1 Reply Latest reply on Jun 8, 2018 4:21 PM by igorg50721738
    Missing common-1.0.0.jar resulting in failing Android Builds
    CommonTime Support
      Android PhoneGap Builds are failing, from the log:
      FAILURE: Build failed with an exception.
      * What went wrong:
      A problem occurred configuring root project 'project'.
      > Could not find common.jar (android.arch.core:common:1.0.0).
        Searched in the following locations:
            https://jcenter.bintray.com/android/arch/core/common/1.0.0/common-1.0.0.jar
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 9.267 secs
      Command finished with error code 1: /project/gradlew cdvBuildDebug,-b,/project/build.gradle,-Dorg.gradle.daemon=true,-Pandroid.useDeprecatedNd k=true,-Dorg.gradle.daemon=false
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      Browsing to https://jcenter.bintray.com/android/arch/core/common/1.0.0/common-1.0.0.jar  redirects to the following which results in 404.
      https://repo.jfrog.org/artifactory/libs-release-bintray/android/arch/core/common/1.0.0/com mon-1.0.0.jar
      Looks like https://repo.jfrog.org/artifactory/libs-release-bintray/android/arch has gone missing?
