1 Reply Latest reply on Mar 17, 2008 2:44 PM by Newsgroup_User
    passing variable trouble
    yogi bear Level 1
      I have created a few arrays in a frame and am trying to pass a variable from the main array to choose a second array by passing a variable using a function after a button is clicked. I use this code to select the name of the new array:
      _root.m1[name].menuTwoID = homeMenu [0];
      from this array
      var homeMenu:Array = [["residential", "resMenu"], ["commercial", "comSubMenu"],.....
      That should produce a passed variable "resMenu" correct?
      It doesn't work later later in a new function when I put it into:
      _root.m2[name].main_text.text = menuTwoID[count-1][0];
      to get the names from the second array.
      If I put "resMenu" directly in the code (below) it works fine.
      _root.m1[name].menuTwoID = resMenu;
      Any ideas of what I'm doing wrong?
