• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Removing hundreds of gradients at once in a low poly image
New Here ,
May 25, 2018 May 25, 2018
So I used a web tool to make one of those low poly mesh images that look like 3d modeling. It's not this image, but the same style.  There are hundred of triangles that make up this image, and most of them are filled with unique gradients. I would like to "flatten" these gradients to the average value of each triangle (so I would keep some of the 3d look but I could alter for screen-printing). Any ideas? I know I can click on each triangle individually. Should I move to photoshop and posterize?
Views
514
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , May 26, 2018 May 26, 2018
Votes
Translate
Translate
Adobe
Community Expert ,
In the past 1,5 hours since you posted this you would probably have been done with doing it manually.
Votes
Translate
Translate
Report
Report
New Here ,
Yup- I did it manually. Just interested to know if there's a simple way to do it that I'm missing- I'm a beginner. But most forum answers seem to be pretty dismissive of beginner questions.
Thanks anyway.
Votes
Translate
Translate
Report
Report
Community Expert ,
If you need to edit hundreds or thousands of different objects (in this case the gradients probably differ both in directions and the colors) a simple solution may just not be available.
How frequent do you expect the task to be for you in the future?
If you expect to do this often you may want to look into Illustrator Scripting and ask for advice over on:
Votes
Translate
Translate
Report
Report
Community Expert ,
I find it distressing that you have reached this conclusion. A lot of people here spend many hours a week primarily attempting to help beginners, patiently and, usually, successfully.
Peter
Votes
Translate
Translate
Report
Report
Community Expert ,
May 27, 2018 May 27, 2018
CarlosCanto, good find!
tromboniator, I disagree with the OP, too.
I am not exactly a regular on the Illustrator Forum but if anything it seems to me the regulars here might be more considerate than elsewhere.
It seems the original poster has an Activity history of two posts on one thread (this thread); so one might wonder what sample they based their observation on.
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Community Expert ,
It might be possible to automate the task with a Script but if it’s worth the trouble is doubtful.
What are the gradients like exactly?
Please post meaningful screenshots including all pertinent Panels.
Votes
Translate
Translate
Report
Report
Enthusiast ,
LATEST
With a high MagicWend selection of tolerance values, you may be able to select and combine certain gradients.
Graphic Designer Educator / PrePress Consultant
Votes
Translate
Translate
Report
Report
