Hello!
I have 2 indesign files called TextNEW (without paragraph styles) and TextOLD. Both documents have exactly same number of paragraph. And I would like a script to find and replace the old text paragraph for the new text. Keep in mind, not all paragraph have changes. Please see the example, the text color RED show you the changes to apply in the TextOLD file. Like you can see the text of the Article 2 is empty in this case, and of course, the text from the TextNEW need be copied into the empty paragraph of the TextOLD.:
TextNEW:
Article 1.
All human beings are born free and equal in dignity and rights. They are endowed with reason and conscience and should act towards one another in a spirit of brotherhood.
Article 2.
Everyone is entitled to all the rights and freedoms.
Article 3.
Everyone has the right to life, liberty and security of person.
TextOLD:
Article 1.
All persons beings are born free and equal in dignity and rights. They are endowed with reason and conscience and should act towards one another in a spirit of brotherhood.
Article 2.
Article 3.
AFTER RUN THE SCRIPT THE TextOLD file:
Article 1.
Article 2.
Article 3.
Like you can see my TextNEW have NOT paragraph styles applied:
my TextOLD have paragraph styles applied:
here you can Download the files here.
Thanks so much!
here the solution:
Download the files and InDesign example
THE SCRIPT
...try{
var myNewStory = app.activeDocument.stories[0];
} catch(myError){ alert("myNewStory not found. Document is empty?"); exit();}
try{
var myOldStory = app.documents[1].stories[0];
} catch(myError){ alert("myOldStory not found. Document is empty?"); exit();}
var myNewParagraphs = myNewStory.paragraphs;
var NewLen = myNewParagraphs.length;
var myOldParagraphs = myOldStory.paragraphs;
var OldLen = myNewParagraphs.length;
if(OldLen !=NewL
here the solution:
THE SCRIPT
try{
try{
if(OldLen !=NewLen) {alert("There is a mismatch between the number of paragraphs"); exit(); }
var myParaStyles = [], myStyle, myText;
if(myNewParagraphs.item(0).parentStory.insertionPoints.item(-1).index == myNewParagraphs.item(-1).insertionPoints.item(-1).index){
myNewParagraphs.item(-1).insertionPoints.item(-1).contents = "\r";
if(myOldParagraphs.item(0).parentStory.insertionPoints.item(-1).index == myOldParagraphs.item(-1).insertionPoints.item(-1).index){
myOldParagraphs.item(-1).insertionPoints.item(-1).contents = "\r";
for(var i=0; i<NewLen; i++) {
myParaStyles.push(myOldStory.paragraphs.appliedParagraphStyle);
myOldStory.paragraphs.contents = "\r";
myText = myNewParagraphs.characters.itemByRange(0, myNewParagraphs.characters.length-2);
myText.duplicate(LocationOptions.atBeginning, myOldStory.paragraphs.insertionPoints.item(0) );
myOldStory.paragraphs.appliedParagraphStyle = myParaStyles;
QUICK VIEW
Thanks, Boris for your help.
