Hello again. I'm very close to finishing the easier part of my Paper Doll game. But my latest demo stoped working and I can't pin down the reason. The issue may be too many uses of a similar code, but I don't know how to rewrite it... Here, I will post code from the problem page and hylight the lines making flash upset.
import fl.controls.ColorPicker;
import fl.events.ColorPickerEvent;
import flash.geom.ColorTransform;
var myGenderArray = [male, female, none];
for each (var Gender in myGenderArray) {
var myDepArray = [dep0, dep1, dep2, dep3, dep4, dep5, dep6, dep7, dep8, dep9, dep10, dep11, dep12];
for each (var Dep in myDepArray) {
var myEyeArray = [eye1, eye2, eye3, eye4, eye5, eye6, ocd];
for each (var Eye in myEyeArray) {
var myAnxArray = [anx0, anx1, anx2, anx3, anx4, anx5, anx6, anx7, anx8, anx9, anx10, anx11, anx12];
for each (var Anx in myAnxArray) {
var myPanicArray = [pan0, pan1, pan2, pan3, pan4, pan5, pan6, pan7, pan8, pan9, pan10, pan11, pan12];
for each (var Panic in myPanicArray) {
var myADhdArray = [ad0, ad1, ad2, ad3, ad4, ad5, ad6, ad7, ad8, ad9, ad10, ad11, ad12];
for each (var ADhd in ADhdArray) {
var myODD1Array = [odd0, odd1, odd2, odd3, odd4, odd5, odd6, odd7, odd8, odd9, odd10, odd11, odd12];
for each (var ODD1 in ODD1Array) {
var myExtraArray = [bip, dia, ptsd, remove];
for each (var Extra in ExtraArray) {
Gender.addEventListener(MouseEvent.CLICK, onGenderClick);
Dep.addEventListener(MouseEvent.CLICK, onDepClick);
Eye.addEventListener(MouseEvent.CLICK, onEyeClick);
Anx.addEventListener(MouseEvent.CLICK, onAnxClick);
Panic.addEventListener(MouseEvent.CLICK, onPanicClick);
ADhd.addEventListener(MouseEvent.CLICK, onADhdClick);
ODD1.addEventListener(MouseEvent.CLICK, onODD1Click);
Extra.addEventListener(MouseEvent.CLICK, onExtraClick);
function onGenderClick (event:MouseEvent):void {
body1.gotoAndStop(event.target.name);
function onDepClick (event:MouseEvent):void {
body2.gotoAndStop(event.target.name);
function onEyeClick (event:MouseEvent):void {
body3.gotoAndStop(event.target.name);
function onAnxClick (event:MouseEvent):void {
body4.gotoAndStop(event.target.name);
function onPanicClick (event:MouseEvent):void {
body5.gotoAndStop(event.target.name);
function onADhdClick (event:MouseEvent):void {
body6.gotoAndStop(event.target.name);
function onODD1Click (event:MouseEvent):void {
body7.gotoAndStop(event.target.name);
function onExtraClick (event:MouseEvent):void {
body8.gotoAndStop(event.target.name);
The program claims that ADhdArray, ODD1Array, and ExtraArray are undefined properties. But I assembled these Arrays and all pieces the same way as all the others, They have buttons and frame labels set up for the array, and the linked to the movie files with instance names set up accordingly.
I can post more code if needed, and would be thankful for any help.
(Oh in case anyone wants to see the last working model, its here: Traits Demo2 - mars714's Sta.sh )
the first problematic line of code uses ADhdArray and that's not defined in the code you showed. you do show myADhdArray being defined but if those are supposed to be the same, they need the same reference name. likewise, for the other problematic lines.
Thank you! I was going over the code over and over but I didn't notice that 'my' appeared in the second line in those that worked, and not in the error lines. Sometimes I just miss little things like that ^^; any how, Thanks again!
you're welcome.
