color profile not working in lightroom cc
We can't play guessing games here. A lot more detail is needed.
Hi Reyoneshotphoto,
We're really sorry for the hassle. Could you please let us know the exact version of Lightroom CC you are using now?
You may try calibrate the monitor profile back to defaults and check if that helps.
Regards,
Mohit
last vesion 7.4
calibre los monitores nada trabaja.
solo trabaja en la version 7.2 de lightroom
no se si he calibrado los monitores bien.. me pueden decir como hacerlo correctamente.. gracias
no se pueden ver los profile
You still are not explaining very clearly. But if you are using Classic 7.4, the profiles are in the Basic panel, directly underneath the histogram.
Hi Reyoneshotphoto,
Could you please let us know which Operating system you are on (Windows/Mac)? We will provide you the step by step guidance to calibrate the monitor profile.
Also, as mentioned by James Hess, we need some more information related to your issue so that we can guide you accordingly to fix this problem.
Regards,
Mohit
Hi Reyoneshophoto, we don't understand what you mean by "color profile". What exactly have you done and what is not working as you expect - for example, are you referring to the profiles that are selected at the top of the Basic panel, and if so, what happens when you click on one and why isn't it what you expect? The Calibration panel is an advanced panel that very few users use or need to use - what are you seeking to do with it?
Thank you. WHEN THE MINITORES CALIBER IS SUCTION PROBLEM. HE SPOKE COLOR PROFILE WHEN USE DTS OR COLOR CHECKER PASSPORT... Thank you
I have another problem with Adobe Premier... When I work Green Screen.El Ultra key preset filter does not work. they can inform me the forun of Adobe Premiere or is this... This is my version of adobe..
