Hi hardlyworking
Okay, now it is me that is confused. For starters, and just
to clarify, I suspect MEP45 was/is creating a single WebHelp target
with no Student/Admin stuff. Just basic WebHelp was what I was
assuming was being discussed.
Now on to your issue. How are you generating? Batch generate?
Are you using a merged setup? Conditional tagging? We need more
information to go on here.
The bottom line here is that many folks see the swarm of
WebHelp files and think that surely there has to be some way to put
it on a diet and slim it down a bit. But all those files are there
for a reason. Accommodating different browsers, different settings
within the same browsers, different versions of the same browser,
etc. While it would be possible to ferret out all the files that
aren't needed for your own situation and delete them, it would have
to be done each and every time you updated the help. From an
efficiency standpoint, it's simply better to consider all of them
necessary and adapt to the flow.
Cheers... Rick
