• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Multiples Find Replaces with TRY CATCH errors in alert and console
Engaged ,
Jun 11, 2018 Jun 11, 2018
Hello!
In my script I find and replaces many words:
    replaceTextUsingFIND ("Article 1.", "Article ONE");
    replaceTextUsingFIND ("Article 2.", "Article TWO");
    replaceTextUsingFIND ("Article 3.", "Article THREE");
    replaceTextUsingFIND ("Article 4.", "Article FOUR");
    function replaceTextUsingFIND (input, output)
        app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
        app.findTextPreferences.findWhat = input;
        app.changeTextPreferences.changeTo = output;
        app.activeDocument.changeText();
This is my document:
In this case, the words Article 2. and Article 4. do not exist, then I need to get one alert per each word.
Is possible get the errors by alert and in the Javascript console? I try with try/catch but didn't work
Thanks for help me!
TOPICS
Scripting
Views
502
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 12, 2018 Jun 12, 2018
HI,
It is not possible to get errors as such, as no error is thrown if the find doesn't find anything, but you can catch that the find didn't find anything.
if you change the following line
to
var changedResults = app.activeDocument.changeText();
Then you can check the length of changedResults to see if anything was changed something like
if ( changedResults === 0)
     // I have put it into a alert, but you could put it to the console.
     alert ( "No results for " + i
Votes
Translate
Translate
Community Expert ,
HI,
to
     alert ( "No results for " + input);
Hpoe this helps
Malcolm
Votes
Translate
Translate
Report
Report
Engaged ,
Hi Malcolm!
I needed a change in the if conditional this === to ==
And now is working!
Here is the final Script:
Download files
        if ( changedResults == 0)  {
Thanks so much!
Votes
Translate
Translate
Report
Report
Community Expert ,
The === matches type as well as value, == just matches value.
I think this is because I missed out the .length inside the if, so it should look like this
if ( changedResults.length === 0)
but as long as it is working which is the main thing.
Regards
Malcolm
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
You true, I change and also is working.
Thanks a lot for your continuos help
    if ( changedResults.length === 0)  {
Votes
Translate
Translate
Report
Report
