1 Reply Latest reply on Jun 5, 2018 8:14 AM by alank99101739
    Changing direction Changing Views
    Allystar67
      Hi there, just watched the Hummingbird video (awesome)
      How would you make the change from side view to front view smoother? if you had to insert an intermediate drawing (or 2) in between the front and side drawings, how can you include it in the turn. Make sense?
      thanks
        • 1. Re: Changing direction Changing Views
          alank99101739 Level 4
          There is a “Head turner” behavior that allows different angles. You can put the whole body under the head turner if you want - it just chooses between different head positions.
          You can however do the same thing with swapsets and keyboard triggers so use say numbers 1234567890 on your keyboard trigger different angles of the puppet. But don’t ask me to rig that! Each profile needs to be rigged up separately! The head turner behavior is convenient because your head in the web cam turns the puppet.
