I have project created in Captivate 2017. I imported audio and plays when I view the file in preview. When I export and publish the file on the server when I play it on the internet the file plays but no audio on the first slide unless I stop the playbar and restart it then the audio on slide one will play. I have tried several things to get it to play on the first slide but once published it will not.
Any ideas?
Thank you
Try adding a short blank slide BEFORE your current slide. And make sure there is a gap between your audio files and the beginning or end of the slide timeline. At least 1/10 second should do it. See if that helps.
I had tied Rod's suggestion, and it did not work for me the first time.
I did find a work around that worked for me. On the first slide with audio, I had attached the audio file using the Options button. I removed the file from there and used an Action to play the audio on Enter.
Hello,
I had the same issue. I changed my default browser from Chrome to Microsoft Edge browser.
It worked and I didn't have to create a work around or have a play button display in preview or my lms.
Change your default browser. Hope this is helpful.
