[Background]
I have set scheduled runnig a batch file whcih indexes over 200,000 PDF files every weekend. However index creating has become failed since the week before last and not be able to create .idx files also.
The number of PDF files increases by about 100-200 during a each week, so that I suspect this problem is caused by excess of the max indexable number of PDF files.
[Environments]
Windows Server 2012 R2 (64bit)
Adobe Acrobat Pro DC
File Version: 15.006.30417.5399
Free Capacity of Hard Disk (C Drive): 17.3GB
Available Physical Memory: 2.37GB
Available Virtual Memory: 3.97GB
[Reference]
Creating PDF indexes
https://helpx.adobe.com/acrobat/using/creating-pdf-indexes.html
[Questions]
Is there any threshold about index building?
[Expected Answers (e.g.)]
Max number of PDF files is [number]. / Failed indexing with [number] PDF files.
Max size of PDF files is [size]. / Failed indexing with [size] PDF files.
[Supplement]
I mentioned about this issue in Bug report, however I have yet to get any answers now.
Index Build Failed – Share your feedback on Acrobat DC
Thank you for sharing your knowledge.
[Self Solved]
This was because of "too much amount of PDF files".
Moving a large part of PDF files inside a target folder, I could make an index without any trouble.
Thanks for reading this question.
[Self Solved]
Hello Sugiyama_t,
Thank you so much for sharing the fix and workaround, it will help other users facing a similar issue.
Regards,
Anand Sri.
