Is there a way to save a "fillable Form" so that I can save and then send it to others for them to sign electronically and return to me? Thanks
Hi Sidekickwayde,
Good question!
To create a fillable form that you can save and send to others in the form of a weblink or URL - please log in to Adobe Sign, and create a widget. Please note that you need the Adobe Sign Business or Enterprise license to have access to the widget feature.
This widget will allow for you to upload the document, add fillable fields (i.e. name/address etc.) via drag-and-drop which you can then save against a link that can be shared. Everyone that clicks on the weblink
...Copy link to clipboard
I'm searching for some clear advice on this too!
We have a form that teachers need to fill out once per student (daily)… the form should:
If you have found the best method, please show me the way.
Hi Sidekickwayde,
Good question!
This widget will allow for you to upload the document, add fillable fields (i.e. name/address etc.) via drag-and-drop which you can then save against a link that can be shared. Everyone that clicks on the weblink will be taken to a blank form to fill in and complete.
Whenever someone fills in the form, you will receive a filled copy via email and a second copy will also be saved in your Adobe Sign Account.
Hope this helps!
I know this pots was old but its new to me as an relatively new Adobe user. My scenario is this...I run a small plumbing company. Ive created a form that the technicians can fill out in the field with the customer. I need that customer to be able to sign the form. Once signed, I want the technincan to send me a copy of the form via email. Once that email is sent, they can "reset" the form for the next customer to fill out and sign. I have yet to speak or work with an Adobe employee that has helped me complete this task and I need to figure this out - crucial for my business.
