6 Replies Latest reply on Jun 12, 2018 12:25 PM by MBA-2-rae
    How to set several artLayers as activeLayer at the same time?
    Curvin Level 1
      Now I know several artLayers,and I want to set them as activeLayer at the same time. But one artLayer can be set as activeLayer when I use app.activeDocument.activeLayer
      help~help~help~
        • 1. Re: How to set several artLayers as activeLayer at the same time?
          SuperMerlin Level 5
          activeLayer means ONE layer only!
          You can have several layers selected  but activeDocument.activeLayer will return details of the top most selected layer.
          • 2. Re: How to set several artLayers as activeLayer at the same time?
            Curvin Level 1
            SuperMerlin, Thank you for your reply!
            So we can not select several layers with code? Now I want to select several layers and merge them with code.
            • 3. Re: How to set several artLayers as activeLayer at the same time?
              Curvin Level 1
              As we all know, we can select several layers in the PS panel, but can we select several layers with code?
              And now I have gotten several layers .
              • 4. Re: How to set several artLayers as activeLayer at the same time?
                SuperMerlin Level 5
                You can select layers by Index , Id or by Name
                Or select all layers.
                Here are some functions that will let you do all the options including the merge.
                function selectLayerByIndex(index,add){
                var ref = new ActionReference();
                ref.putIndex(charIDToTypeID("Lyr "), index);
                var desc = new ActionDescriptor();
                desc.putReference(charIDToTypeID("null"), ref );
                if(add) desc.putEnumerated( stringIDToTypeID( "selectionModifier" ), stringIDToTypeID( "selectionModifierType" ), stringIDToTypeID( "addToSelection" ) );
                desc.putBoolean( charIDToTypeID( "MkVs" ), false );
                try{
                executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
                }catch(e){}
                function selectLayerById(id,add){
                ref.putIdentifier(charIDToTypeID("Lyr "), id);
                try{
                }catch(e){}
                function selectLayerByName(lyrName,add){
                add = undefined ? add = false:add
                ref.putName( charIDToTypeID( "Lyr " ), lyrName);
                desc.putReference( charIDToTypeID( "null" ), ref );
                executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
                function selectAllLayers() {
                var desc29 = new ActionDescriptor();
                var ref23 = new ActionReference();
                ref23.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                desc29.putReference( charIDToTypeID("null"), ref23 );
                executeAction( stringIDToTypeID("selectAllLayers"), desc29, DialogModes.NO );
                function mergeSelected() {
                try{
                executeAction( charIDToTypeID('Mrg2'), undefined, DialogModes.NO );
                }catch(e){}
                • 6. Re: How to set several artLayers as activeLayer at the same time?
                  MBA-2-rae Level 1
                  To select several layers with code I use this function, where the layer-IDs to be selected are stored in an array.
                  // layers to be selected (convert layer index to id:
                  id1 = getLayerId(activeDocument.layers[0])  //
                  id2 = getLayerId(activeDocument.layers[2])
                  // add more IDs if wanted
                  // store the layer-IDs into an array:
                  ary = [id1, id2]
                  // call the function
                  ret = selectLyr()
                  function selectLyr(lyrAry) {
                      // Description: Selects multiple layers
                      // Parameters: lyrAry (Array):  Contains the layer-IDs to be  selected
                      //  Return: boolean
                      if (lyrAry==undefined || lyrAry.constructor != Array )  return  false
                      var d = new ActionDescriptor();
                      var r = new ActionReference();
                      for (var i = 0; i < lyrAry.length; i++) {
                          r.putIdentifier( s2t( "layer" ), lyrAry[i] ) ;                         // Array of layer by ID
                      d.putReference( c2t( "null" ), r );
                      d.putEnumerated( s2t( "selectionModifier" ), s2t( "selectionModifierType" ), s2t(  "addToSelection") );
                      d.putBoolean( s2t( "makeVisible" ), true );
                      try {executeAction( s2t( "select" ), d, DialogModes.NO ); return true;}
                      catch(e) { return false }
                  function getLayerId(theLayer){
                      // by mike hale, via paul riggott;
                      // http://forums.adobe.com/message/1944754#1944754
                      app.activeDocument.activeLayer = theLayer;      // theLayer must be object
                      //Assumes activeDocument and activeLayer
                      r.putEnumerated(c2t("Lyr "), c2t("Ordn"), c2t("Trgt"));
                      d = executeActionGet(r);
                      return d.getInteger( c2t('LyrI') );
                  function c2t (s) {return app.charIDToTypeID(s)};
                  function s2t (s) {return app.stringIDToTypeID(s)};
