2 Replies Latest reply on Sep 23, 2018 9:41 AM by peter_ho@msn.com
    Sign in fails from within LR and PS CC
    peter_ho@msn.com
      I recently created a clean install of Win 10 on an SSD drive and reinstalled my Adobe CC Subscription apps. I also copied across relevant files (catalogues, preferences) from the old HDD I was previously running the apps from.
      I now find "Sign in to Sync" from within LR CC fails. It brings up the Sign In pop up window:
      but it does not sign in after I click the Sign in button. Same with PS CC. Apps and Windows are up to date. Have tried quite a number of suggested solutions found on this forum and elsewhere, but no joy. HOWEVER, I find I can successfully sign in and sync with my mobile device if I run LR with Admin rights, so the problem seems to be related to permissions somewhere, but where?
      It may or may not be related, but I also get this message when starting PS CC Have uninstalled and reinstalled PS, but same problems:
      I've uninstalled and reinstalled PS CC, but same problem.
      I'd be most grateful  if some clever Adobe techie can solve this problem for me!!
      Here's the System Info from Lightroom:
      Lightroom Classic version: 7.3.1 [ 1167660 ]
      License: Creative Cloud
      Language setting: en
      Operating system: Windows 10 - Home Premium Edition
      Version: 10.0.17134
      Application architecture: x64
      System architecture: x64
      Logical processor count: 8
      Processor speed: 3.6 GHz
      Built-in memory: 16302.1 MB
      Real memory available to Lightroom: 16302.1 MB
      Real memory used by Lightroom: 2853.7 MB (17.5%)
      Virtual memory used by Lightroom: 2856.1 MB
      GDI objects count: 562
      USER objects count: 1831
      Process handles count: 3752
      Memory cache size: 3163.9MB
      Internal Camera Raw revision: 933
      Maximum thread count used by Camera Raw: 5
      Camera Raw SIMD optimization: SSE2,AVX
      Camera Raw virtual memory: 786MB / 8151MB (9%)
      Camera Raw real memory: 779MB / 16302MB (4%)
      System DPI setting: 96 DPI
      Desktop composition enabled: Yes
      Displays: 1) 2560x1440, 2) 1024x1280
      Input types: Multitouch: No, Integrated touch: No, Integrated pen: Yes, External touch: No, External pen: Yes, Keyboard: No
      Graphics Processor Info:
      DirectX: AMD Radeon HD 7800 Series (22.19.162.4)
      Application folder: C:\Program Files\Adobe\Adobe Lightroom Classic CC
      Library Path: C:\Users\Peters\Pictures\Lightroom\Lightroom Catalog-2.lrcat
      Settings Folder: C:\Users\Peters\AppData\Roaming\Adobe\Lightroom
      Installed Plugins:
      Config.lua flags: None
      Adapter #1: Vendor : 1002
      Device : 6818
      Subsystem : b041002
      Revision : 0
      Video Memory : 2029
      Adapter #2: Vendor : 1414
      Device : 8c
      Subsystem : 0
      Revision : 0
      Video Memory : 0
      AudioDeviceIOBlockSize: 1024
      AudioDeviceName: Speakers / Headphones (Realtek High Definition Audio)
      AudioDeviceNumberOfChannels: 2
      AudioDeviceSampleRate: 48000
      Build: 10.0x7
      Direct2DEnabled: false
      GL_ACCUM_ALPHA_BITS: 0
      GL_ACCUM_BLUE_BITS: 0
      GL_ACCUM_GREEN_BITS: 0
      GL_ACCUM_RED_BITS: 0
      GL_ALPHA_BITS: 8
      GL_BLUE_BITS: 8
      GL_DEPTH_BITS: 24
      GL_GREEN_BITS: 8
      GL_MAX_3D_TEXTURE_SIZE: 2048
      GL_MAX_TEXTURE_SIZE: 16384
      GL_MAX_TEXTURE_UNITS: 8
      GL_MAX_VIEWPORT_DIMS: 16384,16384
      GL_RED_BITS: 8
      GL_RENDERER: AMD Radeon HD 7800 Series
      GL_SHADING_LANGUAGE_VERSION: 4.50
      GL_STENCIL_BITS: 8
      GL_VENDOR: ATI Technologies Inc.
      GL_VERSION: 4.5.13474 Compatibility Profile Context 22.19.162.4
      GPUDeviceEnabled: false
      OGLEnabled: true
      GL_EXTENSIONS: GL_AMDX_debug_output GL_AMD_blend_minmax_factor GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_framebuffer_sample_positions GL_AMD_gcn_shader GL_AMD_gpu_shader_int64 GL_AMD_interleaved_elements GL_AMD_multi_draw_indirect GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_pinned_memory GL_AMD_query_buffer_object GL_AMD_sample_positions GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_atomic_counter_ops GL_AMD_shader_stencil_export GL_AMD_shader_stencil_value_export GL_AMD_shader_trace GL_AMD_shader_trinary_minmax GL_AMD_sparse_texture GL_AMD_stencil_operation_extended GL_AMD_texture_cube_map_array GL_AMD_texture_texture4 GL_AMD_transform_feedback3_lines_triangles GL_AMD_transform_feedback4 GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_viewport_index GL_ARB_ES2_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_ballot GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_bptc GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_IBM_texture_mirrored_repeat GL_INTEL_fragment_shader_ordering GL_KHR_context_flush_control GL_KHR_debug GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_OES_EGL_image GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
        • 1. Re: Sign in fails from within LR and PS CC
          Akash Sharma Adobe Employee
          Hi there,
          Sorry that you're having problems signing in to Photoshop and Lightroom.
          Please take a look at the steps mentioned in this article Solution to the issue: Adobe Creative Cloud Libraries panel doesn't load in desktop products and let us know if that helps.
          Akash
          • 2. Re: Sign in fails from within LR and PS CC
            peter_ho@msn.com Level 1
            Hello Akash,
            Regarding my issue, I have tried the solutions suggested in your link, which don’t help.
            The CC panel now opens OK without error and lists installed products, so I am connected to the Cloud OK.
            LR Classic opens OK with selected catalogue under my non-admin windows 10 user account, but sync is still not enabled. Clicking the “Sync with Lightroom CC” drop down menu item pops up the sign-in window asking me to login in to ACC (as shown in my original post); the window goes away when I click sign-in and the Sync menu item  then becomes greyed out, as in following screen capture:
            I can still only sync by running LR Classic in Admin mode.
            I’d appreciate any help you can give to solve this very annoying problem.
            Regards,
            Peter
            Hello Akash,
            Regarding my issue, I have tried the solutions suggested in your email below, which don’t help. The CC panel opens OK and lists installed products, per attached window capture.
            LR Classic opens OK with selected catalogue, but sync is not enabled. Clicking the “Sync with Lightroom CC” menu item pops up a window asking me to login in to ACC, but when I do this, the window goes away and the Sync item becomes greyed out, as in following screen capture:
            Regards,
            Peter Homonko
