1 Reply Latest reply on Jun 8, 2018 8:41 AM by Adorobat
    Setting Preferences in Acrobat Pro DC
    dz69289741
      Hi there. I'm new here and have a question. I am creating a huge amount of internal links in several large documents. I have attached all of the appendices which I'm creating the links to. Right now, I need to also Edit each link after it's created, in order to choose "Open in New Window". Does anyone know of a way to change the preference so that the link will automatically open in a new window without having to do this extra step for each link?
      Thanks for your thoughts on this.
        • 1. Re: Setting Preferences in Acrobat Pro DC
          Adorobat Adobe Employee
          Hi Dz,
          As per the issue description mentioned above, you want to set the preferences for internal links in the pdf, is that correct?
          Go to Edit PDF  > select one of the links > right-click > Properties > Actions > under Actions > click on Open a file > Edit
          Select the files > and select New Window.
          Let us know if you need any help.
          Shivam
