1 Reply Latest reply: Mar 10, 2008 10:56 AM by RGracia RSS
    Embedded font not appearing...
    RGracia Community Member
      If you run the following code provided you have a MC on stage with "ball" as instance name, the text appears as intended. However if you uncomment the line that embeds the font, it does not display at all. I have a Font symbol in my library with the same name as you see in the Text Format object "Verdana" and it's been checked for export for AS. Do I have to do something else? Is the order of the code affecting the result?
