In the MAC OSX platform what are the options to identify the hardware where the files are processed?
For instance can the computer model be obtained through the javascript or ESTK?
I looked into the Photoshop environment variables and found the ones listed in the screenshot but nothing that identifies the hardware.
So a hack like this may work on both platforms.
#target photoshop
function getSystemCommandStdout (command)
var stdout = "";
var tempFile = new File (Folder.temp + "/temp.txt");
app.system (command + " > " + tempFile.fsName);
if (tempFile.open ("r"))
stdout = tempFile.read ();
tempFile.close ();
tempFile.remove ();
return stdout;
if ($.os.match(/windows/i)) var computerName = getSystemCommandStdout
...Copy link to clipboard
On Windows Photoshop System Info had a lot of information about ones hardware I would think the same type of information about you mac would be there. A script should be able to get that information. Other Hardware information most likely could obtained through your Mac OS features and commands.
Here is the beginning of my ]Windows Photoshop system Info.
Adobe Photoshop Version: 19.1.4 20180507.r.325 2018/05/07: 1170750 x64
Number of Launches: 357
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.17134.1
System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
Physical processor count: 12
Logical processor count: 24
Processor speed: 1995 MHz
Built-in memory: 40886 MB
Free memory: 2 MB
Memory available to Photoshop: 33152 MB
Memory used by Photoshop: 90 %
Alias Layers: Disabled.
Modifier Palette: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Huge
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Display: 2
Display Bounds: top=0, left=-1920, bottom=1080, right=0
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="NVIDIA Quadro 4000"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="10.18.13.5362"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
glgpu[0].GLRendererID=1757
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvwgf2umx.dll"
glgpu[0].GLDriverDate="20150722000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.1 CUDA"
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="Quadro 4000"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="353.62"
clgpu[0].CLBandwidth=7.48614e+10
clgpu[0].CLCompute=191.732
License Type: Subscription
Serial number: 90970090970448917498
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\jjmac\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 224.2G, 121.4G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
The app.systemInformation
call is what you are looking for.
It should provide info similar to what JJMack​ pasted above for OSX as well.​
app.systemInformation has a lot of interesting spec. I am trying to find an approach to identify the computer where the files are processed in a multi computer environment. My idea to have each computer write to a master cvs file the date, time number of files, file processing recipe and computer name/model/work station. The part that I can not figure out is how to identify the computer in the script. The app.systemInforamtion does not include the computer name.
You could try this script....
var tmpFile= File(Folder.temp + "/env.txt");
var cmd = "env > " + tmpFile.fsName;
app.system(cmd);
tmpFile.execute();
$.sleep(300);
tmpFile.remove();
It should open a text document with a list of enviroment variables
Only tested with Windows but should work with a Mac.
I think SuperMerlin​'s approach of writing the system command result to a text file might be the way to go.
If you just want the computer name though instead of all the environment variables you could use "scutil --get ComputerName" (in OSX).
Wrapping with a function to make it easier to use (example here) gives:
#target photoshop
var stdout = "";
tempFile.close ();
tempFile.remove ();
return stdout;
var computerName = getSystemCommandStdout("scutil --get ComputerName")
$.writeln(computerName)
I find no "scutil" command on my windows sysyem system may be on OSX but this work for me on windows
#target photoshop
var stdout = "";
tempFile.close ();
tempFile.remove ();
return stdout;
var computerName = getSystemCommandStdout("echo %COMPUTERNAME%");
$.writeln(computerName);
alert(computerName);
There is no need for all that code if you want an enviroment variable. I.E.
alert($.getenv("computername"));
Maybe some day I will learn JavaScript, osx, windows and photoshop however, I do not believe I can. My eyes cross whenever I see a regular expression.
The environment variable COMPUTERNAME exists in Windows, but I dont think the computer name is stored in any environment variables for OSX which is why I resorted to using scutil.
Thats why I suggested looking at all the variables, to see what is there.
#target photoshop
var stdout = "";
tempFile.close ();
tempFile.remove ();
return stdout;
if ($.os.match(/windows/i)) var computerName = getSystemCommandStdout("echo %COMPUTERNAME%");
else var computerName = getSystemCommandStdout("scutil --get ComputerName");
JJ Mack thanks! Your code work and returns the computer name in the mac platform.
A big thanks to all who contributed answer to the question.
You guys are awesome and and deserve to be mentioned because of your inclination to help and share knowledge.
Thank you sidpalas, the code works and returns the computer name.
I do not seem to have an "env" command on my windows machine but command set with no parameters will list all environment variables and one can get computername from that. Or you can use command "echo %COMPUTERNAME%"
var cmd = "set > " + tmpFile.fsName;
app.system(cmd);
tmpFile.execute();
$.sleep(300);
tmpFile.remove();
Thank you SuperMerlin. your code does work on a Mac,
