10 Replies Latest reply on Jun 13, 2018 8:56 AM by Jacob Bugge
    clipping mask problem
    romeozzzzzzz Level 1
      Hello
      I downloaded this frame from freepik.com and i want to make clipping mask with it to put an image inside this frame
      I tried too much but i can't
      what can i do ??
        • 1. Re: clipping mask problem
          Any help !!
          • 3. Re: clipping mask problem
            Thanks for your reply
            Is drawing clipping path is the only solution for this ?!
            is there any other solution without drawing ... for example by using pathfinder or anything else
            • 4. Re: clipping mask problem
              Ray Yorkshire Adobe Community Professional
              Perhaps make a copy of it, ungroup, delete the extremities,
              select all and use the ShapeBuilder tool, with a large gap detection set,( double click on the tool for options)
              Then if needed use the blob brush to fill any gaps.
              Next  Pathfinder > Unite
              And  use as a clipping mask on  the image
              Lastly paste the original on top ie
              Edit > Paste in Front
              • 5. Re: clipping mask problem
                I tried to do these steps accurately but failed .... there is no path in the middle of the fame where i make the clipping mask with it ... i need a solution without drawing
                Thanks for your reply bro
                • 6. Re: clipping mask problem
                  Doug A Roberts Adobe Community Professional & MVP
                  Why do you need a solution without drawing? Drawing a path would be the simplest and probably quickest way to do this.
                  • 7. Re: clipping mask problem
                    Because i'm not good enough in using pen tool to draw the path accurately
                    • 8. Re: clipping mask problem
                      John Mensinger Adobe Community Professional & MVP
                      So this is the perfect opportunity to improve. Look closely at tromboniator's example. This isn't that difficult to do if you just take your time, concentrate, and follow the pieces of the frame. (Lock the frame's layer and work on a layer above or below.)
                      You really only need to do one side and either the top or the bottom, then duplicate, flip and join them. Plus, you can make as many adjustments as it takes to get it right after drawing. I'd guess tromboniator did it in just a few minutes. You won't do it that quickly, but it won't take all day either.
                      • 9. Re: clipping mask problem
                        minimumsix9977 Level 1
                        Yep, think in terms of shapes. And the great thing is that everything is editable—you're not drawing with a permanent marker! So you can learn, tweak, fail, tweak, and get better. Sometimes there just isn't a magic button for everything, you know?
                        • 10. Re: clipping mask problem
                          Jacob Bugge MVP & Adobe Community Professional
                          Romeo,
                          One way to go about the suggestion from Peter without drawing is as follows, obviously working on a copy, leaving the original for the actual frame:
                          1) Select the whole structure of frame paths (or those that are to form the Clipping Mask), then Ctrl/Cmd+C+B to copy it behind the original frame structure, then (Ctrl/Cmd+G to Ungroup if Grouped and delete the unwanted bits and) Ctrl/Cmd+G to Group, then hide the original frame structure;
                          2) Object>Path>Offset Path by a positive amount sufficient to close all gaps within the frame path structure;
                          3) Pathfinder>Unite or Merge;
                          4) Object>Path>Offset Path by the same amount as in 2), only negative;
                          5) Select the path from 4) and the image to be clipped and Ctrl/Cmd+7;
                          6) Show the original frame structure hidden in 2).
                          This should give you the exact shape desired.
                          Edit: I started on this post before posts #8&9 were, well, posted.
