How can I have a recording of 1 Visitor, 1 Visit and 1 File Download instance, but no Page View? I didn't think we could get results for a PDF alone.
Solved! Go to Solution.
Views
Total Likes
I have a segment setup to look at all hits for a particular sub-domain. The segment = Page containing my sub-domain in the URL and also download link instances containing my sub-domain in the URL. I've then created a freeform in workspace to look at this segment in particular. My metrics are Visitors, Visits, Page Views and Download Link instances.
I'm getting 1 Visitor, 1 Visit, 0 Page Views and 1 Download Link instance.
How can I tell which page has the problem with tracking?
Views
Total Likes
maybe there was a problem tracking the page view?
Views
Total Likes
Views
Total Likes
i guess you‘re not having a problem with the page view, but with the segment you created.
by adding „download link instances“ on a hit-level, there can‘t be any page view! because it is either a hit for a download or a page view, but not both ...
Views
Total Likes
Hi there
Sorry I guess my description of the segment should have been
Hit where
Page contains = sub-domain
OR
Download Link contains = sub-domain
This has worked in many cases, why doesn't it work if you have an OR operator in there?
Views
Total Likes
should work ... did you try without the „download link inst“ what you get as data?
Views
Total Likes
Okay, so i've tweaked the segment and this is what happened. I removed the download link instance.
This resulted in showing no Visitors, no Visits and no Page Views and no downloads.
Now, if i remove page instead, in the file downloads report, 1 download.
Views
Total Likes
are you sure that the "page contains = sub-domain" is correct? you should at least get any hits, or not?
Views
Total Likes
Try with: "Page event" "exists" in the segment which will filter out those hits which are Non Page Views .
Page events consist of image request data from non-standard image requests. Sources of non-standard image requests are download links, exit links, and custom link tracking.
Views
Total Likes
