• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Searching a way for Animate to automatically replace each images with other ones
Contributor ,
Jun 15, 2018 Jun 15, 2018
When I import, from a psd file, multiple layers, the quality of each layer is really bad.
So, I open Adobe Photoshop, extract the images in a folder (png) and replace each one of them from Animate (see video).
Capturer 21 - Streamable
Is there a way to script it for making Adobe Animate automatically do that ? (like jsfl but if someone could help me with the script, it would be awesome)
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 15, 2018 Jun 15, 2018
No problem if you don't have Illustrator.
As suggested by Chen, you can try some importing approach and hopefully your images will be replaced.
Alternatively, here is a small script to replace bitmaps from a imported PSD file.
Preview:
Usage/considerations:
- Select the folder that directly contains the imported bitmaps and run the script;
- Photoshop appends numerical indexes to layers with the same names using dashes while Animate CC uses underscores. So if one outputs to "image-1", "image-2", the o
Votes
Translate
Translate
Community Expert ,
Hi.
This is possible.
But do you have Illustrator?
If you open your PSD in Illustrator and the import in Animate, I think you'll get much better results.
Votes
Translate
Translate
Report
Report
Contributor ,
Thanks for the answer. I don't have Illustrator. I could buy it but if you think it's possible with jsfl, maybe I could try before buying it ?
Votes
Translate
Translate
Report
Report
Enthusiast ,
I don't think it's possible to solve your problem with illustrations.
Questions about replacing pictures.
Instead of swapping pictures, you can replace them when you import them.
Import Pictures First
File---Import--Import to stage.
Hint looks like sequence, whether to import sequence, point OK.
When you find that the quality of the picture is too bad.
You use Potoshop to make new pictures., export sequences
The name of the new picture sequence is the same as the name of the old sequence.
New Layer.And then again
Select a new picture sequence.
You will then be prompted to replace the existing item. Select it.
This time your original layer picture is all replaced.
And then you delete the new layer,
Now, the picture in your layer is all new.
Of course, if the number of sequence pictures is not equal.
You need to delete 1-2 frames.
Votes
Translate
Translate
Report
Report
Enthusiast ,
In fact, it feels like you don't have to set the steps you should follow.
If you have used a bitmap, then the steps.
You should only draw lines in Potoshop.
After importing ANCC,
Using bitmaps to convert to vectors.
Turn the line into a vector line.Then smooth it.
Then fill the color on the ANCC.
And everything should be done in a graphic component or movie clip.
Of course, if the general animation, you should take the picture as a draft. Then redraw in ANCC. This is the step of the animation.
Votes
Translate
Translate
Report
Report
Community Expert ,
Preview:
- Photoshop appends numerical indexes to layers with the same names using dashes while Animate CC uses underscores. So if one outputs to "image-1", "image-2", the other outputs "image_1", "image_2". So, for these cases, the images won't be replaced.
Swap External Images JSFL script download:
Swap External Bitmaps.jsfl - Google Drive
JSFL code for reference only. Feel free to fix and/or optimize if needed:
var uri;
function importImages()
     var doc = fl.getDocumentDOM();
     var lib;
     var libFolder;
     if (!doc)
          return;
     lib = doc.library;
     libFolder = lib.getSelectedItems()[0].name;
     if (!libFolder)
          return;
     try
          var externalBitmaps = getExternalBitmaps();
          var path;
          var newName;
          if (!externalBitmaps)
               return;
          for (var i = 0, total = externalBitmaps.length; i < total; i++)
               var path = uri + "/" + externalBitmaps;
               var newName = externalBitmaps.replace(".png", "");
               doc.importFile(path, true, false, false);
               lib.selectItem(externalBitmaps);
               lib.renameItem(newName);
               lib.moveToFolder(libFolder, newName, true);
     catch(error)
          fl.trace(externalBitmaps);
          fl.trace(error);
          fl.trace("___________");
function getExternalBitmaps()
     uri = fl.browseForFolderURL("select", "Select the folder containing the PNGs.");
     return FLfile.listFolder(uri + "/*.png", "Images.");
importImages();
I hope this helps.
Regards,
JC
Votes
Translate
Translate
Report
Report
Contributor ,
Exactly that !!!
Thank you very much !
Votes
Translate
Translate
Report
Report
Community Expert ,
Jun 16, 2018 Jun 16, 2018
Excellent!
You're welcome!
Votes
Translate
Translate
Report
Report
Participant ,
Apr 11, 2023 Apr 11, 2023
How to import a PSD:
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
locked
Votes
Translate
Translate
Report
Report
