Hi, I opened up an image in PS today, and it came up looking really dark, contrasty and over saturated. Same in LR.
I checked the image in Paint, MS Photo, After Effects, and it looked as it should in all of those.
I've checked my GPU settings, and global settings are in force for all the various apps. I've attached a screen shot of PS vs AE to demostrate the issue.
anyone else experiencing this issue? I can't work with any photos in LR or PS until this is resolved
The problem is with the monitor profile.
You seem to be on Windows 10, which is known to install bad profiles when doing updates, so that probably happened to you.
Paint, the Photos app, etc. are not color managed, do not use the monitor profile, and are therefore unaffected.
Try setting the monitor profile to sRGB (Adobe RGB if you have a wide gamut monitor). If this fixes the problem, you should ideally calibrate your monitor with a hardware calibrator.
Go to Control panel > Color management, add
...Copy link to clipboard
Hi philipb,
We're really sorry for all the hassle. Could you please let us know the exact version Photoshop you are using now?
Also, Photoshop and After effect both work on different color profiles. You may try calibrate the monitor profile back to defaults and check if that helps.
Regards,
Mohit
Go to Control panel > Color management, add the sRGB profile, and set it as default. Make sure Use my settings for this device is checked.
After Effect is probably not color managed – Photoshop is.
Color managed applications will display correct colors regardless of the profile, as long as the monitor profile is sound and correct.
There is no such thing as a default monitor profile.
When you run calibration with a hardware calibrator, a custom profile is created, which describes the monitor accurately in its calibrated state. So the calibration process consists of two steps – calibration and profiling.
Many thanks, that worked. I think it might have been the April Windows Update that gave me the headache.
Fascinating discussion and one I'd not given enough thought to.
