3 Replies Latest reply on Mar 19, 2008 1:29 PM by cmcskevin
    Debug problems
    cmcskevin
      When I make code changes, then save & click Debug or Play in FlexBuilder 3, the old version of the file still plays. I've cleared the browser cache to no avail. Has anyone experienced this? Is there a resolution?
      Thank you!
      Kevin
        • 1. Re: Debug problems
          Ansury Level 3
          Is the timestamp on the .swf file changing? Did you uncheck 'build automatically'?
          • 2. Re: Debug problems
            cmcskevin Level 1
            Hi Ansury,
            Thanks for responding.
            Yes, the timestamp is changing & it is building.
            I'm making obvious changes (like changing the background from black to red) and it is definitely not the new code though.
            I also changed the name of the main file in the src folder & then ran debug & it said that it couldn't find it in the debug folder. Shouldn't this happen automatically?
            Kevin
            • 3. Re: Debug problems
              cmcskevin Level 1
              Well, figured it out... subversion is the culprit (or us not knowing not to commit the debug-bin folder).
              Solution was to remove the project from the project list, delete the debug-bin folder & re-import the project.
              ... and then commit the code IGNORING the debug-bin folder!
              Hope this helps!
              Kevin
