5 Replies Latest reply on Jun 4, 2018 11:29 AM by sidpalas
    24hr time stamp format
    Polycontrast Level 1
      The function below prints the time using the 24hr clock format. When the hours, minutes and seconds are less than 10, the time value is printed in a single digit format. Can someone give me an idea of how to format the time so that it always prints in a double digit format.
      For instance  the time 21:0:5  would be 21:00:05
        alert(runTime())
        function runTime () {
          try{
            var digital = new Date();
            var hours = digital.getHours();
            var minutes = digital.getMinutes();
            var seconds = digital.getSeconds();
            var milliseconds = digital.getMilliseconds();
            militaryTime = hours + ":" + minutes + ":" + seconds;
            return militaryTime;
          } catch(e) {alert(e)}
        • 1. Re: 24hr time stamp format
          c.pfaffenbichler Level 9
          var theNumber = 5;
          alert (bufferNumberWithZeros(theNumber, 2));
          ////// buffer number with zeros //////
          function bufferNumberWithZeros (number, places) {
          var theNumberString = String(number);
          for (var o = 0; o < (places - String(number).length); o++) {
          theNumberString = String("0" + theNumberString)
          return theNumberString
          • 2. Re: 24hr time stamp format
            SuperMerlin Level 5
            alert(time());
            function time(){
            var date = new Date();
                var d  = date.getDate();
                var day = (d < 10) ? '0' + d : d;
                var m = date.getMonth() + 1;
                var month = (m < 10) ? '0' + m : m;
                var yy = date.getYear();
                var year = (yy < 1000) ? yy + 1900 : yy;
                var hours = date.getHours();
                var minutes = date.getMinutes();
                var seconds = date.getSeconds();
                if (hours <= 9) hours = "0" + hours;
                if (minutes <= 9) minutes = "0" + minutes;
                if (seconds <= 9) seconds = "0" + seconds;
                todaysDate =  hours + ":" + minutes + ":" + seconds;
                return todaysDate.toString();
            • 3. Re: 24hr time stamp format
              Thank you!
              • 4. Re: 24hr time stamp format
                Thank you!
                • 5. Re: 24hr time stamp format
                  sidpalas Level 2
                  While both of the above answers are correct, I prefer the following method as it is slightly more succinct:
                  function makeTwoCharString(intIn){
                          return ("0" + intIn.toString()).slice(-2);
                  As long as the input is between 0 and 99 (inclusive) it will return the desired two digit string.
                  Combining with your code gives:
                  alert(runTime());
                    try{
                      var hours = makeTwoCharString(digital.getHours());
                      var minutes = makeTwoCharString(digital.getMinutes());
                      var seconds = makeTwoCharString(digital.getSeconds());
