• Global community
    • Language:
      • Deutsch
      • English
      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Exit
0
Premiere Elements 2018 not working after Windows 10 update
Community Beginner ,
May 21, 2018 May 21, 2018
After latest Windows 10 update I can only open elements and load clip into time line. I can't play or edit it. Can't do anything. Have re installed program but still the same. Can anyone help me please
Views
1.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Moved to the Premiere Elements forum.
Votes
Translate
Translate
Report
Report
Community Expert ,
Try updating or rolling back your graphics driver directly from the video card manufacturerā€™s site.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 02, 2018 Jun 02, 2018
Same issue here, Adobe support just referred me to non relevant advice pages. Very frustrating.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jun 06, 2018 Jun 06, 2018
The latest Windows update has created dozens of complaints not only the Photoshop Elements forum but also for Photoshop and in the feedback forum.
Many different symptoms and error messages, but all linked to the amount of RAM. Not all users have the problem.
The common workaround is to edit the Windows registry.
Error: An integer between 50 and 8 is required | Elements | Windows 10
I would be surprised if that Windows upgrade issue does not exist with Premiere Elements too.
In that case, editing the registry would be the solution.
Have a look at the recent posts about the issue in the Photoshop Elements forum.
In the feedback forum:
Photoshop CC 2018: An integer between 96 and 8 is required. Closest value inserted. "Could not compl...
Votes
Translate
Translate
Report
Report
New Here ,
Jun 17, 2018 Jun 17, 2018
Changing the Registry does not help in this case. Anybody found a solution for this problem in Premiere Elements yet?
Votes
Translate
Translate
Report
Report
Community Expert ,
To be sure the registry edit is effective and has been correctly made, use the menu Help >> System Information.
The line for "available for Premiere Elements" should have been increased according to the decimal value you have given. If it is not, the edit was not done correctly.
If the value has been increased, then that means that the registry update is probably not the culprit.
Here is a screenshot for my Photoshop Elements;  I don't have  Premiere installed.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 19, 2023 Aug 19, 2023
I tried that method for using Regeit files with the Override but it did not work.. I even tried reinstalling the software, nothing works.
Votes
Translate
Translate
Report
Report
Community Expert ,
Two ideas that MAY work to install and/or run old programs in Windows 10 or Windows 11
-RIGHT click the program icon or EXE and select a compatibility mode in the pop up option window
-and/or select Run as Administrator to assign FULL Windows permissions
-also https://helpx.adobe.com/x-productkb/global/create-local-administrator-account-windows.html
Votes
Translate
Translate
Report
Report
New Here ,
Aug 20, 2023 Aug 20, 2023
LATEST
I went on this page to do the Regedit and the directions were much better. I was doing something that didn't work but after using this page and their directions were good. https://helpx.adobe.com/photoshop/kb/invalid-numeric-entry-integer-96-8-required-photoshop.html
Votes
Translate
Translate
Report
Report
