1 Reply Latest reply on Jun 7, 2018 7:16 AM by stewarts16448458
    JSON-LD As a Data Layer in Launch
    christophers35608510
      Has anyone thought about using JSON-LD for the data layer in Launch? We are thinking it would combine all our SEO and page information for subsequent analytics calls.
        • 1. Re: JSON-LD As a Data Layer in Launch
          stewarts16448458 Level 4
          I thought about it for a day or two.  It seemed like a really good idea until I really started digging into it.
          I ran into a couple of issues.
          1) JSON-LD (using the Schema.org schemas) is a solution designed around SEO (and Google, for the most part).  The format of your JSON-LD snippets will always be chasing Google's preferred structure for communicating any given context.  This means that you are aiming at a moving target (slowly moving, but still...).  Also, when you try to layer the additional information required for analytics and other mar-tech onto the ordained schemas, you step into the unknown and are left wondering if the additional attributes you've added will help or hinder in your SEO placement.
          2) JSON-LD (using the Schema.org schemas) is a solution that has only been thought through for the non-transaction parts of websites.  Since it is built for SEO, things like carts, wishlists, user registrations, user interactions aren't really spelled out for you on Schema.org. Again, I quickly found myself in uncharted territory.  If I were defining a data layer for a fully authenticated experience (i.e. online banking), I think Schema.org JSON-LD would be a very odd fit.
          Depending on the site you have and your needs for analytics, you might find a better fit than I did.  I just wanted to share my experience, FWIW.
          -Stew
