6 Replies Latest reply on Aug 14, 2008 8:39 AM by nikos101
    I  want to put some radiobuttons in some of the datagrid cell colums
    nikos101 Level 2
      I am making a fancy form where I will be using a datagrid where users will be entering data to be passed to the server. I want to put some radiobuttons in some of the datagrid cell colums. Does anyone know how to do this?
        • 1. I  want to put some radiobuttons in some of the datagrid cell colums
          Karl_Sigiscar_1971 Level 3
          You need to create an MXML item renderer that contains a radio button. Then you want to set it to be the item renderer for each concerned column.
          An item renderer is a regular MXML file.
          You can either start with
          <mx:RadioButton
          xmlns:mx=" http://www.adobe.com/2006/mxml">
          </mx:RadioButton>
          or
          <mx:Box
          <mx:RadioButton/>
          </mx:Box>
          Then create a script section in the item renderer and use the data property (this.data) in order to access the object of the current row.
          • 2. Re: I  want to put some radiobuttons in some of the datagrid cell colums
            nikos101 Level 2
            Thanks Karl for that advice but I am slightly unsure how to apply your code.
            How would I fit the radio buttons in this MXML into the datagrid?
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" >
            <mx:RadioButtonGroup id="radiogroup1"/>
            <mx:RadioButtonGroup id="radiogroup2"/>
            <mx:RadioButtonGroup id="radiogroup3"/>
            <mx:RadioButtonGroup id="radiogroup4"/>
            <mx:VBox verticalGap="12" horizontalAlign="center">
            <mx:HBox horizontalAlign="left">
            <mx:RadioButton groupName="radiogroup1" id="_1button1"/>
            <mx:RadioButton groupName="radiogroup1" id="_1button2"/>
            <mx:RadioButton groupName="radiogroup1" id="_1button3"/>
            <mx:RadioButton groupName="radiogroup1" id="_1button4"/>
            </mx:HBox>
            <mx:HBox>
            <mx:RadioButton groupName="radiogroup2" id="_2button1"/>
            <mx:RadioButton groupName="radiogroup2" id="_2button2"/>
            <mx:RadioButton groupName="radiogroup2" id="_2button3"/>
            <mx:RadioButton groupName="radiogroup2" id="_2button4"/>
            </mx:HBox>
            <mx:HBox>
            <mx:RadioButton groupName="radiogroup3" id="_3button1"/>
            <mx:RadioButton groupName="radiogroup3" id="_3button2"/>
            <mx:RadioButton groupName="radiogroup3" id="_3button3"/>
            <mx:RadioButton groupName="radiogroup3" id="_3button4"/>
            </mx:HBox>
            <mx:HBox>
            <mx:RadioButton groupName="radiogroup4" id="_4button1"/>
            <mx:RadioButton groupName="radiogroup4" id="_4button2"/>
            <mx:RadioButton groupName="radiogroup4" id="_4button3"/>
            <mx:RadioButton groupName="radiogroup4" id="_4button4"/>
            </mx:HBox>
            </mx:VBox>
            <mx:DataGrid y="355" x="125">
            <mx:columns>
            <mx:DataGridColumn headerText="Behaviour" dataField="col1"/>
            <mx:DataGridColumn headerText="Indicators" dataField="col2"/>
            <mx:DataGridColumn headerText="1" dataField="col3"/>
            <mx:DataGridColumn headerText="2" dataField="col4"/>
            <mx:DataGridColumn headerText="3" dataField="col5"/>
            <mx:DataGridColumn headerText="4" dataField="col6"/>
            <mx:DataGridColumn headerText="N/A" dataField="col7"/>
            </mx:columns>
            </mx:DataGrid>
            </mx:Application>
            • 3. Re: I  want to put some radiobuttons in some of the datagrid cell colums
              Example of setting an item renderer on a datagrid column:
              <mx:DataGridColumn id="maturityDate"
              dataField="maturityDate"
              itemRenderer="com.mycompany.core.view.itemrenderers.DRMaturityDateRenderer">
              </mx:DataGridColumn>
              • 4. Re: I  want to put some radiobuttons in some of the datagrid cell colums
                Concerning the script part of the item renderer, you want to make sure you do not access null data:
                <mx:Label
                textAlign="center">
                <mx:Script>
                <![CDATA[
                private function set onDataChange(value:Object):void
                // Ensure data is not null
                if(this.data)
                this.setStyle("color", "#AA0000");
                else
                this.setStyle("color", "#000000");
                </mx:Script>
                <mx:Binding source="{ this.data }" destination="onDataChange" />
                </mx:Label>
                • 5. Re: I  want to put some radiobuttons in some of the datagrid cell colums
                  nikos101 Level 2
                  Thanks for your help again karl.
                  If you look at the following code, it produces 1 column of radio buttons that are grouped.
                  <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" backgroundGradientColors="[#ffffff, #ffffff]">
                  <mx:Model id="model">
                  <items>
                  <item>
                  <col1>Row 1</col1>
                  <col2>ABCabc DEFdef</col2>
                  <col3>More content</col3>
                  <col4>Some content</col4>
                  <col5>ABCabc DEFdef</col5>
                  <col6>More content</col6>
                  </item>
                  <item>
                  <col1>Row 2</col1>
                  <col3>Long content that will wrap</col3>
                  </item>
                  <item>
                  <col1>Row 3</col1>
                  </item>
                  <item>
                  <col1></col1>
                  </item>
                  <item>
                  <col1>Row 4</col1>
                  </item>
                  <item>
                  <col1>Row 5</col1>
                  </item>
                  <item>
                  <col1>Row 6</col1>
                  </item>
                  <item>
                  <col1>Row 7</col1>
                  </item>
                  </items>
                  </mx:Model>
                  <mx:DataGrid y="10" left="10" right="10" height="179"
                  dataProvider="{model.item}" resizableColumns="false" sortableColumns="false"
                  variableRowHeight="true" useRollOver="false"
                  draggableColumns="false" dragEnabled="false" allowDragSelection="false" textAlign="center">
                  <mx:columns>
                  <mx:DataGridColumn dataField="data" headerText="" width="25">
                  <mx:itemRenderer>
                  <mx:Component>
                  <mx:RadioButton value="{data}" groupName="rgroup1" height="200%" width="100%"/>
                  </mx:Component>
                  </mx:itemRenderer>
                  <mx:DataGridColumn headerText="Column 1" wordWrap="true" dataField="col1"/>
                  <mx:DataGridColumn headerText="Column 2" wordWrap="true" dataField="col2"/>
                  <mx:DataGridColumn headerText="Column 3" wordWrap="true" dataField="col3"/>
                  <mx:DataGridColumn headerText="Column 4" wordWrap="true" dataField="col4"/>
                  <mx:DataGridColumn headerText="Column 5" wordWrap="true" dataField="col5"/>
                  <mx:DataGridColumn headerText="Column 6" wordWrap="true" dataField="col6"/>
                  </mx:columns>
                  </mx:DataGrid>
                  </mx:Application>
                  However I want to have 1 row of radiobuttons that span all the columns. Is this possible using the datagrid?
                  • 6. I  want to put some radiobuttons in some of the datagrid cell colums
                    nikos101 Level 2
                    I guess it would be better to make the row of radiobuttons as a component and put them into the 1 column
