6 Replies Latest reply on Jun 18, 2018 3:46 PM by Kevin-Monahan
    Laggy playback and handling of AVC video
    Gorod +
      Got a video file recorded using OBS and Blackmagic Decklink 4K card. It was encoded using GPU and ended up in format like this:
      Video
      Format                      : AVC
      Format/Info                 : Advanced Video Codec
      Format profile              : Main@L4.2
      Format settings             : CABAC / 2 Ref Frames
      Format settings, CABAC      : Yes
      Format settings, ReFrames   : 2 frames
      Codec ID                    : avc1
      Codec ID/Info               : Advanced Video Coding
      Duration                    : 46 min 50 s
      Bit rate mode               : Constant
      Bit rate                    : 35.0 Mb/s
      Width                       : 1 920 pixels
      Height                      : 1 080 pixels
      Display aspect ratio        : 16:9
      Frame rate mode             : Constant
      Frame rate                  : 60.000 FPS
      Color space                 : YUV
      Chroma subsampling          : 4:2:0
      Bit depth                   : 8 bits
      Scan type                   : Progressive
      Bits/(Pixel*Frame)          : 0.281
      Stream size                 : 11.2 GiB (100%)
      Color range                 : Limited
      Matrix coefficients         : BT.470 System B/G
      I have an 8 core xeon and 1080ti gpu, but program lagged hardly when I tried to edit something. Playback lagged too, cpu load was near 80%. What's wrong? Should I update some codecs or settings? CUDA rendering works fine, I checked.
