3 Replies Latest reply on May 21, 2018 9:51 AM by Arun Patidar
    AEM 6.4 Servlet POST request not hitting servlet
    grantc99475970
      My problem is similar to the one described here: AEM 6.4 - Java sling servlet does not work with uber 6.4 jar, but does with uber 6.3
      I have the following Servlet:
      @Component(service=Servlet.class,
          property={
              Constants.SERVICE_DESCRIPTION + "=Video servlet",
              "sling.servlet.methods=" + HttpConstants.METHOD_POST,
              "sling.servlet.paths="+ "/bin/damUpload/video"
      public class VideoServlet extends SlingAllMethodsServlet {
       @Override protected void doPost(SlingHttpServletRequest request, SlingHttpServletResponse response) throws ServletException, IOException {
                  System.out.println("POST TO /bin/damUpload/video");
      When I do a POST to localhost:4502/bin/damUpload/video, I get a 500 error:
      18.05.2018 14:47:24.020 *ERROR* [0:0:0:0:0:0:0:1 [1526676444017] POST /bin/damUpload/video HTTP/1.1] org.apache.sling.servlets.post.impl.operations.ModifyOperation Unable to create resource named damUpload in /bin
      18.05.2018 14:47:24.020 *ERROR* [0:0:0:0:0:0:0:1 [1526676444017] POST /bin/damUpload/video HTTP/1.1] org.apache.sling.servlets.post.impl.operations.ModifyOperation Exception during response processing.
      org.apache.sling.api.resource.PersistenceException: Unable to create node at /bin/damUpload
          at org.apache.sling.jcr.resource.internal.helper.jcr.JcrResourceProvider.create(JcrResourceProvider.java:480) [org.apache.sling.jcr.resource:3.0.8]
          at org.apache.sling.resourceresolver.impl.providers.stateful.AuthenticatedResourceProvider.create(AuthenticatedResourceProvider.java:182) [org.apache.sling.resourceresolver:1.5.34]
          at org.apache.sling.resourceresolver.impl.helper.ResourceResolverControl.create(ResourceResolverControl.java:381) [org.apache.sling.resourceresolver:1.5.34]
      I don't see the output for the System.out.println in my stdout.log, so I don't think it ever gets hit.
      My bundle appears to be installed and active, and my service appears to be registered:
        • 1. Re: AEM 6.4 Servlet POST request not hitting servlet
          Arun Patidar Level 4
          I tried your code for me its working.
          Are you using new osgi annotation or felix annotation? Please check Jorg's answer in related Post.
          Arun
          • 2. Re: AEM 6.4 Servlet POST request not hitting servlet
            grantc99475970 Level 1
            Arun Patidar
            I think I'm using the new osgi annotation. I have also tried the solution in Jorg's answer on the related post before asking this question.
            My imports for the servlet are these:
            import org.apache.sling.api.SlingHttpServletRequest;
            import org.apache.sling.api.SlingHttpServletResponse;
            import org.apache.sling.jcr.api.SlingRepository;
            import org.apache.sling.api.servlets.SlingAllMethodsServlet;
            import org.osgi.service.component.annotations.Component;
            import org.osgi.service.component.annotations.Reference;
            import java.io.IOException;
            import javax.jcr.Session;
            import javax.servlet.Servlet;
            import javax.servlet.ServletException;
            import org.apache.sling.api.servlets.HttpConstants;
            import org.osgi.framework.Constants;
            These are in my pom file:
            <dependency>
                        <groupId>org.apache.felix</groupId>
                        <artifactId>org.apache.felix.scr</artifactId>
                        <version>1.6.0</version>
                        <scope>provided</scope>
                    </dependency>
                    <dependency>
                        <artifactId>org.apache.felix.scr.annotations</artifactId>
                        <version>1.9.6</version>
                    </dependency>
                    <dependency>
                        <groupId>biz.aQute</groupId>
                        <artifactId>bndlib</artifactId>
                        <version>1.50.0</version>
                    </dependency>
                    <dependency>
                        <groupId>org.osgi</groupId>
                        <artifactId>org.osgi.core</artifactId>
                        <version>4.2.0</version>
                    </dependency>
                    <dependency>
                        <artifactId>org.osgi.service.component.annotations</artifactId>
                        <version>1.3.0</version>
                    </dependency>
                    <dependency>
                        <artifactId>org.osgi.service.metatype.annotations</artifactId>
                    </dependency>
                    <dependency>
                        <artifactId>org.osgi.annotation</artifactId>
                        <version>6.0.0</version>
                    </dependency>
                    <dependency>
                        <artifactId>org.osgi.compendium</artifactId>
                    </dependency>
            • 3. Re: AEM 6.4 Servlet POST request not hitting servlet
              Yours imports are fine. could you please try to invoke simple servlet with Get method for testing, to check whether issue is with code or something else.
              property={
              Constants.SERVICE_DESCRIPTION + "=Simple Demo Servlet",
              "sling.servlet.paths="+ "/bin/damUpload/video",
              public class SimplePostServlet extends SlingAllMethodsServlet {
                private static final long serialVersionUID = 1L;
              @Override
              protected void doGet(final SlingHttpServletRequest req,
              final SlingHttpServletResponse resp) throws ServletException, IOException {
                      resp.setContentType("text/plain");
                      resp.getWriter().write("Servlet found!");
                      System.out.println("Servlet found!");
