Hi all,
If you used Google Maps widget from Adobe Muse to build your website, you may find the Google Maps not functioning as expected, in the website. Starting from June 11, 2018 there is a change in Google Maps licensing model. This change impacts the Google Maps widget that was distributed with Adobe Muse.
See this article Google maps widget issue in Adobe Muse for a workaround solution.
Preran
I used the original google maps widget on: www.zahnaerzte-am-marktplatz.de
and: www.susannewoerz.de
Since then I didn´t change to this API stuff and I´m still able to see the google maps with its functionality.
At least on mobile everything works fine.
When will this happen, that google maps won`t work anymore with that private key set ups?
Thanks in advance
Uwe
Normally,, it should stop working beginning with the 11th of June. But obviously Google decided to have a „grace period“. Additionally, it was told, that for a certain time „API free“ maps will be displayed in low resolution.
