Expand my Community achievements bar.
Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Target API error - created as Source: Adobe Target Classic
Avatar
Level 3
Hi! I'm using the new Adobe Target API method to create/edit/delete offers, but when creating an offer with it, it only shows as Adobe Target Classic, even if I'm using the new API.
The steps I've done:
  1. I’ve created an offer over the Adobe Target API, as instructed by the documentation.
2. On my console, everything looks alright:
3. On Adobe Target UI however, I can see the offer I’ve created, but it’s showing as Adobe Target Classic:
My fear is that at any moment, these offers can stop working, because they’re Classic.
How do I fix that? I need to see the updates I do as "Adobe Target" as it should be.
Also, it could be interesting to be able to change the USER/name on the Last Modified field, so we can know which developer actually made that change with the API.
Thanks a lot!
1 Accepted Solution
Avatar
Correct answer by
Employee
Hi Paula. You don't need to be concerned that it shows the offer as Target Classic. This is working as designed . Since you are using the API , to create the offer the UI displays it as such, meaning its not created in the target standard UI. Your offers will not stop working because of that.
If you would like to change the USER/name on the Last Modified field, so we can know which developer actually made that change with the API  then we recommend that you submit this as a  feature request through
https://forums.adobe.com/community/experience-cloud/marketing-cloud/target --> Submit an idea
This has the visibility of the product management team and would help get the feature prioritized if more users on the forum support the idea.
View solution in original post
1 Reply
Avatar
Correct answer by
Employee
