Is there a way to make the 'Hand tool' the default tool when opening Acrobat. Currently, every time I open a document the select tool (I-beam) is selected by default and I have to change it to the hand tool for navigating the document. I use this 99% of the time when I open a document and it would be nice to have it as the default.
Hey
Try this:
When you relaunch, the Hand Tool should now be the default.
I followed your suggestions and that didn't work. Documents still open with the select tool as default. I've attached a short video to show the steps.
Hi
Sorry I didn't realise you were running an older version. I'll see what I can find for earlier versions and come back if I find a solution.
In the meantime, could I propose a workaround? Go back to the General preferences and check the option to Use single-key accelerators to access tools then all you need to do is press H on your keyboard to pick up the Hand Tool.
I know it's not the solution you're after, but it is at least faster than using the mouse—and hopefully a bit less frustrating.
That is better. I did some exploring and found there are a number of useful single-key accelerators I was unaware of that I will use. Thanks.
