5 Replies Latest reply on Jun 18, 2018 12:25 AM by shivak41694392
    Subscription SOAP
    shivak41694392 Level 1
      Hi ,
      I am trying to trigger a subscription service using SOAP.
      I have nms:subscription WSDL and I am using subscribe method ,however it seems to be not working.
      I wanted to know if any one tried this.
      below is the request for Subscribe:
      <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:urn="urn:nms:subscription">
         <soapenv:Header/>
         <soapenv:Body>
            <urn:Subscribe>
               <urn:sessiontoken>___02A7C516-98AB-41E4-978D-3382796E3FCD</urn:sessiontoken>
               <urn:strServiceName>SMS</urn:strServiceName>
               <urn:elemRecipient>
                  email="shiva.k@b.com.au"
               </urn:elemRecipient>
               <urn:bCreate></urn:bCreate>
            </urn:Subscribe>
         </soapenv:Body>
      </soapenv:Envelope>
      regards
      Shiva
        • 1. Re: Subscription SOAP
          Vipul Raghav Adobe Employee
          Hi Shiva,
          Your SOAP XML should be something like this
             <soapenv:Header/>
             <soapenv:Body>
                <urn:Subscribe>
                   <urn:elemRecipient>
                         <recipient _key="email" emailFormat="2" email= "shiva.k@b.com.au" firstName="Shiva" lastName="K">
                               <location zipCode="2067"/>
                          </recipient>
                </urn:Subscribe>
             </soapenv:Body>
          </soapenv:Envelope>
          Please refer to the official documentation to understand more about it Business oriented APIs
          Regards,
          Vipul
          • 2. Re: Subscription SOAP
            Hi Vipul,
            Thanks for the prompt response .
            I am passing in :
               <soapenv:Header/>
               <soapenv:Body>
                  <urn:Subscribe>
                     <urn:sessiontoken>___DA3E97AF-F20A-4747-B847-B26565A111AA</urn:sessiontoken>
                     <urn:strServiceName>2</urn:strServiceName>
                     <urn:elemRecipient>
                            </recipient>
                  </urn:Subscribe>
               </soapenv:Body>
            </soapenv:Envelope>
            I am getting the below error :
            <SOAP-ENV:Envelope xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
               <SOAP-ENV:Body>
                  <SOAP-ENV:Fault>
                     <faultcode>SOAP-ENV:Server</faultcode>
                     <faultstring xsi:type="xsd:string">SOP-330011 Error while executing the method 'Subscribe' of service 'nms:subscription'.</faultstring>
                     <detail xsi:type="xsd:string">NMS-470003 Impossible to update. Creation of new recipient profile is not allowed.</detail>
                  </SOAP-ENV:Fault>
               </SOAP-ENV:Body>
            </SOAP-ENV:Envelope>
            • 3. Re: Subscription SOAP
              deepikas18262429 Adobe Employee
              Hi Shiva,
              The Session token you are using was generate through an Admin Operator?
              Is there any error that you are getting in Web logs.
              Thanks & Regards,
              Deepika
              • 4. Re: Subscription SOAP
                Hi Shiva,
                You have not specified a value for <urn:bCreate> tag. So it will default to false.
                it means that the recipient entity you are feedign into the subscription api call, if there is no corresponding recipient found inside the database, it will not create it and hence there will be no subscription.
                I'll suggest passing in true in such a scenario.
                Regards,Vipul
                • 5. Re: Subscription SOAP
                  Thanks Vipul,
                  I got it working  by adding true for create and
                  under servicename I had to pass the internal name of Services and Subscription.
                  I have also tried this for SMS and it worked.
                  Here is the request :
                     <soapenv:Header/>
                     <soapenv:Body>
                        <urn:Subscribe>
                           <urn:sessiontoken>___F289899C-E857-4B99-999C-47D87EBC2DEC</urn:sessiontoken>
                           <urn:strServiceName>newsletter</urn:strServiceName>
                           <urn:elemRecipient>
                                                         <recipient _key="email" emailFormat="2" email=" shiva.k@b.com.au " firstName="Shiva" lastName="K" >
                                  </recipient>
                           <urn:bCreate>True</urn:bCreate>
                        </urn:Subscribe>
                     </soapenv:Body>
                  </soapenv:Envelope>
