I have a file with audio on every slide. I've published as HTML5 and loaded to our LMS. The audio on the first slide plays when a user launches for the first time. When a person closes out and then reopens, the audio doesn't play on the first slide. This is the only slide that has this issue.
Any ideas?
Try adding a blank slide BEFORE your current first slide. Make it a half second or so in duration.
I try to avoid audio and heavy advanced actions on the first slide. Rod offered a suggestion with the same goal. It is a bit weird however that the course will play the audio correctly the first time, but not when relaunched.
Hi RodWard and Lilybiri,
Thanks for the suggestion. I realized as I read your replies, that I wasn't accurate in my original post. The program starts out with a 3 second splash screen, so the audio doesn't actually start until the second slide and that is the audio that doesn't play after the first launch.
Thanks for your help!
