• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Font Size in the Local Files Panel, Can I add a Date Created Column
New Here ,
Jun 12, 2018 Jun 12, 2018
I'm using Dreamweaver 18.2, build 10165, on Mac OS 10.13.5
I need to change the size of the type in the Local Files Panel, and I would like to add a column to that panel, next to the Date Modified column that shows the creation date of all my files.  Is it possible to do either of those things?
Bob Rosenberry
[private/irrelevant info removed by mod]
Views
334
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 13, 2018 Jun 13, 2018
I guess nobody read your question closely.
1) UI font size is not adjustable in DW.  If you need bigger text on a Hi-res display, go into your system's display settings and adjust as needed.
2) Creation date is not a column option in DW.  Use your system's file manager instead.
Votes
Translate
Translate
Community Expert ,
Go to Site > Manage Sites and choose the site that you are working on. Click File View Columns and show/hide as wanted.
To change the size of the columns, hover over the bar at the end of the column header and drag to the desired size
Wappler, the only real Dreamweaver alternative.
Votes
Translate
Translate
Report
Report
Community Expert ,
To add to Ben's answer, you can also right click in the Files window, to the right of the "Local Files" heading in his second screen capture to access a dropdown menu of the items shown in his first screen capture...
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
Votes
Translate
Translate
Report
Report
