• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
reponsive design - At Smartphone, gaps between my blocks???
New Here ,
May 30, 2018 May 30, 2018
Hello, I am editing a template which I have purchased on themeforest!
Everything works and looks great on the computer as well.
But as soon as I call it on my smartphone there are always big gaps between the blocks!
How can I fix this?
my site: CuePlay - DJ / Producer Personal Website Responsive Muse Template
my projectdata: Dropbox - DJ Palmi.muse
Views
384
Translate
Translate
Report
Report
Community guidelines
community guidelines
Hey DJPalmi,
Thought to give a look at your site and found that there isn't anything can do for this, it's a flaw in design itself.
I don't even say it as a flaw but maybe slight misaligned settings which can be solved very easily but manually.
For ease of access you can reduce the page to 25 % and then try adjusting the contents as described above by our expert.
Hope this helps.
Regards,
Ankush
Votes
Translate
Translate
LEGEND ,
No secret about it! There are several simple issues:
1. Invisible elements:
Delete them.
2. Many elements „bleed“ outside the page/breakpoint width. This is forbidden, because it causes heavy issues on mobile devices. Read this document for further information: https://forums.adobe.com/docs/DOC-8953​ Make sure, that no element in no breakpoint ever overlaps/is placed outside the page/breakpoint width.
3. You have to adjust the vertical position of your elements breakpoint-wise. If you do this, most issues will be gone:
  • Go to the specific breakpoint
  • Select the first element, which has a too large distance to the other elements.
  • A double triangle appears at the right side of Muse’s application window:
  • Drag it upwards, until the  spacing is correct. This causes all elements below the icon to move synchronously up/downwards.
  • Repeat that for every misplaced element in every breakpoint.
  • You’ll find the reason for this behaviour and a way to avoid it, by reading my answer in this thread: https://forums.adobe.com/message/8749608#8749608
If these informations don’t solve your issues. Correct you document and share it again.
Votes
Translate
Translate
Report
Report
New Here ,
Hello Günter, thank you for your quick reply.
I have followed all your steps.
Unfortunately, there are still big gaps in the smartphone version.
my file after your tips: Dropbox - DJ Palmi.muse
please help me 😕 P.s. i'm not a expert i'm a newbie of this programm
Votes
Translate
Translate
Report
Report
LEGEND ,
I will have a look tomorrow!
Votes
Translate
Translate
Report
Report
Hey DJPalmi,
Hope this helps.
Regards,
Ankush
Votes
Translate
Translate
Report
Report
New Here ,
May 31, 2018 May 31, 2018
Thanks!!!! Its perfect.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
That means, your problem is solved?
Votes
Translate
Translate
Report
Report
