I do a web comic series and I create my outlines and the basic sketch in Adobe Draw, and then export it to Photoshop to do the line art and coloring. The last few days, when I export to photoshop it is doing some weird compression and making my lines look blurry and unclean. I've found a workaround by exporting to Illustrator first and then exporting to .psd but I would rather just export directly to photoshop. I'm not sure what's happening. I've attached some samples of upload from today and upload from a week ago. HLEP!
This week:
Last Week:
Hi Suzy.
Great. Thanks for this information. It's super helpful. And thanks for doing the test.
The blurriness of your PSD is due to a server-side bug that the team is aware of and working on. Since it involves another team, I'm not exactly sure when it will be resolved (probably next week), but I don't think it will require an update to the apps.
Until then, as a workaround just keep using pixels instead of inches for a bit and you should be okay.
Thanks again for checking.
Sue.
Hi Suzy.
Sorry for taking so long to respond; it's likely I'm going to have to reach out to the product team about this one, but I have a couple of quick questions first:
* What version of Draw are you using? (If you're on iOS, tap the Settings icon in the lower nav then About Draw; if you're on Android tap the hamburger icon in the upper left.)
* What version of Ps are you using? ( Check this by opening the app and choosing About Photoshop from the Photoshop CC file menu).
* And, I think I know the answer to this one, but just want to make sure: You're sending directly to the desktop from Draw, correct? That is, you're not saving as a .psd first, right?
EDIT/ADD: And one more thing I'd like you to try, if you would:
Create a new "custom" document and use as your form of measure pixels instead of inches (ie, 1800 x 3600 pixels instead of 6 x12 inches at 300 dpi) and see if you still experience the same loss of quality.
I think that's all I need to know right now. Let me know.
Sue
Adobe Draw - Version 4.6
Adobe Photoshop CC - 19.1.4 release
I am using the function to "Open In" at the top of the navigation bar when I export to Photoshop, I'm not saving it beforehand, just sending it directly over.
EDIT/ADD: The new document using pixels seems to send over just fine and doesn't do the weird compression thing with the 300dpi versions do. What does that mean?
Hi Suzy.
Sue.
Thank you so much for the information and thank you for getting back to me so quickly! I look forward to the update and will use the work around for now.
Thank you again.
~ Suzy
Suzy.
You're welcome.
Sorry about the hassle (worry).
Sue.
