8 Replies Latest reply on Mar 14, 2008 1:25 PM by Oliver Goldman
    Searching a root directory
    RobbieDL Level 1
      Can the getDirectoryListing or getDirectoryListingAsync work with a root directory? I'm working on a little project to detect the input of USB devices. I'm trying to read the contents of the USB device (in this current case it's native path is E:/), but neither getDirectoryListing or getDirectoryListingAsync seem to read the contents.
      Is there anyway to get the contents of a root directory? I'm using Javascript.
      Appreciate any feedback. Cheers.
        • 1. Re: Searching a root directory
          Oliver Goldman Adobe Employee
          Yes, you should be able to enumerate a directory such as e:\. Can you provide a small code sample illustrating the problem?
          thanks,
          Oliver Goldman | Adobe AIR Engineering
          • 2. Searching a root directory
            RobbieDL Level 1
            Thanks for getting back to me, Oliver.
            Here's a little snippet of code from what I've got so far.
            var list = usbDrive.getDirectoryListing();
            dirList = [];
            for (i = 0; i < list.length; i++)
            dirList.push(list .nativePath);
            "usbDrive" is a global variable that contains the native path to the root directory I'm looking to get the directory listing for, which is currently E:/.
            If I change usbDrive.getDirectoryListing() to another directory, such as My Documents, it works just fine. But doesn't seem to work here.
            • 3. Re: Searching a root directory
              The getDirectoryListing() call will return an Array, not a File. You probably intended something along the lines of "list .nativePath" inside the for loop?
              • 4. Re: Searching a root directory
                Ah, interesting--apparently the array subscript notation is getting clobbered by the forum system. So that'd be "list [ 0 ] . nativePath". (Let's hope that comes through with square brackets intact.)
                Anway, this works in our testing. How are you initializing usbDrive?
                • 5. Re: Searching a root directory
                  RobbieDL Level 1
                  I initially have two functions; one that grabs the root directories when the application is first ran and stores them in an array, and a second then runs every 5 seconds and grabs the root directories and stores them in array again, but this time checking the length to see if it's different. If it is, this function gets run:
                  function checkNewRootDirs() {
                  tempArray = [];
                  for(i=0; i < newRootDirsArray.length; i++) {
                  inArray = true;
                  for(z=0; z < originalRootDirsArray.length; z++) {
                  if(newRootDirsArray == originalRootDirsArray[z]) {
                  inArray = false; }
                  tempArray
                  = inArray; } }
                  for(m=0; m < tempArray.length; m++) {
                  if(tempArray[m] == true) {
                  usbDrive = newRootDirsArray[m]; } }
                  dirListed(); }
                  When alerted out, usbDrive does contain the corrent native path to the USB drive. dirListed then runs the code I posted above, but returns no results.
                  Thanks again Oliver for lending a hand, much appreciated.
                  • 6. Re: Searching a root directory
                    So try a simpler app and see what happens. Two lines will do:
                    usbDrive = new File( "e:\" );
                    trace( usbDrive.getDirectoryList());
                    • 7. Re: Searching a root directory
                      RobbieDL Level 1
                      Ah yeah, that did the trick. Ran the code this code:
                      var usbDrive = new air.File("E:/");
                      alert(usbDrive);
                      and it alerted out the contents of E:/. I then went back to my original code, and did a quick IF statement to see if it was seeing how I originally was grabbing the root drive as a directory, and low and behold, it wasn't. But modifying the code above a little should do the trick.
                      Big thanks for the help Oliver, really do appreicate it. While I'm here, I do have a couple of general AIR questions. Firstly, I picked up the O'Reilly AIR handbook the other day, and was browsing through and noticed it mentioned a File.Upload function. But reading through the AIR reference guide, I don't see any mention of the File.Upload function. Has it been taken out since the book was written?
                      Secondly, I've had a quick look through, but couldn't see anything. Does AIR have a built in function that can grab the extension of a file?
                      Thanks again,
                      • 8. Re: Searching a root directory
                        There is a File.upload() method; it's inherited from the FileReference class.
                        To get a file's extension, use the File.extension property.
                        regards,
