• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
problem went i import a illustrator file to after effects
New Here ,
May 18, 2018 May 18, 2018
the problem is when importing an .ai file to after effects this is not shown correctly, I get text or black screen, just open me .eps but I can not do anything, i try to reinstalling after effects and illustrator and nothing , I have the updated drivers and try creating a new file after reinstalling Illustrator but it only showed me everything in black even though text was no longer available, someone knows how to solve this error, thanks
Views
6.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , May 18, 2018 May 18, 2018
Dropbox says it all:
When you save a file this dialogue should pop up.
That should fix the problem.
Votes
Translate
Translate
Community Expert ,
We would have to see your AI file to know what is wrong with it.
Try this.
Start a new AI document 1920 points by 1080 points. Select any of the shape like the Rectangle tool and draw a shape with a red fil and no stroke. Add a new layer in the layer panel. Use the pen tool to draw a line with a blue stroke about 10 points wide in the second layer. Save the AI file and then import as a composition with cropped layers in AE. You should get a comp with a red shape on the bottom layer and a blue line on the top layer. The background would be black. If that works then the problem is with your original file.
Votes
Translate
Translate
Report
Report
New Here ,
I went back to re-install again illustrator and later i create the new document with you instrutions but nothing happen U_U
this problem it only happens with the .ai files but no with .psd
Votes
Translate
Translate
Report
Report
Community Expert ,
Try this file:
Dropbox - AI Test.ai
If your browser adds a different extension just delete it. Open as a comp retaining layer sizes and you should see two layers. If that file does not work the make sure AE is up to date. If it works, make sure AI is up to date, reset all of the preferences in Illustrator, and make sure the color mode is RGB. You might also want to open the text file in AI and add another line or object and save it as a different name.
Votes
Translate
Translate
Report
Report
New Here ,
when re-install the illustrator and after effects update them to the latest version, the file that you send was already in RGB since it was in video format with 150Dpi, for some reason the problem only occurs when I save something with my illustrator because your file works correctly, also the files of my teacher and that of some colleagues, apparently the problem is my illustrator but I do not understand why, I already uninstall the plugins and reset the preferences of both illustrator and after effects
Votes
Translate
Translate
Report
Report
Community Expert ,
You need to check your preferences:
You should also make sure you are saving with the right settings:
You also need to make sure that there is only one Artboard and that all of the artwork is included on that artboard.
Votes
Translate
Translate
Report
Report
New Here ,
are the default preferences, I uninstalled and reinstalled the adobe illustrator and reset the preferences
Votes
Translate
Translate
Report
Report
Community Expert ,
If you can post the file that does not work I'll take a look.
Votes
Translate
Translate
Report
Report
New Here ,
all my files don't work U_U
this is one of my files
Votes
Translate
Translate
Report
Report
New Here ,
i save you file with my illustrator and now don't work in after effects - this is your file that i save with my illustrator
this is you file that save
and this is you file
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
O_O
thanks you
also i try to open my files with affinity but don't work
but i active this option and now also affinity can read too
thank you TT_TT you save my life
Votes
Translate
Translate
Report
Report
New Here ,
dropbox now also can show a preview of ai file
thanks again
Votes
Translate
Translate
Report
Report
New Here ,
Jul 18, 2021 Jul 18, 2021
LATEST
It's really helpful thank you.
Votes
Translate
Translate
Report
Report
