0 Replies Latest reply on Mar 14, 2008 7:08 PM by Ken_Nielsen
    Trouble trying to rotate a gradient in Flash
    Ken_Nielsen
      I understand that making a rectangle in object drawing mode and then filling that rectangle with a gradient fill that I can then rotate that fill using the Gradient Transform Tool. The problem is it is out of control when I select the corner rotate handle: It does not constrain to 90 degrees when I hold the shift key down and the indicators that show the rotate angle on the stage disappear off the screen in a strange fashion.
      Something is wrong but I've never used this feature before and wondered if someone with experience using edits to gradient fills in Flash could set me straight.
      TIA,
      Ken
