Hey togehter,
i would like to create a 12-Month-Collage the existing Collage includes just 9 pics!
Has anyone an idea how can i solve my Problem?!
thanks
Hi sebastianmunich:
Are you saying that you are opening up a collage that someone else has created with 9 images, and you want to add 3 more to it?
You can add new images to an existing Photoshop file via drag and drop or File > Place. Hopefully, each of the original 9 images are on their own layers—you will either need to move and resize them (Edit > Free Transform is an easy way to scale) or add more canvas (Image > Canvas Size) to accommodate the new images.
~Barb
If BarbBinder comment wasn't the solution, would you mind posting a little information - If English isn't your native language feel free to write your post in your local language and Adobe forums have a neat function to translate it.
Unfortunately, it's very difficult to understand your problem making it even harder to help you with a solution!
Can you post a screenshot? You can make the 9 smaller and add 3 more... but I need a screenshot of the original 9 to really see what you are wanting.
Sounds like your using photoshop elements?
If so, which version?
If you have Photoshop it does no have a Photo Collage feature. However it is easyx to create Photo Collage templates and automatically populate them using four simple template rules and the scripts in my Photoshop Photo Collage Toolkit. Supports up to 53 images
Photoshop scripting is powerful and I believe this package demonstrates this here is a video showing a 5 image collage PSD template being populated with images
The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
There are fifteen scripts in this package they provide the following functions:
Danke für eure Hilfe.
Ich habe es mit Photoshop auf dem PC versucht und dann mit Photoshop Express auf dem Iphone. Express stellt ein Template mit 9 Bildern zur Verfügung. Gibt es auch ein Template oder hat jemand ein Template mit 12 Bildern?
I believe the collage feature on PS express is limited to a maximum of 9 images, meaning you won’t be able to 3 additional images to it (unfortunately)
If you could use the PC version, follow both BarbBinder and JJMack comments which will both work for you, the easiest being BarbBinder​
It’s really as simple as setting your page size, drag and dropping the images into it and resizing the images to fit (Free Transform)
Feel free to post back should you have any questions
Sebastian,
Keine Ahnung, aber ich glaube schon.
I would think that there would be a template on Express for creating a collage using 12 pictures.
Have you found one yet? If so we will try to find one for you.
Cheers from Duesseldorf!
Kenn.
Templates psd files are easy to create and modify to add additional images. Just expand the psd canvas size to house the additional images and add the image mapping requirements. For the templates I create that would require the addition or three additional Alpha channels that maps the three three images size location and shape.
There is a forum for photoshop express.
Photoshop cc is a different application than photoshop express.
I have a hunch you are working with Photoshop Elements where Photo Collage is an option in the Create a drop-down menu. If that is the case, view this short video: Create a photo collage in Photoshop Elements 11
(EDIT). One more suggestion: If you are using Elements, it would be wise to direct your inquires to: photoshop elements forum
