Bonjour,
Depuis ce matin en ouvrant mon ae l'affichage de mes vidéos dans ma bibliothèque et sur ma fenêtre de rendu est rayé violet et vert! Une mise à jour de w10 a été faite ce matin avant d'ouvrir mon ae! Pour info j'ai installé une nouvelle version de mon aecc2018 au cas ou et tjs pas de résultat positif! idem sur adobe première! quand un rendu est fait il n'ya pas de bug, quand une vidéo est lu sur vlc par ex, tout va bien aussi...help ^^
Hi ujudzign,
This problem has affected many Premiere Pro users too.
For most of the people, it started after the latest Windows update. Do you recall updating Windows?
For now, try this:
Go to File > Project Settings > Video Rendering and Effects and switch to Mercury Software Only.
Let us know if that helps.
Rameez
Update your system's graphics driver and check the relevant hardware acceleration settings in the programs.
Mylenium
Thx Millenium
all driver are updated and after effect settings are correct. no working yet
Try differents way but nothing is good
Issues such as this usually occur on systems with less-than-stellar GPUs. Set your comp's resolution to 1/2 and 1/3 to see if they solve the issue. Relatedly, do not set the Comp's Magnification level to anything other than 50% and 100% if AE's interface displays screen drawing issues, such as this.
Merci Roland
So! The day before everything was working properly, I have a computer that allows me to work well and I never had this kind of problem
Thank you for your help but after testing your solution, nothing happened
updates w10? graphic card (not so much young)? .. mother carde... intel ?? that is the question
I suggest you double-check that your GPU drivers are updated. If the problem persists, then you may have to revert to the older GPU driver you were using prior to the Win10 update - once in a while a system update or GPU update may create conflicts or create issues such as the one you are facing right now.
Hi ujudzign,
For now, try this:
Rameez
Actually everything comes from the update! problem set in between
thank you for your feedback
