1 Reply Latest reply on Mar 14, 2008 10:50 PM by pixlor
    Brick pattern?
    DIY_Lobotomy Level 1
      I need to fill a large selected area with a colored brick pattern. Is that possible using FW CS3? If so, what is the best way? Thanks!...
        • 1. Re: Brick pattern?
          pixlor Level 4
          Here's an easy way to fill a shape.
          In the Properties palette, in the drop-down box for the fill that usually says "Solid," select
          Pattern > Other...
          and select your brick pattern. As long as your image tiles, you should be fine.
