3 Replies Latest reply on May 25, 2018 12:19 PM by AnandSri
    Out of Memoryy
    russellm79499843 Level 1
      I am a support person and I have an end user who gets the message Out of Memory when he is viewing a PDF file.
      I tried clearing his temp file - still got the message. I also tried increasing virtual memory - still same message.
      Is there any solution to this issue?
        • 1. Re: Out of Memoryy
          AnandSri Adobe Employee (Admin)
          Hello Russellm,
          We apologize for the inconvenience caused, as per the description above, one of the users is getting an error message "Out of memory" when viewing a PDF file, Is that correct?
          This error usually occurs, if you run too many memory-extensive applications simultaneously. So try performing those redaction tasks after closing some of the background processes/applications.
          Also, check for any pending updates of Acrobat from help>check for updates, reboot the machine after installing any updates and try viewing the PDF file.
          Is it specific to one PDF file or with all the PDF files? Try disabling the Protected mode once and see if this brings any difference. To disable the protected mode, please refer to Protected View feature for PDFs (Windows), Adobe Reader
          You can also navigate to Acrobat's Preferences from Edit>Preferences>Security(Enhanced)>Protected View>Off
          Note: Disabling Protected mode is for testing purpose, please enable it back.
          In Acrobat's Preferences, navigate to Edit>Preferences>Page Display>Page Content and Information, select "Show large images"
          If the issue persists, please share the following details so that we can help you better:
          Let us know how it goes and share your findings.
          Regards,
          Anand Sri.
          • 2. Re: Out of Memoryy
            CLASSIFICATION: UNCLASSIFIED
            We have found out the cause of the issue. There is one page that is causing the issue and we think the page will have to be fixed.
            Russell Medcalf
            Team Vectrus
            PC Technician
            [Personal info removed by Mod: Phone number, email]
            • 3. Re: Out of Memoryy
              Hello Russellm,
              Thank you for sharing the update. Please remove the PDF page and check. Let us know how it goes.
              Regards,
              Anand Sri.
