5 Replies Latest reply on Sep 4, 2018 4:14 AM by Adorobat
    Acrobat 2017 crashes immediately after opening
    timk20003630
      I've installed Acrobat and it closes immediately after opening. I've completely uninstalled the program , ran the acrobat cleanup wizard, downloaded from the website and re-installed with the same issue. I've also tried to reset the preferences but the folders did not exist to rename. Please advise.
      Thank you.
        • 1. Re: Acrobat 2017 crashes immediately after opening
          Adorobat Adobe Employee
          Hi Timk,
          As per the issue description mentioned above, Acrobat is crashing when trying to launch, is that correct?
          Try the troubleshooting steps given in the following help document:
          Acrobat or Reader fresh installation crashes on first launch
          If issue still persists, try the steps given in the following help documents:
          Troubleshoot Mac OS 10.x system errors, freezes | Adobe software
          Troubleshoot Windows system errors, freezes | Adobe software
          Also, let us know dot version of Acrobat and the operating system installed on the machine? You may refer to the steps given in this link on how to check the version: Identify the product and its version for Acrobat and Reader DC
          Let us know if you need any help.
          Shivam
          2 people found this helpful
          • 2. Re: Acrobat 2017 crashes immediately after opening
            helmuth97779303
            Same issue here, crash report attached.
            Already tried every step on troubleshooting instructions, nothing works.
            Date/Time:       2018-06-19 15:58:31 +0200
            OS Version:      Mac OS X 10.13.4 (Build 17E199)
            Architecture:    x86_64h
            Report Version:  26
            Data Source:     Stackshots
            Command:         AdobeAcrobat
            Path:            /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
            Identifier:      com.adobe.Acrobat.Pro
            Version:         18.011.20040 (18.011.20040)
            Parent:          launchd [1]
            PID:             954
            Event:           hang
            Duration:        1.10s (process was unresponsive for 29 seconds before sampling)
            Steps:           11 (100ms sampling interval)
            Hardware model:  iMac18,3
            Active cpus:     8
            Time Awake Since Boot: 270s
            Fan speed:       1201 rpm
            Timeline format: stacks are sorted chronologically
            Use -i and -heavy to re-report with count sorting
            • 3. Re: Acrobat 2017 crashes immediately after opening
              Hi Helmuth,
              Sorry for the delay in response.
              Could you try updating Acrobat to the latest patch using "Check for updates" option under "Help" menu, reboot the machine after installing update and try again. You may also download updates from here: Adobe software and product updates
              Could you confirm if you have tried the troubleshooting steps given in the following link:
              Also, let us know if Acrobat crashes when launching an application or when opening a pdf file?
              Shivam
              • 4. Re: Acrobat 2017 crashes immediately after opening
                helmuth97779303 Level 1
                Tried all troubleshooting you posted.
                Keeps being unusable.
                Application crashes when opening a pdf:
                Date/Time:       2018-09-03 20:14:45 +0200
                OS Version:      Mac OS X 10.13.6 (Build 17G65)
                Report Version:  26
                Version:         18.011.20058 (18.011.20058)
                Parent:          launchd [1]
                PID:             14927
                Event:           hang
                Duration:        1.00s (process was unresponsive for 19 seconds before sampling)
                Steps:           10 (100ms sampling interval)
                Active cpus:     8
                Time Awake Since Boot: 350000s
                Fan speed:       1196 rpm
                Heaviest stack for the main thread of the target process:
                  10  start + 1 (libdyld.dylib + 4117) [0x7fff5384a015]
                  10  main + 86 (AdobeAcrobat + 3911) [0x10d566f47]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 29278) [0x10dd8e25e]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 35385) [0x10dd8fa39]
                  10  -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885]
                  10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34]
                  10  _DPSNextEvent + 2788 (AppKit + 269618) [0x7fff28fa8d32]
                  10  AEProcessAppleEvent + 55 (HIToolbox + 259232) [0x7fff2ad074a0]
                  10  aeProcessAppleEvent + 383 (AE + 38245) [0x7fff2cb0b565]
                  10  dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 41 (AE + 38519) [0x7fff2cb0b677]
                  10  aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 1788 (AE + 40400) [0x7fff2cb0bdd0]
                  10  _NSAppleEventManagerGenericHandler + 102 (Foundation + 300434) [0x7fff2db32592]
                  10  -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 287 (Foundation + 300820) [0x7fff2db32714]
                  10  -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 766 (AppKit + 288565) [0x7fff28fad735]
                  10  -[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:] + 235 (AppKit + 2358604) [0x7fff291a6d4c]
                  10  __69-[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:]_block_invoke + 891 (AppKit + 2360049) [0x7fff291a72f1]
                  10  -[NSApplication(NSAppleEventHandling) _openURLs:withCompletionHandler:] + 1026 (AppKit + 4613711) [0x7fff293cd64f]
                  10  withWindowOrderingObserverHeuristic + 479 (AppKit + 4614788) [0x7fff293cda84]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 39100) [0x10dd908bc]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 568618) [0x10de11d2a]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 14639669) [0x10eb7d235]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 571136) [0x10de12700]
                  10  ??? (<99007E2C-7C7E-301A-8EB7-2D07F8BC2553> + 266438) [0x11a9700c6]
                  10  ??? (<78EC052E-D928-3914-A227-AEA4F5631144> + 114511) [0x119ebcf4f]
                  10  ??? (<E0F67CDC-FECC-32D4-9348-979BAA1E9574> + 3496023) [0x1218d7857]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 4292188) [0x11820ae5c]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1322716) [0x117f35edc]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 574688) [0x10de134e0]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 577130) [0x10de13e6a]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 579028) [0x10de145d4]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 579508) [0x10de147b4]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 23542190) [0x10f3fa9ae]
                  10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 738099) [0x10de3b333]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2378251) [0x118037a0b]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2329626) [0x11802bc1a]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2327452) [0x11802b39c]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2325571) [0x11802ac43]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1714449) [0x117f95911]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1772296) [0x117fa3b08]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1772034) [0x117fa3a02]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1769668) [0x117fa30c4]
                  10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 838310) [0x117ebfaa6]
                  10  -[NSHost address] + 37 (CFNetwork + 1512687) [0x7fff2aa854ef]
                  10  -[NSHost blockingResolveUntil:] + 155 (CFNetwork + 633591) [0x7fff2a9aeaf7]
                  10  _dispatch_semaphore_wait_slow + 101 (libdispatch.dylib + 39289) [0x7fff53818979]
                  10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff53991246]
                *10  semaphore_wait_continue + 0 (kernel + 596880) [0xffffff8000291b90]
                Process:         AdobeAcrobat (Acrobat Pro DC) [14927]
                Parent:          launchd [1]
                UID:             502
                Task size:       224.47 MB
                CPU Time:        <0.001s (1970.0K cycles, 579.6K instructions, 3.40c/i)
                Note:            Unresponsive for 19 seconds before sampling
                Note:            3 idle work queue threads omitted
                  Thread 0x6a5d2d           DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                  <thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
                  10  start + 1 (libdyld.dylib + 4117) [0x7fff5384a015] 1-10
                    10  main + 86 (AdobeAcrobat + 3911) [0x10d566f47] 1-10
                      10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 29278) [0x10dd8e25e] 1-10
                        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 35385) [0x10dd8fa39] 1-10
                          10  -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 1-10
                            10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1-10
                              10  _DPSNextEvent + 2788 (AppKit + 269618) [0x7fff28fa8d32] 1-10
                                10  AEProcessAppleEvent + 55 (HIToolbox + 259232) [0x7fff2ad074a0] 1-10
                                  10  aeProcessAppleEvent + 383 (AE + 38245) [0x7fff2cb0b565] 1-10
                                    10  dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 41 (AE + 38519) [0x7fff2cb0b677] 1-10
                                      10  aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 1788 (AE + 40400) [0x7fff2cb0bdd0] 1-10
                                        10  _NSAppleEventManagerGenericHandler + 102 (Foundation + 300434) [0x7fff2db32592] 1-10
                                          10  -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 287 (Foundation + 300820) [0x7fff2db32714] 1-10
                                            10  -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 766 (AppKit + 288565) [0x7fff28fad735] 1-10
                                              10  -[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:] + 235 (AppKit + 2358604) [0x7fff291a6d4c] 1-10
                                                10  __69-[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:]_block_invoke + 891 (AppKit + 2360049) [0x7fff291a72f1] 1-10
                                                  10  -[NSApplication(NSAppleEventHandling) _openURLs:withCompletionHandler:] + 1026 (AppKit + 4613711) [0x7fff293cd64f] 1-10
                                                    10  withWindowOrderingObserverHeuristic + 479 (AppKit + 4614788) [0x7fff293cda84] 1-10
                                                      10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 39100) [0x10dd908bc] 1-10
                                                        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 568618) [0x10de11d2a] 1-10
                                                          10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 14639669) [0x10eb7d235] 1-10
                                                            10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 571136) [0x10de12700] 1-10
                                                              10  ??? (<99007E2C-7C7E-301A-8EB7-2D07F8BC2553> + 266438) [0x11a9700c6] 1-10
        10  ??? (<78EC052E-D928-3914-A227-AEA4F5631144> + 114511) [0x119ebcf4f] 1-10
        10  ??? (<E0F67CDC-FECC-32D4-9348-979BAA1E9574> + 3496023) [0x1218d7857] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 4292188) [0x11820ae5c] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1322716) [0x117f35edc] 1-10
        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 574688) [0x10de134e0] 1-10
        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 577130) [0x10de13e6a] 1-10
        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 579028) [0x10de145d4] 1-10
        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 579508) [0x10de147b4] 1-10
        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 23542190) [0x10f3fa9ae] 1-10
        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 738099) [0x10de3b333] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2378251) [0x118037a0b] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2329626) [0x11802bc1a] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2327452) [0x11802b39c] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 2325571) [0x11802ac43] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1714449) [0x117f95911] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1772296) [0x117fa3b08] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1772034) [0x117fa3a02] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 1769668) [0x117fa30c4] 1-10
        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 838310) [0x117ebfaa6] 1-10
        10  -[NSHost address] + 37 (CFNetwork + 1512687) [0x7fff2aa854ef] 1-10
        10  -[NSHost blockingResolveUntil:] + 155 (CFNetwork + 633591) [0x7fff2a9aeaf7] 1-10
        10  _dispatch_semaphore_wait_slow + 101 (libdispatch.dylib + 39289) [0x7fff53818979] 1-10
        10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff53991246] 1-10
        *10  semaphore_wait_continue + 0 (kernel + 596880) [0xffffff8000291b90] 1-10
                  Thread 0x6a5d35           DispatchQueue 117         10 samples (1-10)         priority 37 (base 37)     cpu time <0.001s (1131.2K cycles, 357.4K instructions, 3.17c/i)
                  <thread QoS user initiated (requested user initiated), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
                  10  start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff53b61be9] 1-10
                    10  _pthread_wqthread + 1387 (libsystem_pthread.dylib + 12649) [0x7fff53b62169] 1-10
                      10  _dispatch_worker_thread3 + 101 (libdispatch.dylib + 14165) [0x7fff53812755] 1-10
                        10  _dispatch_root_queue_drain + 515 (libdispatch.dylib + 14761) [0x7fff538129a9] 1-10
                          10  _dispatch_async_redirect_invoke + 703 (libdispatch.dylib + 50995) [0x7fff5381b733] 1-10
                            10  _dispatch_continuation_pop + 472 (libdispatch.dylib + 85633) [0x7fff53823e81] 1-10
                              10  _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff53810db8] 1-10
                                10  __NSOQSchedule_f + 369 (Foundation + 223511) [0x7fff2db1f917] 1-10
                                  10  -[__NSOperationInternal _start:] + 778 (Foundation + 239854) [0x7fff2db238ee] 1-10
                                    10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 17307662) [0x10ee0880e] 1-10
                                      10  +[NSThread sleepForTimeInterval:] + 156 (Foundation + 849639) [0x7fff2dbb86e7] 1-10
                                        10  __semwait_signal + 10 (libsystem_kernel.dylib + 118146) [0x7fff5399ad82] 1-10
                  Thread 0x6a7695           DispatchQueue 754         10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user initiated, ipc override user initiated), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
                    10  _pthread_wqthread + 980 (libsystem_pthread.dylib + 12242) [0x7fff53b61fd2] 1-10
                      10  _dispatch_workloop_worker_thread + 880 (libdispatch.dylib + 109857) [0x7fff53829d21] 1-10
                        10  _dispatch_root_queue_drain_deferred_wlh + 332 (libdispatch.dylib + 93965) [0x7fff53825f0d] 1-10
                          10  _dispatch_queue_invoke + 373 (libdispatch.dylib + 37222) [0x7fff53818166] 1-10
                            10  _dispatch_queue_serial_drain + 635 (libdispatch.dylib + 90647) [0x7fff53825217] 1-10
                                10  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff538185fa] 1-10
                                  10  __18-[NSHost resolve:]_block_invoke + 366 (CFNetwork + 634158) [0x7fff2a9aed2e] 1-10
                                    10  -[NSHost __resolveWithFlags:resultArray:handler:] + 224 (CFNetwork + 1507318) [0x7fff2aa83ff6] 1-10
                                      10  getaddrinfo + 61 (libsystem_info.dylib + 35245) [0x7fff5393c9ad] 1-10
                                        10  _getaddrinfo_internal + 242 (libsystem_info.dylib + 167746) [0x7fff5395cf42] 1-10
                                          10  si_addrinfo + 1938 (libsystem_info.dylib + 37202) [0x7fff5393d152] 1-10
                                            10  search_addrinfo + 306 (libsystem_info.dylib + 61330) [0x7fff53942f92] 1-10
                                              10  mdns_addrinfo + 1197 (libsystem_info.dylib + 62621) [0x7fff5394349d] 1-10
                                                10  kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff5399bbea] 1-10
                                                 *10  ??? (kernel + 5263408) [0xffffff8000705030] 1-10
                  Thread 0x6a5d63           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
                  10  thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff53b61bf9] 1-10
                    10  _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff53b6250d] 1-10
                      10  _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff53b62661] 1-10
                        10  ??? (<ECB4421C-9DE6-3940-BA7B-CBC5A582784D> + 3781653) [0x10da63415] 1-10
                          10  ??? (<ECB4421C-9DE6-3940-BA7B-CBC5A582784D> + 52845) [0x10d6d4e6d] 1-10
                            10  ??? (<ECB4421C-9DE6-3940-BA7B-CBC5A582784D> + 53040) [0x10d6d4f30] 1-10
                              10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff5399aa16] 1-10
                               *10  psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 1-10
                  Thread 0x6a5d64           10 samples (1-10)         priority 31 (base 31)
                  Thread 0x6a5d65           10 samples (1-10)         priority 31 (base 31)
                  Thread 0x6a5d78           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)     cpu time <0.001s (360.1K cycles, 91.0K instructions, 3.96c/i)
                        10  _NSEventThread + 184 (AppKit + 1568708) [0x7fff290e5fc4] 1-10
                          10  CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1-10
                            10  __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1-10
                              10  __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1-10
                                10  mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1-10
                                 *10  ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1-10
                  Thread 0x6a5f93           10 samples (1-10)         priority 31 (base 31)
                        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4614356) [0x10e1ed8d4] 1-10
                          10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4555602) [0x10e1df352] 1-10
                            10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 18049855) [0x10eebdb3f] 1-10
                              10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4573425) [0x10e1e38f1] 1-10
                                10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4636315) [0x10e1f2e9b] 1-10
                  Thread 0x6a5f95           10 samples (1-10)         priority 31 (base 31)
                  <process unclamped, process received importance donation from WindowServer [214], IO tier 0>
                        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 26213884) [0x10f686dfc] 1-10
                  Thread 0x6a5f99           10 samples (1-10)         priority 31 (base 31)     cpu time <0.001s (98.0K cycles, 19.9K instructions, 4.94c/i)
                        10  __NSThread__start__ + 1197 (Foundation + 193016) [0x7fff2db181f8] 1-10
                          10  ??? (<D7288EE1-0DB3-3731-8A36-3CEB2DDE9824> + 104767) [0x11776093f] 1-10
                  Thread 0x6a5fcb           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
                          10  -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2375300) [0x7fff2ab57e84] 1-10
                  Thread 0x6a5fdf           10 samples (1-10)         priority 31 (base 31)
                        10  ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 1049145) [0x117d12239] 1-10
                          10  ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 595895) [0x117ca37b7] 1-10
                            10  ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 615786) [0x117ca856a] 1-10
                              10  ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 1052351) [0x117d12ebf] 1-10
                                10  ??? (<3FB068A4-9343-3185-870E-F922267BFA19> + 1058204) [0x117d1459c] 1-10
                  Thread 0x6a600b           10 samples (1-10)         priority 31 (base 31)
                            10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4599942) [0x10e1ea086] 1-10
                              10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 4558862) [0x10e1e000e] 1-10
                                10  read + 10 (libsystem_kernel.dylib + 123202) [0x7fff5399c142] 1-10
                                 *10  hndl_unix_scall64 + 22 (kernel + 125382) [0xffffff800021e9c6] 1-10
                                   *10  unix_syscall64 + 616 (kernel + 6306152) [0xffffff8000803968] 1-10
                                     *10  read_nocancel + 115 (kernel + 5532931) [0xffffff8000746d03] 1-10
                                       *10  ??? (kernel + 5533541) [0xffffff8000746f65] 1-10
                                         *10  soreceive + 5082 (kernel + 5735770) [0xffffff800077855a] 1-10
                                           *10  sbwait + 406 (kernel + 5772870) [0xffffff8000781646] 1-10
                                             *10  msleep + 98 (kernel + 5438898) [0xffffff800072fdb2] 1-10
                                               *10  ??? (kernel + 5437670) [0xffffff800072f8e6] 1-10
                                                 *10  lck_mtx_sleep + 126 (kernel + 505086) [0xffffff800027b4fe] 1-10
                                                   *10  thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 1-10
                                                     *10  ??? (kernel + 554618) [0xffffff800028767a] 1-10
                                                       *10  machine_switch_context + 205 (kernel + 1584605) [0xffffff8000382ddd] 1-10
                  Thread 0x6a6011           Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 46 (base 46)
                        10  __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff5399acf2] 1-10
                         *10  ??? (kernel + 5438272) [0xffffff800072fb40] 1-10
                  Thread 0x6a6042           10 samples (1-10)         priority 31 (base 31)
                        10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 27018295) [0x10f74b437] 1-10
                          10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 27026412) [0x10f74d3ec] 1-10
                            10  ??? (<E12DD39E-D322-37FE-9DB1-F5C6EED666EF> + 27027880) [0x10f74d9a8] 1-10
                  Thread 0x6a606f           10 samples (1-10)         priority 31 (base 31)
                        10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 5392045) [0x1183176ad] 1-10
                          10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 3213033) [0x1181036e9] 1-10
                            10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 3742731) [0x118184c0b] 1-10
                              10  ??? (<530D24AF-462E-3CD3-95AF-C8EF7C2533CF> + 3741733) [0x118184825] 1-10
                  Binary Images:
                           0x10d566000 -        0x10d566fff  com.adobe.Acrobat.Pro 18.011.20058 (18.011.20058) <C8E55D09-69DB-3088-BBCD-BC349D00F1A8>  /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/MacOS/AdobeAcrobat
                           0x10d6c8000 -                ???  ???                                               <ECB4421C-9DE6-3940-BA7B-CBC5A582784D>
                           0x10dd87000 -                ???  ???                                               <E12DD39E-D322-37FE-9DB1-F5C6EED666EF>
                           0x117747000 -                ???  ???                                               <D7288EE1-0DB3-3731-8A36-3CEB2DDE9824>
                           0x117c12000 -                ???  ???                                               <3FB068A4-9343-3185-870E-F922267BFA19>
                           0x117df3000 -                ???  ???                                               <530D24AF-462E-3CD3-95AF-C8EF7C2533CF>
                           0x119ea1000 -                ???  ???                                               <78EC052E-D928-3914-A227-AEA4F5631144>
                           0x11a92f000 -                ???  ???                                               <99007E2C-7C7E-301A-8EB7-2D07F8BC2553>
                           0x121582000 -                ???  ???                                               <E0F67CDC-FECC-32D4-9348-979BAA1E9574>
                        0x7fff28f67000 -     0x7fff29dc5fff  com.apple.AppKit 6.9 (1561.60.100)                <3C27CF6F-E640-3411-A87D-CCB2222CC754>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                        0x7fff2a914000 -     0x7fff2acaefff  com.apple.CFNetwork 902.1 (902.1)                 <76EB8CB6-BF59-3BDA-BF2B-F21B161611B9>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                        0x7fff2acc8000 -     0x7fff2afcdfff  com.apple.HIToolbox 2.1.1 (911.10)                <BF7F9C0E-C732-3FB2-9BBC-362888BDA57B>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                        0x7fff2b988000 -     0x7fff2be29fff  com.apple.CoreFoundation 6.9 (1454.90)            <E5D594BF-9142-3325-A62D-CF4AAF472642>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                        0x7fff2cb02000 -     0x7fff2cb76fff  com.apple.AE 735.1 (735.1)                        <08EBA184-20F7-3725-AEA6-C314448161C6>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                        0x7fff2dae9000 -     0x7fff2deaffff  com.apple.Foundation 6.9 (1454.90)                <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                        0x7fff5380f000 -     0x7fff53848fff  libdispatch.dylib (913.60.2)                      <232C69BD-022E-3AB9-8807-79F9FA7CB5EC>  /usr/lib/system/libdispatch.dylib
                        0x7fff53849000 -     0x7fff53866fff  libdyld.dylib (551.4)                             <81BF3A82-5719-3B54-ABA9-76C82D932CAC>  /usr/lib/system/libdyld.dylib
                        0x7fff53934000 -     0x7fff5397dfff  libsystem_info.dylib (517.30.1)                   <AB634A98-B8AA-3804-8436-38261FC8EC4D>  /usr/lib/system/libsystem_info.dylib
                        0x7fff5397e000 -     0x7fff539a4fff  libsystem_kernel.dylib (4570.71.2)                <F22B8D73-69D8-36D7-BF66-7F9AC70C08C2>  /usr/lib/system/libsystem_kernel.dylib
                        0x7fff53b5f000 -     0x7fff53b6afff  libsystem_pthread.dylib (301.50.1)                <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4>  /usr/lib/system/libsystem_pthread.dylib
                   *0xffffff7f82a20000 - 0xffffff7f82a2bfff  com.apple.kec.pthread 1.0 (1)                     <E64F7A49-CBF0-3251-9F02-3655E3B3DD31>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
                   *0xffffff8000200000 - 0xffffff80009fffff  kernel (4570.71.2)                                <1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F>  /System/Library/Kernels/kernel
                Process:         ACCFinderSync [329]
                Path:            /Applications/Utilities/Adobe Sync/*/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex/Contents/MacOS/ACCFinderSync
                Parent:          launchd [1]
                UID:             502
                Sudden Term:     Tracked (allows idle exit)
                Task size:       17.25 MB
                CPU Time:        <0.001s (426.5K cycles, 100.2K instructions, 4.26c/i)
                Process:         ACCFinderSync [14740]
                Parent:          launchd [1]
                UID:             502
                Task size:       32.11 MB
                CPU Time:        <0.001s (389.2K cycles, 90.2K instructions, 4.32c/i)
                Process:         accountsd [314]
                Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
                Parent:          launchd [1]
                UID:             502
                Task size:       53.15 MB
                Note:            1 idle work queue thread omitted
                  Thread 0xd57              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                    10  ??? (accountsd + 2602) [0x10bea3a2a] 1-10
                  Binary Images:
                           0x10bea3000 -        0x10bea3fff  accountsd (677.3.0.14)                 <34F8D127-6497-3DF1-8C4C-1F6C354AB66E>  /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
                Process:         AcroCEF [14929]
                Path:            /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AcroCEF/AcroCEF.app/Contents/MacOS/AcroCEF
                Parent:          AdobeAcrobat (Acrobat Pro DC) [14927]
                Responsible:     AdobeAcrobat (Acrobat Pro DC) [14927]
                UID:             502
                Task size:       153.75 MB
                CPU Time:        0.010s (23.8M cycles, 11.2M instructions, 2.13c/i)
                Process:         AcroCEF Helper [14930]
                Path:            /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AcroCEF Helper.app/Contents/MacOS/AcroCEF Helper
                Parent:          AcroCEF [14929]
                UID:             502
                Task size:       119.02 MB
                Process:         AcroCEF Helper [14946]
                UID:             502
                Task size:       102.54 MB
                Process:         adid [237]
                Path:            /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid
                Parent:          launchd [1]
                UID:             265
                Task size:       8136 KB
                  Thread 0x78d              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (adid + 903416) [0x102cd98f8] 1-10
                      10  CFRunLoopRun + 99 (CoreFoundation + 801763) [0x7fff2ba4bbe3] 1-10
                  Binary Images:
                           0x102bfd000 -        0x102d91fff  adid (4.19)                            <FC2CF85B-F9E9-302E-8FB0-1DEE4BA24650>  /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/adid
                Process:         Adobe CEF Helper [452]
                Path:            /Library/Application Support/Adobe/*/Adobe CEF Helper.app/Contents/MacOS/Adobe CEF Helper
                Parent:          Creative Cloud [394]
                Responsible:     Creative Cloud [394]
                UID:             502
                Task size:       62.96 MB
                Process:         Adobe CEF Helper [458]
                UID:             502
                Task size:       193.13 MB
                CPU Time:        <0.001s (3.1M cycles, 1031.6K instructions, 3.05c/i)
                Process:         Adobe Desktop Service [457]
                Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/MacOS/Adobe Desktop Service
                Parent:          launchd [1]
                UID:             502
                Task size:       416.02 MB
                CPU Time:        <0.001s (31.8K cycles, 4.2K instructions, 7.63c/i)
                Process:         Adobe Installer [585]
                Path:            /Library/Application Support/Adobe/*/Adobe Installer
                Parent:          com.adobe.acc.installer.v2 [545]
                Responsible:     com.adobe.acc.installer.v2 [545]
                UID:             0
                Task size:       11.41 MB
                  Thread 0x1f45             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
                  10  start + 52 (Adobe Installer + 5028) [0x1019fe3a4] 1-10
                    10  ??? (Adobe Installer + 20192) [0x101a01ee0] 1-10
                      10  ??? (Adobe Installer + 21204) [0x101a022d4] 1-10
                        10  OOBEUtils::OOBEEventsIntl::WaitforEvntIntl(long long) + 187 (Adobe Installer + 100043) [0x101a156cb] 1-10
                  Thread 0x1f4d             10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
                        10  listenerThread(void*) + 75 (Adobe Installer + 102363) [0x101a15fdb] 1-10
                                   *10  ??? (kernel + 2877244) [0xffffff80004be73c] 1-10
                                     *10  VNOP_READ + 106 (kernel + 2933994) [0xffffff80004cc4ea] 1-10
                                       *10  apfs_fifospec_read + 31 (apfs + 252656) [0xffffff7f81945af0] 1-10
                                         *10  fifo_read + 135 (kernel + 2972599) [0xffffff80004d5bb7] 1-10
                  Binary Images:
                           0x1019fd000 -        0x101a5afff  Adobe Installer                                <90A6FA82-6455-3756-AC28-3A4BAC2212C9>  /Library/Application Support/Adobe/*/Adobe Installer
                   *0xffffff7f81908000 - 0xffffff7f819e3fff  com.apple.filesystems.apfs 748.51.0 (748.51.0) <F5310D5D-825A-3114-86DA-6E7D2A21133A>  /System/Library/Extensions/apfs.kext/Contents/MacOS/apfs
                Process:         AdobeCRDaemon [447]
                Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/C ontents/MacOS/AdobeCRDaemon
                UID:             502
                Task size:       10.96 MB
                CPU Time:        0.001s (4.8M cycles, 3.9M instructions, 1.24c/i)
                Process:         AdobeCRDaemon [485]
                Path:            /Library/Application Support/Adobe/*/Adobe Desktop Service.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app /Contents/MacOS/AdobeCRDaemon
                Parent:          Adobe Desktop Service [457]
                Responsible:     Adobe Desktop Service [457]
                UID:             502
                Task size:       11.02 MB
                CPU Time:        <0.001s (3.7M cycles, 3.8M instructions, 0.96c/i)
                Process:         AdobeCRDaemon [510]
                Path:            /Applications/Utilities/Adobe Sync/*/Core Sync.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app/Co ntents/MacOS/AdobeCRDaemon
                Parent:          Core Sync [506]
                Responsible:     Core Sync [506]
                UID:             502
                Task size:       17.79 MB
                CPU Time:        <0.001s (3.6M cycles, 3.7M instructions, 0.97c/i)
                Process:         AdobeCRDaemon [14928]
                Path:            /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCRDaemon.app /Contents/MacOS/AdobeCRDaemon
                UID:             502
                Task size:       9412 KB
                CPU Time:        <0.001s (2.9M cycles, 3.7M instructions, 0.78c/i)
                Process:         AdobeIPCBroker [429]
                Path:            /Applications/Utilities/Adobe Application Manager/*/AdobeIPCBroker.app/Contents/MacOS/AdobeIPCBroker
                Parent:          launchd [1]
                UID:             502
                Task size:       25.15 MB
                CPU Time:        <0.001s (217.4K cycles, 64.3K instructions, 3.38c/i)
                Process:         AdobeResourceSynchronizer [14932]
                Path:            /Applications/Adobe Acrobat DC/Adobe Acrobat.app/Contents/Helpers/AdobeResourceSynchronizer.app/Contents/MacOS/AdobeResourceSy nchronizer
                UID:             502
                Task size:       18.89 MB
                Process:         AGMService [86]
                Path:            /Library/Application Support/Adobe/*/AGMService
                Parent:          launchd [1]
                UID:             0
                Task size:       17.13 MB
                  Thread 0x284              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  10  start + 52 (AGMService + 8308) [0x100002074] 1-10
                    10  ??? (AGMService + 9707) [0x1000025eb] 1-10
                      10  ??? (AGMService + 118692) [0x10001cfa4] 1-10
                        10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134654) [0x7fff2db09dfe] 1-10
                          10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134950) [0x7fff2db09f26] 1-10
                  Binary Images:
                           0x100000000 -        0x10024cfff  AGMService                             <42106898-5812-3B90-BF32-D1FE1C07C98B>  /Library/Application Support/Adobe/*/AGMService
                Process:         AirPlayUIAgent [390]
                Path:            /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
                Parent:          launchd [1]
                UID:             502
                Task size:       15 MB
                CPU Time:        <0.001s (308.8K cycles, 72.9K instructions, 4.24c/i)
                  Thread 0x10b9             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time <0.001s (153.4K cycles, 30.3K instructions, 5.06c/i)
                  <thread QoS user interactive (requested user interactive), process sudden termination clean, process unclamped, IO tier 0>
                    10  NSApplicationMain + 804 (AppKit + 23154) [0x7fff28f6ca72] 1-10
                          10  _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 1-10
                            10  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 1-10
                              10  ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 1-10
                                10  RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 1-10
                  Thread 0x10f7             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  Thread 0x68948f           10 samples (1-10)         priority 31 (base 31)
                  <process sudden termination clean, process unclamped, IO tier 0>
                *10  wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f82a23b83] 1-10
                  Binary Images:
                           0x106c80000 -        0x106c89fff  com.apple.AirPlayUIAgent 2.0 (366.76.2) <F93D4FC6-1F74-3EB0-8802-85A42A590A16>  /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent
                Process:         AirPlayXPCHelper [117]
                Path:            /usr/libexec/AirPlayXPCHelper
                Parent:          launchd [1]
                UID:             0
                Task size:       15.28 MB
                CPU Time:        <0.001s (183.5K cycles, 42.7K instructions, 4.30c/i)
                Note:            2 idle work queue threads omitted
                  Thread 0x3e9              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), IO tier 0>
                  10  _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff5381ccc0] 1-10
                    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff5399b022] 1-10
                  Thread 0x6a7702           10 samples (1-10)         priority 31 (base 31)
                  <IO tier 0>
                  Binary Images:
                           0x10d319000 -        0x10d31afff  AirPlayXPCHelper (366.76.2)        <4C695B3B-8257-3350-85AE-D88FB08FF5A2>  /usr/libexec/AirPlayXPCHelper
                Process:         airportd [162]
                Path:            /usr/libexec/airportd
                Parent:          launchd [1]
                UID:             0
                Task size:       20.16 MB
                  Thread 0x3e8              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from sharingd [389], IO tier 0>
                    10  ??? (airportd + 318747) [0x10e05ed1b] 1-10
                  Thread 0x480              DispatchQueue 83          10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default, ipc override default), process sudden termination clean, process unclamped, process received importance donation from sharingd [389], IO tier 0>
                                  10  ??? (airportd + 416478) [0x10e076ade] 1-10
                                    10  CFReadStreamRead + 382 (CoreFoundation + 510318) [0x7fff2ba0496e] 1-10
                                                   *10  spec_read + 667 (kernel + 2976283) [0xffffff80004d6a1b] 1-10
                                                     *10  cdev_read + 379 (IO80211Family + 450730) [0xffffff7f81ad40aa] 1-10
                  Thread 0x407              DispatchQueue 84          10 samples (1-10)         priority 31 (base 31)
                                  10  ??? (airportd + 417681) [0x10e076f91] 1-10
                  Thread 0x47f              DispatchQueue 85          10 samples (1-10)         priority 31 (base 31)
                                  10  ??? (airportd + 416952) [0x10e076cb8] 1-10
                  Thread 0x48b              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x10e011000 -        0x10e146fff  airportd (1361.7)                              <44A90813-5031-3F9E-BADC-1A0F8383050F>  /usr/libexec/airportd
                   *0xffffff7f81a66000 - 0xffffff7f81b16fff  com.apple.iokit.IO80211Family 12.0 (1200.12.2) <9CF530F9-ABD9-3A18-B611-42C5811D3FAF>  /System/Library/Extensions/IO80211Family.kext/Contents/MacOS/IO80211Family
                Process:         akd [236]
                Path:            /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
                Parent:          launchd [1]
                UID:             0
                Task size:       7096 KB
                  Thread 0x769              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (akd + 111269) [0x103ed32a5] 1-10
                  Binary Images:
                           0x103eb8000 -        0x103f65fff  akd (181.0.0.42)                       <7038EF23-D871-3575-B216-EF30AF3148DB>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
                Process:         akd [362]
                Parent:          launchd [1]
                UID:             502
                Task size:       18.37 MB
                  Thread 0xfef              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (akd + 111269) [0x10fcb12a5] 1-10
                  Thread 0x1267c0           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10fc96000 -        0x10fd43fff  akd (181.0.0.42)                       <7038EF23-D871-3575-B216-EF30AF3148DB>  /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
                Process:         AlertNotificationService [14326]
                Path:            /Applications/Google Chrome.app/Contents/Versions/68.0.3440.106/Google Chrome Framework.framework/Versions/A/XPCServices/AlertNotificationService.xpc/Contents/MacOS/Al ertNotificationService
                Parent:          launchd [1]
                Responsible:     Google Chrome (Chrome) [14319]
                UID:             502
                Task size:       9076 KB
                Process:         amfid [123]
                Path:            /usr/libexec/amfid
                Parent:          launchd [1]
                UID:             0
                Task size:       15.52 MB
                  Thread 0x2f9              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
                  Binary Images:
                           0x10bbaf000 -        0x10bbb5fff  amfid (270.70.1)                   <2935F22B-678C-3C31-A3A0-025DA73CA0C2>  /usr/libexec/amfid
                Process:         analyticsd [198]
                Path:            /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
                Parent:          launchd [1]
                UID:             263
                Task size:       13.23 MB
                  Thread 0x487              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (analyticsd + 237679) [0x1088d906f] 1-10
                  Thread 0x6a72fe           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                  Binary Images:
                           0x10889f000 -        0x108947fff  analyticsd (27.4)                      <19D56FFD-8618-3B31-9838-679108B6CAFA>  /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
                Process:         apfsd [208]
                Path:            /usr/libexec/apfsd
                Parent:          launchd [1]
                UID:             0
                Task size:       5316 KB
                  Thread 0x552              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                    10  ??? (apfsd + 17913) [0x10d9335f9] 1-10
                  Binary Images:
                           0x10d92f000 -        0x10d938fff  apfsd (748.77.8)                       <D7ECFD4A-CDF5-3F76-BCC4-EFBD3CC08C43>  /usr/libexec/apfsd
                Process:         APFSUserAgent [368]
                Path:            /System/Library/CoreServices/APFSUserAgent
                Parent:          launchd [1]
                UID:             502
                Task size:       5600 KB
                  Thread 0x1045             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10903a000 -        0x10903efff  APFSUserAgent (748.77.8)           <49679BB1-8024-3139-BEE4-51C17095E8E1>  /System/Library/CoreServices/APFSUserAgent
                Process:         apple.DevicePropertyReader [13371]
                Path:            /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Content s/MacOS/apple.DevicePropertyReader
                Parent:          launchd [1]
                Responsible:     PTPCamera [13369]
                UID:             502
                Task size:       10124 KB
                  Thread 0x5a12a2           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x100380000 -        0x100381fff  com.apple.DevicePropertyReader 1.0 (1) <6B4D5A99-1F15-3D35-9610-E86DB992E531>  /System/Library/Image Capture/Devices/PTPCamera.app/Contents/XPCServices/apple.DevicePropertyReader.xpc/Content s/MacOS/apple.DevicePropertyReader
                Process:         appleeventsd [64]
                Path:            /System/Library/CoreServices/appleeventsd
                Parent:          launchd [1]
                UID:             55
                Task size:       9260 KB
                  Thread 0x5ae              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), thread darwinbg, process darwinbg, IO tier 2>
                  10  <truncated backtrace> 1-10
                  Binary Images:
                           0x104510000 -        0x104510fff  appleeventsd (735.1)               <88F1B1E2-2576-3E4C-84EA-CA77C9958C01>  /System/Library/CoreServices/appleeventsd
                Process:         AppleSpell [597]
                Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
                Parent:          launchd [1]
                UID:             502
                Task size:       69.58 MB
                  Thread 0x202c             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (AppleSpell + 7064) [0x10aaa9b98] 1-10
                      10  -[NSSpellServer run] + 73 (Foundation + 2090637) [0x7fff2dce768d] 1-10
                  Binary Images:
                           0x10aaa8000 -        0x10abaafff  com.apple.AppleSpell 2.4 (430.2)       <724CCFE3-CF4C-39C4-8EE1-4126B2A532F7>  /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
                Process:         applessdstatistics [14620]
                Path:            /usr/libexec/applessdstatistics
                Parent:          launchd [1]
                UID:             0
                Task size:       4560 KB
                  Thread 0x685bfc           DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested utility), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
                    10  ??? (applessdstatistics + 5851) [0x1036176db] 1-10
                      10  _dispatch_group_wait_slow + 151 (libdispatch.dylib + 28265) [0x7fff53815e69] 1-10
                  Binary Images:
                           0x103616000 -        0x10364dfff  applessdstatistics (118.70.3)      <090263DD-A7A9-32D7-A5BD-89DE93AA9897>  /usr/libexec/applessdstatistics
                Process:         apsd [94]
                Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
                Parent:          launchd [1]
                UID:             0
                Task size:       45.79 MB
                  Thread 0x288              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (apsd + 532954) [0x10d4f01da] 1-10
                  Thread 0x9fd              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
                  Thread 0xa03              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x10d46e000 -        0x10d56bfff  apsd (625.1.2.1)                       <3D02BD05-5E7A-38CB-A02A-CC4BF2738997>  /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
                Process:         aslmanager [156]
                Path:            /usr/sbin/aslmanager
                Parent:          launchd [1]
                UID:             0
                Task size:       6236 KB
                  Thread 0x3ae              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, IO tier 3>
                  Binary Images:
                           0x10ae2d000 -        0x10ae36fff  aslmanager (356.70.1)              <194952A2-3DEC-3421-B419-31B84BBE7543>  /usr/sbin/aslmanager
                Process:         aslmanager [5131]
                Parent:          launchd [1]
                UID:             0
                Task size:       3820 KB
                  Thread 0x335572           10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 3>
                  Binary Images:
                           0x105bbd000 -        0x105bc6fff  aslmanager (356.70.1)              <194952A2-3DEC-3421-B419-31B84BBE7543>  /usr/sbin/aslmanager
                Process:         AssetCache [642]
                Path:            /usr/libexec/AssetCache/AssetCache
                Parent:          launchd [1]
                UID:             235
                Task size:       12.95 MB
                  Thread 0x3831             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (AssetCache + 9411) [0x10a76b4c3] 1-10
                      10  ??? (AssetCache + 96458) [0x10a7808ca] 1-10
                        10  ??? (AssetCache + 97282) [0x10a780c02] 1-10
                  Binary Images:
                           0x10a769000 -        0x10aad2fff  AssetCache (214)                       <036DE5D5-8F7C-391E-A42D-04E08423858F>  /usr/libexec/AssetCache/AssetCache
                Process:         AssetCacheLocatorService [6331]
                Path:            /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/Ass etCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
                Parent:          launchd [1]
                UID:             502
                Task size:       8580 KB
                  Thread 0x43486f           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 71 (AssetCacheLocatorService + 33045) [0x10aea2115] 1-10
                      10  -[AssetCacheLocatorService start] + 652 (AssetCacheLocatorService + 55904) [0x10aea7a60] 1-10
                  Thread 0x4348f9           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10ae9a000 -        0x10aed3fff  com.apple.AssetCacheLocatorService 82.1 (82.1) <1B6C8446-9169-39DF-86E8-087BC1B143B8>  /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/Ass etCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService
                Process:         assistant_service [1932]
                Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistan t_service
                Parent:          launchd [1]
                UID:             502
                Task size:       159.93 MB
                  Thread 0x34ee8            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (assistant_service + 6441) [0x1001ef929] 1-10
                  Thread 0x323dcf           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1001ee000 -        0x1001fbfff  assistant_service (1737.24.34.0.1)     <62E2432C-9F2E-3D49-B536-0DFF0BDCAD06>  /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistan t_service
                Process:         assistantd [365]
                Path:            /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistan td
                Parent:          launchd [1]
                UID:             502
                Task size:       40.89 MB
                  Thread 0x1034             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (assistantd + 39854) [0x100968bae] 1-10
                      10  ??? (assistantd + 41614) [0x10096928e] 1-10
                  Binary Images:
                           0x10095f000 -        0x100da4fff  assistantd (1737.24.34.0.1)            <B5858C15-54B8-3BE9-B1B8-9A9848A27D42>  /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistan td
                Process:         AudioComponentRegistrar [251]
                Path:            /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
                Parent:          launchd [1]
                UID:             0
                Task size:       8172 KB
                  Thread 0x85f              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (AudioComponentRegistrar + 6938) [0x10d475b1a] 1-10
                  Binary Images:
                           0x10d474000 -        0x10d475fff  AudioComponentRegistrar (975.4.21.23)  <271C6C79-7CDD-3129-B995-805877449D2B>  /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
                Process:         AudioComponentRegistrar [668]
                Parent:          launchd [1]
                UID:             502
                Task size:       9780 KB
                  Thread 0x43fd             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (AudioComponentRegistrar + 6938) [0x10bc10b1a] 1-10
                  Binary Images:
                           0x10bc0f000 -        0x10bc10fff  AudioComponentRegistrar (975.4.21.23)  <271C6C79-7CDD-3129-B995-805877449D2B>  /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
                Process:         authd [141]
                Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
                Parent:          launchd [1]
                UID:             0
                Task size:       13.95 MB
                  Thread 0x3bb              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
                  Thread 0x3bc              DispatchQueue 10          10 samples (1-10)         priority 4 (base 4)
                        10  _dispatch_root_queue_drain + 902 (libdispatch.dylib + 15148) [0x7fff53812b2c] 1-10
                              10  ??? (authd + 18417) [0x109b8f7f1] 1-10
                                10  au_sdev_read_aia + 528 (libbsm.0.dylib + 60396) [0x7fff51787bec] 1-10
                                  10  fgetc + 52 (libsystem_c.dylib + 246895) [0x7fff538d546f] 1-10
                                    10  __srget + 14 (libsystem_c.dylib + 273977) [0x7fff538dbe39] 1-10
                                      10  __srefill1 + 24 (libsystem_c.dylib + 273694) [0x7fff538dbd1e] 1-10
                                        10  __read_nocancel + 10 (libsystem_kernel.dylib + 117738) [0x7fff5399abea] 1-10
                                                       *10  ??? (kernel + 5069540) [0xffffff80006d5ae4] 1-10
                  Binary Images:
                           0x109b8b000 -        0x109baefff  com.apple.authd 1.0 (58286.70.7)   <A8257077-7DFA-3C3C-87AA-D9F5EB080BCC>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/M acOS/authd
                        0x7fff51779000 -     0x7fff51789fff  libbsm.0.dylib (39)                <6BC96A72-AFBE-34FD-91B1-748A530D8AE6>  /usr/lib/libbsm.0.dylib
                        0x7fff53899000 -     0x7fff53922fff  libsystem_c.dylib (1244.50.9)      <1187BFE8-4576-3247-8177-481554E1F9E7>  /usr/lib/system/libsystem_c.dylib
                Process:         autofsd [103]
                Path:            /usr/libexec/autofsd
                Parent:          launchd [1]
                UID:             0
                Task size:       5040 KB
                  Thread 0x4c6              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
                  Binary Images:
                           0x10ad2f000 -        0x10ad2ffff  autofsd (270.40.1)                 <43CA7756-70DB-3568-8AD1-5C5D63F41672>  /usr/libexec/autofsd
                Process:         avconferenced [2853]
                Path:            /usr/libexec/avconferenced
                Parent:          launchd [1]
                UID:             502
                Task size:       21.81 MB
                  Thread 0x7a140            DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                    10  ??? (avconferenced + 3829) [0x106d4bef5] 1-10
                  Binary Images:
                           0x106d4b000 -        0x106d4bfff  avconferenced (1020.31)                <693EF29B-A177-3237-8C04-5AFC844777D5>  /usr/libexec/avconferenced
                Process:         awacsd [196]
                Path:            /usr/libexec/awacsd
                Parent:          launchd [1]
                UID:             0
                Task size:       14.15 MB
                  Thread 0x6dc              DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
                  Thread 0x74b              Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 20 (base 20)
                  Thread 0xa69              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested utility), process sudden termination dirty, timers tier 3 (coalesced), IO tier 1>
                  Binary Images:
                           0x10a7cf000 -        0x10a847fff  awacsd (120)                           <82317BD3-321D-34BC-835F-393EBC355EC5>  /usr/libexec/awacsd
                Process:         awdd [197]
                Path:            /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
                Parent:          launchd [1]
                UID:             0
                Task size:       15.21 MB
                  Thread 0x482              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (awdd + 21935) [0x10d1dc5af] 1-10
                  Binary Images:
                           0x10d1d7000 -        0x10d2c7fff  awdd (930)                             <AEDE667C-65A5-395E-90F3-962889B773C7>  /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
                Process:         backgroundtaskmanagementagent [327]
                Path:            /System/Library/CoreServices/backgroundtaskmanagementagent
                Parent:          launchd [1]
                UID:             502
                Task size:       8800 KB
                  Thread 0xe0f              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10321d000 -        0x103235fff  backgroundtaskmanagementagent (71.21) <80C0ABBE-8D6B-39AA-8446-84E19FA003F0>  /System/Library/CoreServices/backgroundtaskmanagementagent
                Process:         backupd [14747]
                Path:            /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
                Parent:          launchd [1]
                UID:             0
                Task size:       25.20 MB
                  Thread 0x695a48           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 3>
                    10  ??? (backupd + 70623) [0x10ee673df] 1-10
                  Binary Images:
                           0x10ee56000 -        0x10eee2fff  backupd (283.8)                        <F8A3842C-A7C2-3198-B49B-D2512CE75868>  /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
                Process:         backupd-helper [88]
                Path:            /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
                Parent:          launchd [1]
                UID:             0
                Task size:       25.44 MB
                  Thread 0x29c              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                    10  ??? (backupd-helper + 11557) [0x104c0ed25] 1-10
                  Binary Images:
                           0x104c0c000 -        0x104c27fff  backupd-helper (283.8)                 <97CDFC29-4976-3F11-9C90-8A17D1B189C2>  /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
                Process:         bird [304]
                Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
                Parent:          launchd [1]
                UID:             502
                Task size:       25.55 MB
                  Thread 0xcf5              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Finder [300], process received importance donation from com.apple.appkit.xpc.openAndSavePanelService [14737], IO tier 0>
                    10  ??? (bird + 6065) [0x10048e7b1] 1-10
                  Binary Images:
                           0x10048d000 -        0x10048efff  bird (575.14)                          <2CA8458A-F28D-309A-BA2B-EF46C73CDDD8>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
                Process:         bluetoothd [114]
                Path:            /usr/sbin/bluetoothd
                Parent:          launchd [1]
                UID:             0
                Task size:       13.61 MB
                  Thread 0x295              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (bluetoothd + 764173) [0x10e1b790d] 1-10
                  Thread 0x6df              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x10e0fd000 -        0x10e35bfff  bluetoothd (6007.4.10)                 <18B938D6-3E4C-3943-A508-7EE6EAA70385>  /usr/sbin/bluetoothd
                Process:         bootinstalld [254]
                Path:            /usr/libexec/bootinstalld
                Parent:          launchd [1]
                UID:             0
                Task size:       10.37 MB
                  Thread 0x86c              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                    10  ??? (bootinstalld + 21859) [0x10f384563] 1-10
                  Binary Images:
                           0x10f37f000 -        0x10f385fff  bootinstalld (454.4)                   <20FE4EFF-9439-3B5C-99E5-44E6FAAE7510>  /usr/libexec/bootinstalld
                Process:         Calendar [14699]
                Path:            /Applications/Calendar.app/Contents/MacOS/Calendar
                Parent:          launchd [1]
                UID:             502
                Task size:       111.99 MB
                CPU Time:        <0.001s (235.0K cycles, 57.6K instructions, 4.08c/i)
                  Thread 0x68ae8f           DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time <0.001s (235.0K cycles, 57.6K instructions, 4.08c/i)
                    10  ??? (Calendar + 8179) [0x102003ff3] 1-10
                  Thread 0x68af53           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  Thread 0x6a1f14           Thread name "NetworkLoad" 10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, process unclamped, IO tier 0>
                        10  _runNetworkThread + 480 (GeoServices + 85274) [0x7fff4489cd1a] 1-10
                  Binary Images:
                           0x102002000 -        0x10229cfff  com.apple.iCal 10.0 (2195.4.3)              <41BE0747-F4AC-3600-9D65-355FCCA619C3>  /Applications/Calendar.app/Contents/MacOS/Calendar
                        0x7fff44888000 -     0x7fff451cafff  com.apple.GeoServices 1.0 (1363.24.8.15.58) <41BA60FF-66EB-342F-B14B-8CB2C9776745>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                Process:         CalendarAgent [361]
                Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
                Parent:          launchd [1]
                UID:             502
                Task size:       90.44 MB
                  Thread 0xfba              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CalendarAgent + 6112) [0x10efc37e0] 1-10
                  Thread 0x12fa             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Thread 0x64313e           Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10efc2000 -        0x10efc3fff  CalendarAgent (399.2.2)                     <08EC4AE2-F0BC-39C0-AF42-7EC1D50464FE>  /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
                Process:         CallHistoryPluginHelper [444]
                Path:            /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
                Parent:          launchd [1]
                UID:             502
                Task size:       22.17 MB
                  Thread 0x12f2             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CallHistoryPluginHelper + 5507) [0x10aa99583] 1-10
                  Binary Images:
                           0x10aa98000 -        0x10aa99fff  CallHistoryPluginHelper (823)          <F1F6B8F5-0836-36CC-8EE9-6C6A8FF9FAA1>  /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
                Process:         callservicesd [317]
                Path:            /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
                Parent:          launchd [1]
                UID:             502
                Task size:       38.60 MB
                  Thread 0xd91              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (callservicesd + 995987) [0x104e41293] 1-10
                      10  autoreleasepool<A>(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff4ebf7c68] 1-10
                        10  ??? (callservicesd + 996172) [0x104e4134c] 1-10
                  Binary Images:
                           0x104d4e000 -        0x104eb8fff  callservicesd (975.11.5)               <42834AA5-C905-3487-9904-FC5F8CF98E4C>  /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
                        0x7fff4ebf4000 -     0x7fff4ebf9fff  libswiftObjectiveC.dylib (900.8.49.1)  <DCF880C2-D021-36E6-86A1-63845D04E99E>  /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
                Process:         CalNCService [364]
                Path:            /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/C alNCService.xpc/Contents/MacOS/CalNCService
                Parent:          launchd [1]
                Responsible:     CalendarAgent [361]
                UID:             502
                Task size:       36.57 MB
                  Thread 0x1033             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 111 (CalNCService + 48854) [0x109c82ed6] 1-10
                      10  -[NSXPCListener resume] + 165 (Foundation + 485365) [0x7fff2db5f7f5] 1-10
                        10  xpc_main + 433 (libxpc.dylib + 63946) [0x7fff53ba39ca] 1-10
                          10  _xpc_objc_main + 536 (libxpc.dylib + 68939) [0x7fff53ba4d4b] 1-10
                  Binary Images:
                           0x109c77000 -        0x109c86fff  com.apple.CalendarNotification.CalNCService 1.0 (550.4.2) <3E78A650-4787-3F8A-AFB1-0EA606B84B5D>  /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/C alNCService.xpc/Contents/MacOS/CalNCService
                        0x7fff53b94000 -     0x7fff53bc1fff  libxpc.dylib (1205.70.9)                                  <0BC7AD67-671D-31D4-8B88-C317B8379598>  /usr/lib/system/libxpc.dylib
                Process:         captiveagent [6562]
                Path:            /usr/libexec/captiveagent
                Parent:          launchd [1]
                UID:             258
                Task size:       7420 KB
                  Thread 0x461a5e           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (captiveagent + 5136) [0x10d1c3410] 1-10
                  Thread 0x461a62           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Thread 0x461a71           Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10d1c2000 -        0x10d1c9fff  captiveagent (355.60.1)                <32DDFC7A-1CED-3E2C-883E-4DF3B6EA7730>  /usr/libexec/captiveagent
                Process:         cdpd [403]
                Path:            /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
                Parent:          launchd [1]
                UID:             502
                Task size:       12.08 MB
                  Thread 0x1132             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (cdpd + 5952) [0x1097d4740] 1-10
                  Binary Images:
                           0x1097d3000 -        0x1097d4fff  cdpd (164.1)                           <C6876219-23A3-3F02-B75D-CA73FDFE32B7>  /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
                Process:         cfprefsd [124]
                Path:            /usr/sbin/cfprefsd
                Parent:          launchd [1]
                UID:             0
                Task size:       5660 KB
                  Thread 0x2dd              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10a392000 -        0x10a392fff  cfprefsd (1454.90)                 <465DD400-0C15-3770-B007-869D397BCF6A>  /usr/sbin/cfprefsd
                Process:         cfprefsd [285]
                Parent:          launchd [1]
                UID:             502
                Task size:       11.09 MB
                  Thread 0xbec              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1002d5000 -        0x1002d5fff  cfprefsd (1454.90)                 <465DD400-0C15-3770-B007-869D397BCF6A>  /usr/sbin/cfprefsd
                Process:         cfprefsd [6558]
                Parent:          launchd [1]
                UID:             205
                Task size:       1728 KB
                  Thread 0x461988           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10c55d000 -        0x10c55dfff  cfprefsd (1454.90)                 <465DD400-0C15-3770-B007-869D397BCF6A>  /usr/sbin/cfprefsd
                Process:         ckkeyrolld [373]
                Path:            /usr/sbin/ckkeyrolld
                Parent:          launchd [1]
                UID:             502
                Task size:       15.23 MB
                  Thread 0x13db             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10eda6000 -        0x10edbcfff  ckkeyrolld (736.16)                <A5B47935-D097-3292-968D-0A62A928AEE0>  /usr/sbin/ckkeyrolld
                Process:         cloudd [359]
                Path:            /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
                Parent:          launchd [1]
                UID:             502
                Task size:       63.35 MB
                  Thread 0xfc2              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, process unclamped, process received importance donation from bird [304], process received importance donation from SafariBookmarksSyncAgent (SafariSupport) [408], IO tier 0>
                    10  ??? (cloudd + 10314) [0x10b28a84a] 1-10
                  Thread 0x11e4             Thread name "com.apple.CFStream.LegacyThread"       10 samples (1-10)         priority 31 (base 31)
                        10  _legacyStreamRunLoop_workThread + 261 (CoreFoundation + 1511541) [0x7fff2baf9075] 1-10
                  Thread 0x11ef             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 31 (base 31)
                  Thread 0x43486b           Thread name "cloudd.mmcs" 10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested utility), process sudden termination clean, process unclamped, process received importance donation from bird [304], process received importance donation from SafariBookmarksSyncAgent (SafariSupport) [408], IO tier 1>
                          10  -[CKDMMCSEngineContext _MMCSThread] + 416 (CloudKitDaemon + 1971205) [0x7fff3dad1405] 1-10
                  Binary Images:
                           0x10b288000 -        0x10b28dfff  cloudd (736.16)                                   <EE134C1B-707B-30FA-8D0B-565FD4C011E9>  /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
                        0x7fff3d8f0000 -     0x7fff3ddb0fff  com.apple.cloudkit.CloudKitDaemon 736.16 (736.16) <59E250E2-70D8-32F6-A1D3-C6C5EBD666CC>  /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Versions/A/CloudKitDaemon
                Process:         CloudKeychainProxy [291]
                Path:            /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bun dle/Contents/MacOS/CloudKeychainProxy
                Parent:          launchd [1]
                UID:             502
                Task size:       20.32 MB
                  Thread 0xc44              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CloudKeychainProxy + 38922) [0x10848480a] 1-10
                  Binary Images:
                           0x10847b000 -        0x10848efff  com.apple.security.cloudkeychainproxy3 10.0 (58286.70.7) <A3C3C76E-D578-3FB3-A126-51A675FD7E2C>  /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bun dle/Contents/MacOS/CloudKeychainProxy
                Process:         cloudpaird [392]
                Path:            /System/Library/CoreServices/cloudpaird
                Parent:          launchd [1]
                UID:             502
                Task size:       18.80 MB
                  Thread 0x1351             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (cloudpaird + 68712) [0x10266cc68] 1-10
                  Binary Images:
                           0x10265c000 -        0x102687fff  cloudpaird (6007.4.10)                 <38FB3A3D-043E-3AC7-889D-43236BBFB804>  /System/Library/CoreServices/cloudpaird
                Process:         cloudphotosd [410]
                Path:            /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
                Parent:          launchd [1]
                UID:             502
                Task size:       24.90 MB
                CPU Time:        <0.001s (288.3K cycles, 70.2K instructions, 4.11c/i)
                  Thread 0x135a             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)       cpu time <0.001s (165.2K cycles, 36.4K instructions, 4.55c/i)
                    10  main + 115 (cloudphotosd + 736114) [0x10f787b72] 1-10
                  Thread 0x18ee             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested user interactive), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                  Binary Images:
                           0x10f6d4000 -        0x10f7c3fff  com.apple.cloudphotosd 3.0 (3291.13.210) <D3E54417-40DD-352F-9057-0CAEC442717A>  /System/Library/CoreServices/cloudphotosd.app/Contents/MacOS/cloudphotosd
                Process:         CMFSyncAgent [552]
                Path:            /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent.app/Content s/MacOS/CMFSyncAgent
                Parent:          launchd [1]
                UID:             502
                Task size:       6700 KB
                  Thread 0x1b87             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CMFSyncAgent + 5409) [0x10e761521] 1-10
                  Binary Images:
                           0x10e760000 -        0x10e763fff  com.apple.cmfsyncagent 10.0 (1000)     <45D6871D-3AD5-3CBE-9561-F02403A28127>  /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent.app/Content s/MacOS/CMFSyncAgent
                Process:         colorsync.displayservices [239]
                Path:            /usr/libexec/colorsync.displayservices
                Parent:          launchd [1]
                UID:             0
                Task size:       6092 KB
                  Thread 0x7ee              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (colorsync.displayservices + 12335) [0x109d2502f] 1-10
                  Binary Images:
                           0x109d22000 -        0x109d26fff  colorsync.displayservices (3325)       <65354026-157C-3043-BEC7-D4A8742A9B5F>  /usr/libexec/colorsync.displayservices
                Process:         colorsync.useragent [546]
                Path:            /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
                Parent:          launchd [1]
                UID:             502
                Task size:       11.89 MB
                  Thread 0x1af6             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (colorsync.useragent + 10945) [0x10718bac1] 1-10
                  Binary Images:
                           0x107189000 -        0x10718cfff  colorsync.useragent (3325)             <3A0DE3FA-B902-3485-B4F6-E90B568BA422>  /System/Library/Frameworks/ColorSync.framework/Support/colorsync.useragent
                Process:         colorsyncd [248]
                Path:            /usr/libexec/colorsyncd
                Parent:          launchd [1]
                UID:             0
                Task size:       6056 KB
                  Thread 0x81c              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (colorsyncd + 7903) [0x10250dedf] 1-10
                  Binary Images:
                           0x10250c000 -        0x10250efff  colorsyncd (3325)                      <98DD19DF-929C-38BB-BA62-B2A178C203AF>  /usr/libexec/colorsyncd
                Process:         com.adobe.acc.installer.v2 [545]
                Path:            /Library/PrivilegedHelperTools/com.adobe.acc.installer.v2
                Parent:          launchd [1]
                UID:             0
                Task size:       13.38 MB
                  Thread 0x1ae4             DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  10  start + 52 (com.adobe.acc.installer.v2 + 4548) [0x1065591c4] 1-10
                    10  ??? (com.adobe.acc.installer.v2 + 15584) [0x10655bce0] 1-10
                      10  ??? (com.adobe.acc.installer.v2 + 5192) [0x106559448] 1-10
                  Binary Images:
                           0x106558000 -        0x106587fff  com.adobe.acc.installer.v2             <C0A78625-5590-3CC4-B0F7-A20C3E79386E>  /Library/PrivilegedHelperTools/com.adobe.acc.installer.v2
                Process:         com.apple.AccountPolicyHelper [269]
                Path:            /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPo licyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
                Parent:          launchd [1]
                UID:             0
                Task size:       4876 KB
                  Thread 0x96e              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x106eb7000 -        0x106ec1fff  com.apple.AccountPolicyHelper 1.0 (1) <1CF6879C-2950-3952-B84E-7ADD5BFF0B21>  /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPo licyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
                Process:         com.apple.AmbientDisplayAgent [12967]
                Path:            /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.app le.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
                Parent:          launchd [1]
                UID:             0
                Task size:       10.39 MB
                  Thread 0x57fe3c           DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, IO tier 0>
                    10  main + 320 (com.apple.AmbientDisplayAgent + 11861) [0x10be8ce55] 1-10
                  Thread 0x57ff11           10 samples (1-10)         priority 31 (base 31)
                        10  ??? (com.apple.AmbientDisplayAgent + 14076) [0x10be8d6fc] 1-10
                  Binary Images:
                           0x10be8a000 -        0x10be91fff  com.apple.AmbientDisplayAgent 1.0 (110) <0E1D072D-BBAB-3B0F-8A1A-D9CA82A6E0A6>  /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.app le.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
                Process:         com.apple.appkit.xpc.openAndSavePanelService [14737]
                Path:            /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.o penAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
                Architecture:    x86_64
                Parent:          launchd [1]
                Responsible:     Preview [14729]
                UID:             502
                Task size:       53.21 MB
                CPU Time:        <0.001s (379.5K cycles, 129.8K instructions, 2.92c/i)
                  Thread 0x6931e7           DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from Preview [14729], IO tier 0>
                    10  main + 208 (com.apple.appkit.xpc.openAndSavePanelService + 29592) [0x10111d398] 1-10
                      10  NSViewServiceApplicationMain + 2903 (ViewBridge + 10942) [0x7fff5048eabe] 1-10
                        10  -[NSXPCSharedListener resume] + 16 (ViewBridge + 19477) [0x7fff50490c15] 1-10
                            10  _xpc_objc_main + 580 (libxpc.dylib + 68983) [0x7fff53ba4d77] 1-10
                                  10  -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 92 (ViewBridge + 19952) [0x7fff50490df0] 1-10
                  Thread 0x693217           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  Binary Images:
                           0x101116000 -        0x101120fff  com.apple.appkit.xpc.openAndSavePanelService 1.0 (1) <748F24AB-B4A8-3F68-BED4-4522AE356245>  /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.o penAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
                        0x7fff5048c000 -     0x7fff5055bfff  com.apple.ViewBridge 343.2 (343.2)                   <5519FCED-1F88-3BE6-9BE1-69992086B01B>  /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                Process:         com.apple.appstore.PluginXPCService [13342]
                Path:            /System/Library/PrivateFrameworks/StoreXPCServices.framework/Versions/A/XPCServices/com.a pple.appstore.PluginXPCService.xpc/Contents/MacOS/com.apple.appstore.PluginXPCService
                Parent:          launchd [1]
                UID:             502
                Task size:       4496 KB
                  Thread 0x59fe4c           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10c6a0000 -        0x10c6a1fff  com.apple.appstore.PluginXPCService 1.0 (658.1) <2D0A8871-08F0-35BB-AA93-8B52447E57BC>  /System/Library/PrivateFrameworks/StoreXPCServices.framework/Versions/A/XPCServices/com.a pple.appstore.PluginXPCService.xpc/Contents/MacOS/com.apple.appstore.PluginXPCService
                Process:         com.apple.audio.DriverHelper [177]
                Path:            /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.Dri verHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
                Parent:          launchd [1]
                Responsible:     coreaudiod [163]
                UID:             202
                Task size:       7152 KB
                  Thread 0x434              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x102533000 -        0x102535fff  com.apple.audio.DriverHelper 1.0 (1) <FD7ED2EE-FF98-375A-B6ED-70146A780CDF>  /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.Dri verHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
                Process:         com.apple.audio.SandboxHelper [255]
                Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Parent:          launchd [1]
                UID:             202
                Task size:       8684 KB
                  Thread 0x87e              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x106fbf000 -        0x106fc3fff  com.apple.audio.SandboxHelper 1.0.1 (1) <DEF2716C-A2E2-3B4C-ABE7-9347B705FA6D>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [679]
                Parent:          launchd [1]
                Responsible:     assistantd [365]
                UID:             502
                Task size:       7712 KB
                  Thread 0x543b             10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x104d91000 -        0x104d95fff  com.apple.audio.SandboxHelper 1.0.1 (1) <DEF2716C-A2E2-3B4C-ABE7-9347B705FA6D>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [13420]
                Parent:          launchd [1]
                Responsible:     WhatsApp [13411]
                UID:             502
                Task size:       8632 KB
                  Thread 0x5a59e3           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10e407000 -        0x10e40bfff  com.apple.audio.SandboxHelper 1.0.1 (1) <DEF2716C-A2E2-3B4C-ABE7-9347B705FA6D>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.audio.SandboxHelper [14029]
                Parent:          launchd [1]
                Responsible:     Mail [13967]
                UID:             502
                Task size:       8624 KB
                  Thread 0x64b667           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Thread 0x64b66d           10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10df12000 -        0x10df16fff  com.apple.audio.SandboxHelper 1.0.1 (1) <DEF2716C-A2E2-3B4C-ABE7-9347B705FA6D>  /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                Process:         com.apple.BKAgentService [2287]
                Path:            /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAg entService.xpc/Contents/MacOS/com.apple.BKAgentService
                Parent:          launchd [1]
                UID:             502
                Task size:       15.70 MB
                  Thread 0x50cef            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 98 (com.apple.BKAgentService + 133351) [0x10e2dd8e7] 1-10
                  Binary Images:
                           0x10e2bd000 -        0x10e332fff  com.apple.BKAgentService 1.11 (80)     <70392DA3-A00E-3E60-91F5-DDCCEB1E0699>  /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAg entService.xpc/Contents/MacOS/com.apple.BKAgentService
                Process:         com.apple.CharacterPicker.FileService [608]
                Path:            /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.ap ple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
                Parent:          launchd [1]
                UID:             502
                Task size:       9636 KB
                  Thread 0x2453             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  10  start + 1 (libdyld.dylib + 4117) [0x7fff5384a015] 1-10
                    10  main + 16 (com.apple.CharacterPicker.FileService + 3710) [0x10909ce7e] 1-10
                  Binary Images:
                           0x10909c000 -        0x1090a4fff  com.apple.CharacterPicker.FileService 1.0 (1) <29ECA86B-046C-383B-8C0C-01CBDA74FA4E>  /System/Library/PrivateFrameworks/CharacterPicker.framework/Versions/A/XPCServices/com.ap ple.CharacterPicker.FileService.xpc/Contents/MacOS/com.apple.CharacterPicker.FileService
                Process:         com.apple.CloudPhotosConfiguration [509]
                Path:            /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/Clou dPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguratio n.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
                Parent:          launchd [1]
                UID:             502
                Task size:       21.44 MB
                  Thread 0x18ef             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 24 (com.apple.CloudPhotosConfiguration + 10395) [0x10734989b] 1-10
                      10  +[CPSConfigurationService run] + 53 (com.apple.CloudPhotosConfiguration + 10717) [0x1073499dd] 1-10
                        10  -[CPSConfigurationService run] + 199 (com.apple.CloudPhotosConfiguration + 10929) [0x107349ab1] 1-10
                  Binary Images:
                           0x107347000 -        0x107358fff  com.apple.CloudPhotosConfiguration 3.0 (3291.13.210) <1A5B8C4D-1151-3C85-A1EA-F614FF24AA32>  /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/Clou dPhotosConfigurationXPC.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguratio n.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
                Process:         com.apple.cmio.registerassistantservice [273]
                Path:            /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.re gisterassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
                Parent:          launchd [1]
                UID:             0
                Task size:       1020 KB
                  Thread 0x9e8              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10f3a8000 -        0x10f3a9fff  com.apple.cmio.registerassistantservice 1.1 (1.1) <2BE013CC-784F-315D-BFBF-3DDD76A4389E>  /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.re gisterassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
                Process:         com.apple.CodeSigningHelper [250]
                Path:            /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
                Parent:          launchd [1]
                UID:             0
                Task size:       9928 KB
                  Thread 0x846              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10131d000 -        0x10131efff  com.apple.CodeSigningHelper 1.0 (1) <7470BDAA-098A-3358-A0E8-34F91DD6CD78>  /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSignin gHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
                Process:         com.apple.CommerceKit.TransactionService [13345]
                Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple. CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
                Parent:          launchd [1]
                Responsible:     storeassetd [4241]
                UID:             502
                Task size:       33.58 MB
                  Thread 0x59feb2           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Thread 0x5a1aa0           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x103d04000 -        0x103ee3fff  com.apple.CommerceKit.TransactionService 1.0 (658.1) <C8722E58-2B7B-3D5E-9795-E7C79C6B5D38>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple. CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
                Process:         com.apple.CommerceKit.TransactionService [13395]
                Parent:          launchd [1]
                Responsible:     storedownloadd [644]
                UID:             502
                Task size:       12.87 MB
                  Thread 0x5a1fb6           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x104ae6000 -        0x104cc5fff  com.apple.CommerceKit.TransactionService 1.0 (658.1) <C8722E58-2B7B-3D5E-9795-E7C79C6B5D38>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/XPCServices/com.apple. CommerceKit.TransactionService.xpc/Contents/MacOS/com.apple.CommerceKit.TransactionService
                Process:         com.apple.ctkpcscd [165]
                Path:            /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/C ontents/MacOS/com.apple.ctkpcscd
                Parent:          launchd [1]
                Responsible:     securityd [98]
                UID:             0
                Task size:       8520 KB
                  Thread 0x40d              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10d95c000 -        0x10d966fff  com.apple.ctkpcscd 1.0 (1)         <718182BE-A017-368A-BD14-E2C276060B30>  /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/C ontents/MacOS/com.apple.ctkpcscd
                Process:         com.apple.dock.extra [435]
                Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
                Parent:          launchd [1]
                Responsible:     Dock [296]
                UID:             502
                Task size:       26.69 MB
                CPU Time:        <0.001s (361.9K cycles, 85.4K instructions, 4.24c/i)
                  Thread 0x129c             DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)     cpu time <0.001s (167.5K cycles, 35.0K instructions, 4.78c/i)
                  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
                    10  ??? (com.apple.dock.extra + 4160) [0x1020ae040] 1-10
                            10  -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 1-10
                              10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1-10
                  Thread 0x12ac             Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  Binary Images:
                           0x1020ad000 -        0x1020b0fff  com.apple.dock.extra 1.0 (1)           <D6F5E0A6-F6BC-3701-BBC2-FC36DBBD5FD5>  /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
                Process:         com.apple.geod [350]
                Path:            /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                Parent:          launchd [1]
                UID:             502
                Task size:       26.05 MB
                CPU Time:        <0.001s (160.1K cycles, 40.9K instructions, 3.92c/i)
                  Thread 0xee6              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.geod + 117269) [0x10750da15] 1-10
                  Thread 0xefc              Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
                  Thread 0x140f             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1074f1000 -        0x107515fff  com.apple.geod 1.0 (1363.24.8.15.58)        <C57D1E31-9D64-378D-A547-87E54F334F42>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                Process:         com.apple.geod [6555]
                Parent:          launchd [1]
                UID:             205
                Task size:       17.09 MB
                  Thread 0x46196e           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.geod + 117269) [0x10a252a15] 1-10
                  Thread 0x4619d3           Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
                  10  thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff53b61bf9] 1-10
                    10  _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff53b6250d] 1-10
                      10  _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff53b62661] 1-10
                  Binary Images:
                           0x10a236000 -        0x10a25afff  com.apple.geod 1.0 (1363.24.8.15.58)        <C57D1E31-9D64-378D-A547-87E54F334F42>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                Process:         com.apple.geod [6573]
                Parent:          launchd [1]
                UID:             0
                Task size:       18.47 MB
                  Thread 0x462f36           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.geod + 117269) [0x1090f5a15] 1-10
                  Thread 0x462f44           Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
                  Thread 0x462f5e           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1090d9000 -        0x1090fdfff  com.apple.geod 1.0 (1363.24.8.15.58)        <C57D1E31-9D64-378D-A547-87E54F334F42>  /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple. geod.xpc/Contents/MacOS/com.apple.geod
                Process:         com.apple.hiservices-xpcservice [606]
                Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.a pple.hiservices-xpcservice
                Parent:          launchd [1]
                UID:             502
                Task size:       6300 KB
                  Thread 0x240d             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x102b14000 -        0x102b18fff  com.apple.hiservices-xpcservice 1.22 (624.1) <57D3EA7E-079E-3569-90BF-760970CEC426>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.a pple.hiservices-xpcservice
                Process:         com.apple.iCloudHelper [14838]
                Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
                Parent:          launchd [1]
                UID:             502
                Task size:       16.26 MB
                  Thread 0x6a204b           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 166 (com.apple.iCloudHelper + 13784) [0x1059a25d8] 1-10
                              10  CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1-10
                                10  __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1-10
                                  10  __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1-10
                                    10  mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1-10
                                     *10  ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1-10
                  Binary Images:
                           0x10599f000 -        0x1059b1fff  com.apple.iCloudHelper 1.07 (267)      <C3CFD1CF-B8DC-375D-AFE6-C017BB4F13A5>  /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
                Process:         com.apple.ifdreader [212]
                Path:            /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdread er
                Parent:          launchd [1]
                UID:             0
                Task size:       9076 KB
                  Thread 0x559              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 1115 (com.apple.ifdreader + 6238) [0x10edfc85e] 1-10
                  Binary Images:
                           0x10edfb000 -        0x10ee07fff  com.apple.ifdreader 1.0 (1)            <88A3A996-79B8-327E-8EBE-928BA94E85BE>  /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdread er
                Process:         com.apple.iTunesLibraryService [456]
                Path:            /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibrar yService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
                Parent:          launchd [1]
                UID:             502
                Task size:       10.74 MB
                  Thread 0x15f3             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1035b6000 -        0x103685fff  com.apple.iTunesLibraryService 12.8 (12.8.0) <B1A8AC6B-3939-3E21-A6DF-FA35822BC5EE>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibrar yService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
                Process:         com.apple.iTunesLibraryService [4725]
                Parent:          launchd [1]
                Responsible:     assistant_service [1932]
                UID:             502
                Task size:       10.55 MB
                  Thread 0x323db2           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                     *10  ??? (kernel + 5438272) [0xffffff800072fb40] 1-10
                  Binary Images:
                           0x10e3ef000 -        0x10e4befff  com.apple.iTunesLibraryService 12.8 (12.8.0) <B1A8AC6B-3939-3E21-A6DF-FA35822BC5EE>  /Library/Frameworks/iTunesLibrary.framework/Versions/A/XPCServices/com.apple.iTunesLibrar yService.xpc/Contents/MacOS/com.apple.iTunesLibraryService
                Process:         com.apple.MediaLibraryService [650]
                Path:            /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaL ibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService
                Parent:          launchd [1]
                Responsible:     cloudphotosd [410]
                UID:             502
                Task size:       33.13 MB
                  Thread 0x385c             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 100 (com.apple.MediaLibraryService + 4242) [0x10c03b092] 1-10
                  Binary Images:
                           0x10c03a000 -        0x10c044fff  com.apple.MediaLibraryService 1.4.0 (751) <DDC29838-6393-3B83-AF5C-C2AFAA1BC6BB>  /System/Library/Frameworks/MediaLibrary.framework/Versions/A/XPCServices/com.apple.MediaL ibraryService.xpc/Contents/MacOS/com.apple.MediaLibraryService
                Process:         com.apple.Notes.datastore [2086]
                Path:            /System/Library/PrivateFrameworks/NotesShared.framework/Versions/A/XPCServices/com.apple. Notes.datastore.xpc/Contents/MacOS/com.apple.Notes.datastore
                Parent:          launchd [1]
                UID:             502
                Task size:       7264 KB
                  Thread 0x46179            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 187 (com.apple.Notes.datastore + 8880) [0x1054582b0] 1-10
                      10  ??? (com.apple.Notes.datastore + 5610) [0x1054575ea] 1-10
                  Binary Images:
                           0x105456000 -        0x10545dfff  com.apple.Notes.datastore 1.0 (876.1)  <C1CC0FC3-7037-300D-B8FA-FCB2F625A233>  /System/Library/PrivateFrameworks/NotesShared.framework/Versions/A/XPCServices/com.apple. Notes.datastore.xpc/Contents/MacOS/com.apple.Notes.datastore
                Process:         com.apple.notificationcenterui.WeatherSummary [412]
                Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notifi cationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSum mary
                Parent:          launchd [1]
                Responsible:     NotificationCenter (Notification Center) [351]
                UID:             502
                Task size:       15.17 MB
                  Thread 0x114a             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from NotificationCenter (Notification Center) [351], IO tier 0>
                    10  main + 147 (com.apple.notificationcenterui.WeatherSummary + 6381) [0x1045378ed] 1-10
                  Binary Images:
                           0x104536000 -        0x104538fff  com.apple.notificationcenterui.WeatherSummary 1.0 (639.10) <65779B7C-13C9-350D-A85C-7E3FF02A7AE3>  /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notifi cationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSum mary
                        0x7fff2b988000 -     0x7fff2be29fff  com.apple.CoreFoundation 6.9 (1454.90)                     <E5D594BF-9142-3325-A62D-CF4AAF472642>  /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                        0x7fff2dae9000 -     0x7fff2deaffff  com.apple.Foundation 6.9 (1454.90)                         <8EA924F3-ADAE-3F4B-8482-8B11C027D9A5>  /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                        0x7fff53849000 -     0x7fff53866fff  libdyld.dylib (551.4)                                      <81BF3A82-5719-3B54-ABA9-76C82D932CAC>  /usr/lib/system/libdyld.dylib
                        0x7fff5397e000 -     0x7fff539a4fff  libsystem_kernel.dylib (4570.71.2)                         <F22B8D73-69D8-36D7-BF66-7F9AC70C08C2>  /usr/lib/system/libsystem_kernel.dylib
                   *0xffffff8000200000 - 0xffffff80009fffff  kernel (4570.71.2)                                         <1AE5ACFD-3B6F-3D74-AD52-31F1430DBC6F>  /System/Library/Kernels/kernel
                Process:         com.apple.PerformanceAnalysis.animationperfd [264]
                Path:            /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/co m.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysi s.animationperfd
                Parent:          launchd [1]
                UID:             0
                Sudden Term:     Tracked (allows idle exit)
                Task size:       9664 KB
                  Thread 0x8ef              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Thread 0x6a7953           10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x105f6e000 -        0x105f77fff  com.apple.PerformanceAnalysis.animationperfd 1.2 (2) <0AA66B5A-1407-37B8-B870-6F82CDDF8DBA>  /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/co m.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysi s.animationperfd
                        0x7fff5380f000 -     0x7fff53848fff  libdispatch.dylib (913.60.2)                         <232C69BD-022E-3AB9-8807-79F9FA7CB5EC>  /usr/lib/system/libdispatch.dylib
                   *0xffffff7f82a20000 - 0xffffff7f82a2bfff  com.apple.kec.pthread 1.0 (1)                        <E64F7A49-CBF0-3251-9F02-3655E3B3DD31>  /System/Library/Extensions/pthread.kext/Contents/MacOS/pthread
                Process:         com.apple.photomodel [1069]
                Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS /com.apple.photomodel
                Parent:          launchd [1]
                Responsible:     photolibraryd [527]
                UID:             502
                Task size:       20.34 MB
                Note:            1 idle work queue thread omitted
                  Thread 0x18690            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                  Binary Images:
                           0x109ba0000 -        0x109ba5fff  com.apple.photomodel 3.0 (3291.13.210) <C4CD8C02-A4B8-3D77-A904-FE28F1299640>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomodel.xpc/Contents/MacOS /com.apple.photomodel
                Process:         com.apple.photomoments [572]
                Path:            /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/Mac OS/com.apple.photomoments
                Parent:          launchd [1]
                UID:             502
                Task size:       23.56 MB
                  Thread 0x1e5a             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 502 (com.apple.photomoments + 6432) [0x102332920] 1-10
                  Thread 0x1f4f             Thread name "NetworkLoad" 10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x102331000 -        0x102336fff  com.apple.photomoments 3.0 (3291.13.210) <AA1E8961-8AF9-3EFB-B686-E0B54CD96699>  /System/Library/PrivateFrameworks/PhotoLibraryPrivate.framework/Versions/A/Frameworks/Pho toLibraryServices.framework/Versions/A/XPCServices/com.apple.photomoments.xpc/Contents/Mac OS/com.apple.photomoments
                Process:         com.apple.quicklook.ThumbnailsAgent [647]
                Path:            /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quick look.ThumbnailsAgent
                Parent:          launchd [1]
                UID:             502
                Task size:       10.91 MB
                  Thread 0x3842             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.quicklook.ThumbnailsAgent + 44149) [0x10366fc75] 1-10
                  Binary Images:
                           0x103665000 -        0x10367bfff  com.apple.quicklook.ThumbnailsAgent (49.3) <2CCABD6D-4748-33E4-9287-7F84A1C0068A>  /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Support/com.apple.quick look.ThumbnailsAgent
                Process:         com.apple.sbd [916]
                Path:            /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.appl e.sbd.xpc/Contents/MacOS/com.apple.sbd
                Parent:          launchd [1]
                UID:             502
                Task size:       22.64 MB
                CPU Time:        <0.001s (129.0K cycles, 40.8K instructions, 3.16c/i)
                  Thread 0x11eb2            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (com.apple.sbd + 263959) [0x10f1d8717] 1-10
                  Thread 0x323dc0           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                        10  __NSThread__start__ + 1197 (Foundation + 193016) [0x7fff2db181f8] 1-10
                          10  -[__CoreSchedulingSetRunnable runForever] + 722 (CFNetwork + 2375300) [0x7fff2ab57e84] 1-10
                  Binary Images:
                           0x10f198000 -        0x10f1f6fff  com.apple.sbd 1.0 (297.60.1)           <F5852541-5EA4-3542-9E8B-09E6A283710C>  /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/XPCServices/com.appl e.sbd.xpc/Contents/MacOS/com.apple.sbd
                        0x7fff2a914000 -     0x7fff2acaefff  com.apple.CFNetwork 902.1 (902.1)      <76EB8CB6-BF59-3BDA-BF2B-F21B161611B9>  /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                        0x7fff53b5f000 -     0x7fff53b6afff  libsystem_pthread.dylib (301.50.1)     <0E51CCBA-91F2-34E1-BF2A-FEEFD3D321E4>  /usr/lib/system/libsystem_pthread.dylib
                Process:         com.apple.siri-distributed-evaluation [1643]
                Path:            /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/ com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evalua tion
                Parent:          launchd [1]
                UID:             502
                Task size:       6580 KB
                  Thread 0x29eb0            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 278 (com.apple.siri-distributed-evaluation + 23706) [0x103e1dc9a] 1-10
                  Binary Images:
                           0x103e18000 -        0x103e1ffff  com.apple.siri-distributed-evaluation 1.0 (1) <ED7885E1-6369-3D20-88AD-4C7A38634120>  /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/ com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evalua tion
                Process:         com.apple.speech.speechsynthesisd [2018]
                Path:            /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
                Parent:          launchd [1]
                UID:             502
                Task size:       27.63 MB
                  Thread 0x3caa3            DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (com.apple.speech.speechsynthesisd + 6851) [0x10030aac3] 1-10
                  Binary Images:
                           0x100309000 -        0x10031bfff  com.apple.speech.speechsynthesisd (7.8.1) <FE1B6A3D-027C-31CA-8307-81EA3024F86C>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
                Process:         com.apple.speech.speechsynthesisd [2122]
                Parent:          launchd [1]
                UID:             0
                Task size:       20.10 MB
                  Thread 0x48411            DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (com.apple.speech.speechsynthesisd + 6851) [0x1003c0ac3] 1-10
                  Binary Images:
                           0x1003bf000 -        0x1003d1fff  com.apple.speech.speechsynthesisd (7.8.1) <FE1B6A3D-027C-31CA-8307-81EA3024F86C>  /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
                Process:         com.apple.tonelibraryd [3827]
                Path:            /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/XPCServices/com.apple. tonelibraryd.xpc/Contents/MacOS/com.apple.tonelibraryd
                Parent:          launchd [1]
                UID:             502
                Task size:       4760 KB
                  Thread 0x2e7552           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10abb3000 -        0x10abb5fff  com.apple.tonelibraryd 1.0 (1)     <6565AA93-2C77-3F40-8302-F18604DB4598>  /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/XPCServices/com.apple. tonelibraryd.xpc/Contents/MacOS/com.apple.tonelibraryd
                Process:         com.apple.WeatherKitService [937]
                Path:            /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.W eatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
                Parent:          launchd [1]
                UID:             502
                Task size:       148.90 MB
                  Thread 0x12782            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10bea1000 -        0x10bebffff  com.apple.WeatherKitService 2.0 (153.4.1) <7C726DFB-2DE6-3FB9-AD43-8D90659FEE60>  /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.W eatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
                Process:         com.apple.WeatherKitService [6557]
                Parent:          launchd [1]
                UID:             502
                Task size:       50.59 MB
                  Thread 0x4619af           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x107889000 -        0x1078a7fff  com.apple.WeatherKitService 2.0 (153.4.1) <7C726DFB-2DE6-3FB9-AD43-8D90659FEE60>  /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.W eatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
                Process:         com.apple.WebKit.Networking [13970]
                Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Netwo rking.xpc/Contents/MacOS/com.apple.WebKit.Networking
                Parent:          launchd [1]
                UID:             502
                Task size:       38.48 MB
                CPU Time:        <0.001s (317.9K cycles, 68.3K instructions, 4.66c/i)
                Note:            2 idle work queue threads omitted
                  Thread 0x63d759           DispatchQueue 1           10 samples (1-10)         priority 37 (base 37)     cpu time <0.001s (168.6K cycles, 33.7K instructions, 5.00c/i)
                  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, process received importance donation from Mail [13967], IO tier 0>
                    10  ??? (com.apple.WebKit.Networking + 5793) [0x1044e66a1] 1-10
                          10  -[NSRunLoop(NSRunLoop) run] + 76 (Foundation + 134654) [0x7fff2db09dfe] 1-10
                            10  -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277 (Foundation + 134950) [0x7fff2db09f26] 1-10
                  Thread 0x63d763           10 samples (1-10)         priority 37 (base 37)
                        10  void* std::__1::__thread_proxy<std::__1::tuple<std::__1::unique_ptr<std::__1::__thread_struct, std::__1::default_delete<std::__1::__thread_struct> >, void (*)(bmalloc::Scavenger*), bmalloc::Scavenger*> >(void*) + 40 (JavaScriptCore + 12744344) [0x7fff2f683698] 1-10
                          10  bmalloc::Scavenger::threadEntryPoint(bmalloc::Scavenger*) + 9 (JavaScriptCore + 12743513) [0x7fff2f683359] 1-10
                            10  bmalloc::Scavenger::threadRunLoop() + 251 (JavaScriptCore + 12744027) [0x7fff2f68355b] 1-10
                              10  void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 86 (JavaScriptCore + 12744870) [0x7fff2f6838a6] 1-10
                                10  std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 18 (libc++.1.dylib + 27824) [0x7fff5179ecb0] 1-10
                                  10  __psynch_cvwait + 10 (libsystem_kernel.dylib + 117270) [0x7fff5399aa16] 1-10
                                   *10  psynch_cvcontinue + 0 (pthread + 38948) [0xffffff7f82a29824] 1-10
                  Thread 0x63d775           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  Thread 0x63ff06           Thread name "com.apple.CFNetwork.CustomProtocols"   10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, process unclamped, process received importance donation from Mail [13967], IO tier 0>
                  Binary Images:
                           0x1044e5000 -        0x1044e6fff  com.apple.WebKit.Networking 13605 (13605.3.8) <557AF506-FABE-3607-B9A2-FD24A7CABD24>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Netwo rking.xpc/Contents/MacOS/com.apple.WebKit.Networking
                        0x7fff2ea5c000 -     0x7fff2f742fff  com.apple.JavaScriptCore 13605 (13605.3.8)    <E6B49CDA-72F0-3E58-85EF-98AF10CE04B0>  /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                        0x7fff51798000 -     0x7fff517eefff  libc++.1.dylib (400.9)                        <7D3DACCC-3804-393C-ABC1-1A580FD00CB6>  /usr/lib/libc++.1.dylib
                Process:         com.apple.WebKit.WebContent [13969]
                Path:            /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Parent:          launchd [1]
                UID:             502
                Task size:       193.11 MB
                  Thread 0x63d756           DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                    10  ??? (com.apple.WebKit.WebContent + 5793) [0x10dced6a1] 1-10
                          10  NSApplicationMain + 804 (AppKit + 23154) [0x7fff28f6ca72] 1-10
                                10  _DPSNextEvent + 2085 (AppKit + 268915) [0x7fff28fa8a73] 1-10
                                  10  _BlockUntilNextEventMatchingListInModeWithFilter + 64 (HIToolbox + 194692) [0x7fff2acf7884] 1-10
                                    10  ReceiveNextEventCommon + 613 (HIToolbox + 195334) [0x7fff2acf7b06] 1-10
                                      10  RunCurrentEventLoopInMode + 286 (HIToolbox + 195990) [0x7fff2acf7d96] 1-10
                  Thread 0x63d76e           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                        10  _NSEventThread + 184 (AppKit + 1568708) [0x7fff290e5fc4] 1-10
                  Thread 0x63d76f           10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user initiated), process sudden termination dirty, process unclamped, IO tier 0>
                  Thread 0x63d776           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  Thread 0x63d77f           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 46 (base 46)
                        10  WTF::wtfThreadEntryPoint(void*) + 9 (JavaScriptCore + 13865) [0x7fff2ea5f629] 1-10
                          10  WTF::Thread::entryPoint(WTF::Thread::NewThreadContext*) + 228 (JavaScriptCore + 12712596) [0x7fff2f67ba94] 1-10
                            10  WebCore::ScrollingThread::initializeRunLoop() + 253 (WebCore + 264893) [0x7fff38d69abd] 1-10
                              10  CFRunLoopRun + 99 (CoreFoundation + 801763) [0x7fff2ba4bbe3] 1-10
                  Binary Images:
                           0x10dcec000 -        0x10dcedfff  com.apple.WebKit.WebContent 13605 (13605.3.8) <8D62BE72-9344-303A-A15A-A8B5AC3BFCA3>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                        0x7fff28f67000 -     0x7fff29dc5fff  com.apple.AppKit 6.9 (1561.60.100)            <3C27CF6F-E640-3411-A87D-CCB2222CC754>  /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                        0x7fff2acc8000 -     0x7fff2afcdfff  com.apple.HIToolbox 2.1.1 (911.10)            <BF7F9C0E-C732-3FB2-9BBC-362888BDA57B>  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                        0x7fff38d29000 -     0x7fff3a3fcfff  com.apple.WebCore 13605 (13605.3.8)           <2F0DA536-2C93-3EB2-9FFE-13AE1B40C4DC>  /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                Process:         com.apple.WebKit.WebContent [14688]
                Parent:          launchd [1]
                UID:             502
                Task size:       108.36 MB
                  Thread 0x689643           DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                    10  ??? (com.apple.WebKit.WebContent + 5793) [0x10adfd6a1] 1-10
                  Thread 0x68965d           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                  Thread 0x68967d           10 samples (1-10)         priority 37 (base 37)
                  Thread 0x689680           Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 37 (base 37)
                  Thread 0x689686           Thread name "WebCore: Scrolling"                    10 samples (1-10)         priority 46 (base 46)
                  Binary Images:
                           0x10adfc000 -        0x10adfdfff  com.apple.WebKit.WebContent 13605 (13605.3.8) <8D62BE72-9344-303A-A15A-A8B5AC3BFCA3>  /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebCo ntent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
                Process:         CommCenter [295]
                Path:            /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
                Parent:          launchd [1]
                UID:             502
                Task size:       31.63 MB
                CPU Time:        <0.001s (519.5K cycles, 162.2K instructions, 3.20c/i)
                Note:            3 idle work queue threads omitted
                  Thread 0xc82              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination clean, IO tier 0>
                    10  ??? (CommCenter + 396898) [0x10da73e62] 1-10
                      10  ??? (CommCenter + 398500) [0x10da744a4] 1-10
                  Thread 0xd67              10 samples (1-10)         priority 31 (base 31)
                        10  ATCSThreadStartStub(void*) + 30 (libATCommandStudioDynamic.dylib + 21438) [0x7fff510623be] 1-10
                          10  ATCSTimerDriver::startATCSTimerDispatcher(void*) + 9 (libATCommandStudioDynamic.dylib + 24189) [0x7fff51062e7d] 1-10
                            10  ATCSTimerDriver::timerDispatcher() + 47 (libATCommandStudioDynamic.dylib + 24499) [0x7fff51062fb3] 1-10
                              10  ATCSCondition::wait(ATCSMutex*, int) + 123 (libATCommandStudioDynamic.dylib + 22347) [0x7fff5106274b] 1-10
                  Thread 0xd74              10 samples (1-10)         priority 31 (base 31)
                        10  ??? (CommCenter + 4606456) [0x10de779f8] 1-10
                  Thread 0xd75              10 samples (1-10)         priority 31 (base 31)
                        10  ??? (CommCenter + 586189) [0x10daa21cd] 1-10
                  Thread 0xd88              10 samples (1-10)         priority 31 (base 31)     cpu time <0.001s (79.8K cycles, 20.3K instructions, 3.93c/i)
                        10  ??? (CommCenter + 4271617) [0x10de25e01] 1-10
                          10  ??? (CommCenter + 4272063) [0x10de25fbf] 1-10
                  Binary Images:
                           0x10da13000 -        0x10e167fff  CommCenter (5793)                      <6F9ADD82-C588-3CCD-953E-F05EEECE4C2F>  /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter
                        0x7fff5105d000 -     0x7fff510a2fff  libATCommandStudioDynamic.dylib (1992) <9C49CEB1-E998-366E-AA69-B39A40EA5C23>  /usr/lib/libATCommandStudioDynamic.dylib
                Process:         commerce [349]
                Path:            /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
                Parent:          launchd [1]
                UID:             502
                Task size:       50.21 MB
                  Thread 0xee5              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested utility), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
                    10  ??? (commerce + 132208) [0x10e152470] 1-10
                  Thread 0x17c2             Thread name "com.apple.NSURLConnectionLoader"       10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), process sudden termination clean, thread darwinbg, process darwinbg, timers tier 3 (coalesced), IO tier 2>
                  Binary Images:
                           0x10e132000 -        0x10e343fff  commerce (658.1)                       <EEA40253-8DD2-38B0-9C5D-775302C0D1BC>  /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
                Process:         configd [67]
                Path:            /usr/libexec/configd
                Parent:          launchd [1]
                UID:             0
                Task size:       13.74 MB
                CPU Time:        <0.001s (1334.6K cycles, 444.9K instructions, 3.00c/i)
                  Thread 0x272              DispatchQueue 1           Thread name "SCDynamicStore"                        10 samples (1-10)         priority 37 (base 37)     cpu time <0.001s (1334.6K cycles, 444.9K instructions, 3.00c/i)
                  <thread QoS user initiated (requested user initiated), process sudden termination clean, IO tier 0>
                    10  ??? (configd + 12387) [0x10344e063] 1-10
                      10  ??? (configd + 17462) [0x10344f436] 1-10
                  Thread 0x2d2              Thread name "Main plugin thread"                    10 samples (1-10)         priority 31 (base 31)
                        10  ??? (configd + 20390) [0x10344ffa6] 1-10
                  Thread 0x315              Thread name "InterfaceNamer thread"                 10 samples (1-10)         priority 31 (base 31)
                        10  ??? (configd + 76327) [0x10345da27] 1-10
                  Thread 0x31a              10 samples (1-10)         priority 31 (base 31)
                        10  pppcntl_run_thread + 704 (PPPController + 56719) [0x103534d8f] 1-10
                  Thread 0x31e              Thread name "com.apple.CFSocket.private"            10 samples (1-10)         priority 31 (base 31)
                        10  __select + 10 (libsystem_kernel.dylib + 118002) [0x7fff5399acf2] 1-10
                  Thread 0x3cb              10 samples (1-10)         priority 31 (base 31)
                        10  captived_thread + 267 (CaptiveNetworkSupport + 18849) [0x1046049a1] 1-10
                  Thread 0x3d8              10 samples (1-10)         priority 31 (base 31)
                        10  ??? (EAPOLController + 18669) [0x10358b8ed] 1-10
                  Binary Images:
                           0x10344b000 -        0x1034a5fff  configd (963.50.8)                                               <3EC09458-0806-3C00-B0A1-C110B418F3C3>  /usr/libexec/configd
                           0x103527000 -        0x103564fff  com.apple.SystemConfiguration.PPPController 1.10 (1.10)          <BE2873E8-2F5F-3F32-8DC3-197CB344F048>  /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
                           0x103587000 -        0x10358dfff  com.apple.SystemConfiguration.EAPOLController 14.0.0 (14.0)      <0A38C3FD-2851-36EB-BD17-756ED276BEFB>  /System/Library/SystemConfiguration/EAPOLController.bundle/Contents/MacOS/EAPOLController
                           0x104600000 -        0x104620fff  com.apple.SystemConfiguration.CaptiveNetworkSupport 16.0.0 (1.0) <6BBDFDEF-5517-322C-894F-5421AA407BF8>  /System/Library/SystemConfiguration/CaptiveNetworkSupport.bundle/Contents/MacOS/CaptiveNe tworkSupport
                Process:         ContactsAccountsService [322]
                Path:            /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
                Parent:          launchd [1]
                UID:             502
                Task size:       16.20 MB
                  Thread 0xddf              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (ContactsAccountsService + 13639) [0x10f7bb547] 1-10
                  Binary Images:
                           0x10f7b8000 -        0x10f7bffff  ContactsAccountsService (1808.8)       <F9C4F587-62A6-309A-B160-B379DF438137>  /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
                Process:         ContactsAgent [443]
                Path:            /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
                Parent:          launchd [1]
                UID:             502
                Task size:       16.41 MB
                  Thread 0x12e0             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 102 (ContactsAgent + 8795) [0x7fff3e21e25b] 1-10
                  Binary Images:
                           0x10fced000 -        0x10fcedfff  ContactsAgent (12)                     <6FFF41A8-B6BF-3712-AB6A-2EE13F554297>  /System/Library/PrivateFrameworks/ContactsAgent.framework/Executables/ContactsAgent
                        0x7fff3e21c000 -     0x7fff3e232fff  com.apple.ContactsAgent 1.0 (1)        <A1E5B0AA-EF48-36CE-A1BD-0B2F2758E0E3>  /System/Library/PrivateFrameworks/ContactsAgent.framework/Versions/A/ContactsAgent
                Process:         contactsdonationagent [2085]
                Path:            /System/Library/PrivateFrameworks/ContactsDonation.framework/Versions/A/Support/contactsd onationagent
                Parent:          launchd [1]
                UID:             502
                Task size:       22.87 MB
                  Thread 0x46161            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested default), process sudden termination dirty, thread darwinbg, process darwinbg, IO tier 2>
                    10  ??? (contactsdonationagent + 13693) [0x1060eb57d] 1-10
                  Binary Images:
                           0x1060e8000 -        0x10613ffff  contactsdonationagent (38.2)           <00D93B5E-2868-3D03-82DD-33DC19F55EE9>  /System/Library/PrivateFrameworks/ContactsDonation.framework/Versions/A/Support/contactsd onationagent
                Process:         ContainerMetadataExtractor [434]
                Path:            /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadata Extractor.xpc/Contents/MacOS/ContainerMetadataExtractor
                Parent:          launchd [1]
                Responsible:     bird [304]
                UID:             502
                Task size:       12.75 MB
                  Thread 0x1294             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (ContainerMetadataExtractor + 14876) [0x10b4c1a1c] 1-10
                  Binary Images:
                           0x10b4be000 -        0x10b4c5fff  com.apple.CloudDocsDaemon.container-metadata-extractor 1.0 (575.14) <7A6A7700-3A76-39E0-A515-C531D19806EE>  /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadata Extractor.xpc/Contents/MacOS/ContainerMetadataExtractor
                Process:         ContextService [618]
                Path:            /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextServ ice.xpc/Contents/MacOS/ContextService
                Parent:          launchd [1]
                UID:             502
                Task size:       8916 KB
                  Thread 0x2c82             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  10  _dispatch_sig_thread + 53 (libdispatch.dylib + 56512) [0x7fff5381ccc0] 1-10
                    10  __sigsuspend_nocancel + 10 (libsystem_kernel.dylib + 118818) [0x7fff5399b022] 1-10
                  Binary Images:
                           0x103e64000 -        0x10426ffff  com.apple.siri.context.service 1.0 (1) <11C06E93-8975-3430-A164-D89A0A555D1A>  /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextServ ice.xpc/Contents/MacOS/ContextService
                Process:         Core Sync [506]
                Path:            /Applications/Utilities/Adobe Sync/*/Core Sync.app/Contents/MacOS/Core Sync
                Parent:          launchd [1]
                UID:             502
                Task size:       40.67 MB
                CPU Time:        0.001s (2.2M cycles, 621.0K instructions, 3.55c/i)
                Process:         coreaudiod [163]
                Path:            /usr/sbin/coreaudiod
                Parent:          launchd [1]
                UID:             202
                Task size:       16.70 MB
                  Thread 0x3f4              DispatchQueue 1           10 samples (1-10)         priority 63 (base 63)
                  <process sudden termination dirty, IO tier 0>
                    10  ??? (coreaudiod + 171569) [0x1081dbe31] 1-10
                  Thread 0x41b              Thread name "HAL Async Logger"                      10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process sudden termination dirty, IO tier 0>
                        10  ??? (coreaudiod + 263571) [0x1081f2593] 1-10
                          10  ??? (coreaudiod + 262405) [0x1081f2105] 1-10
                            10  semaphore_wait_trap + 10 (libsystem_kernel.dylib + 78406) [0x7fff53991246] 1-10
                             *10  semaphore_wait_continue + 0 (kernel + 596880) [0xffffff8000291b90] 1-10
                  Thread 0x48d              Thread name "Audio HAL Overload Reporting Spool"    10 samples (1-10)         priority 31 (base 31)
                  Thread 0x4ac              Thread name "SystemSoundServer"                     10 samples (1-10)         priority 61 (base 61)
                        10  CAPThread::Entry(CAPThread*) + 77 (AudioToolbox + 69913) [0x7fff2a372119] 1-10
                          10  GenericRunLoopThread::Entry(void*) + 158 (AudioToolbox + 70666) [0x7fff2a37240a] 1-10
                  Binary Images:
                           0x1081b2000 -        0x108341fff  coreaudiod (93.13.6.1)                           <877517E9-45F2-3674-9AB3-E106607B679E>  /usr/sbin/coreaudiod
                        0x7fff2a361000 -     0x7fff2a5effff  com.apple.audio.toolbox.AudioToolbox 1.14 (1.14) <E0B8B5D8-80A0-308B-ABD6-F8612102B5D8>  /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                Process:         coreauthd [270]
                Path:            /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
                Parent:          launchd [1]
                UID:             0
                Task size:       10.09 MB
                  Thread 0x9a3              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (coreauthd + 33981) [0x107cb34bd] 1-10
                  Binary Images:
                           0x107cab000 -        0x107cd6fff  coreauthd (425.70.1)                   <E802A99A-0734-3DB7-8510-6FE801E68778>  /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
                Process:         coreauthd [332]
                Parent:          launchd [1]
                UID:             502
                Task size:       11.16 MB
                  Thread 0xe39              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (coreauthd + 33981) [0x1073644bd] 1-10
                  Binary Images:
                           0x10735c000 -        0x107387fff  coreauthd (425.70.1)                   <E802A99A-0734-3DB7-8510-6FE801E68778>  /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
                Process:         corebrightnessd [116]
                Path:            /usr/libexec/corebrightnessd
                Parent:          launchd [1]
                UID:             0
                Task size:       55.15 MB
                  Thread 0x296              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  main + 582 (corebrightnessd + 5961) [0x10daf9749] 1-10
                  Binary Images:
                           0x10daf8000 -        0x10daf9fff  corebrightnessd (592.70.11)            <F1409A70-1C86-3917-B330-A43EE595D721>  /usr/libexec/corebrightnessd
                Process:         coreduetd [89]
                Path:            /usr/libexec/coreduetd
                Parent:          launchd [1]
                UID:             0
                Task size:       39.21 MB
                  Thread 0x29d              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (coreduetd + 225624) [0x10be75158] 1-10
                  Binary Images:
                           0x10be3e000 -        0x10bed4fff  coreduetd (915.50.54)                  <C036A795-056D-362E-9C00-95D1A15670EB>  /usr/libexec/coreduetd
                Process:         CoreLocationAgent [348]
                Path:            /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
                Parent:          launchd [1]
                UID:             502
                Task size:       16.85 MB
                  Thread 0xecb              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  Thread 0xf10              Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user interactive), process sudden termination clean, IO tier 0>
                  Binary Images:
                           0x1000a2000 -        0x1000a8fff  com.apple.CoreLocationAgent 1486.12 (1486.12) <81888D2C-6E76-3157-8AFE-B391723C5CDC>  /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
                Process:         coreservicesd [143]
                Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/coreservicesd
                Parent:          launchd [1]
                UID:             0
                Task size:       13.98 MB
                  Thread 0x377              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  _CoreServicesServerMain + 710 (CarbonCore + 563987) [0x7fff2cc00b13] 1-10
                  Thread 0x3c9              10 samples (1-10)         priority 31 (base 31)
                        10  fmodWatchConsumer + 290 (CarbonCore + 307304) [0x7fff2cbc2068] 1-10
                  Thread 0x3ca              10 samples (1-10)         priority 31 (base 31)
                        10  read + 10 (libsystem_kernel.dylib + 123202) [0x7fff5399c142] 1-10
                         *10  hndl_unix_scall64 + 22 (kernel + 125382) [0xffffff800021e9c6] 1-10
                           *10  unix_syscall64 + 616 (kernel + 6306152) [0xffffff8000803968] 1-10
                             *10  read_nocancel + 115 (kernel + 5532931) [0xffffff8000746d03] 1-10
                               *10  ??? (kernel + 5533541) [0xffffff8000746f65] 1-10
                                 *10  ??? (kernel + 2958502) [0xffffff80004d24a6] 1-10
                                   *10  ??? (kernel + 5438002) [0xffffff800072fa32] 1-10
                                     *10  thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 1-10
                                       *10  ??? (kernel + 554618) [0xffffff800028767a] 1-10
                                         *10  machine_switch_context + 205 (kernel + 1584605) [0xffffff8000382ddd] 1-10
                  Binary Images:
                           0x10f72e000 -        0x10f72efff  coreservicesd (1178.4)                            <0B40BA4C-501A-3249-8EA7-9A954D104C3D>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/coreservicesd
                        0x7fff2cb77000 -     0x7fff2ce4efff  com.apple.CoreServices.CarbonCore 1178.4 (1178.4) <0D5E19BF-18CB-3FA4-8A5F-F6C787C5EE08>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                Process:         CoreServicesUIAgent [13376]
                Path:            /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
                Parent:          launchd [1]
                UID:             502
                Task size:       19.85 MB
                CPU Time:        <0.001s (273.4K cycles, 75.2K instructions, 3.63c/i)
                  Thread 0x5a16f8           DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)     cpu time <0.001s (153.3K cycles, 40.9K instructions, 3.75c/i)
                  Thread 0x5a1703           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 37 (base 37)
                  <thread QoS user initiated (requested user interactive), process sudden termination dirty, IO tier 0>
                  Binary Images:
                           0x10dce4000 -        0x10dd13fff  com.apple.coreservices.uiagent 180.7.6 (180.7.6) <1CE9BAFA-C20F-39C7-9BDE-D484BE211D38>  /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
                Process:         corespotlightd [404]
                Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Support/corespotlightd
                Parent:          launchd [1]
                UID:             502
                Task size:       25.89 MB
                  Thread 0x1354             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (corespotlightd + 38395) [0x107d195fb] 1-10
                  Thread 0x16b5             10 samples (1-10)         priority 31 (base 31)
                  10  <truncated backtrace> 1-10
                  Binary Images:
                           0x107d10000 -        0x107d1cfff  corespotlightd (1191.4.13)             <811549E5-277A-36A6-B74B-8832EC988C48>  /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Support/corespotlightd
                Process:         coresymbolicationd [621]
                Path:            /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
                Parent:          launchd [1]
                UID:             0
                Task size:       6592 KB
                  Thread 0x2ec2             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x108d67000 -        0x108d72fff  coresymbolicationd (64026.2)       <150AABEC-EC13-355E-9733-94A7574EA8B2>  /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
                Process:         crashpad_handler [14321]
                Path:            /Applications/Google Chrome.app/Contents/Versions/68.0.3440.106/Google Chrome Framework.framework/Versions/A/Helpers/crashpad_handler
                Parent:          launchd [1]
                Responsible:     Google Chrome (Chrome) [14319]
                UID:             502
                Task size:       9128 KB
                  Thread 0x67510f           DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested user interactive), process unclamped, IO tier 0>
                    10  ??? (crashpad_handler + 19428) [0x1033b3be4] 1-10
                      10  ??? (crashpad_handler + 30381) [0x1033b66ad] 1-10
                        10  ??? (crashpad_handler + 213369) [0x1033e3179] 1-10
                          10  ??? (crashpad_handler + 211822) [0x1033e2b6e] 1-10
                  Thread 0x675111           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), process unclamped, IO tier 0>
                        10  ??? (crashpad_handler + 189130) [0x1033dd2ca] 1-10
                          10  ??? (crashpad_handler + 184201) [0x1033dbf89] 1-10
                            10  ??? (crashpad_handler + 221694) [0x1033e51fe] 1-10
                              10  _dispatch_semaphore_wait_slow + 58 (libdispatch.dylib + 39246) [0x7fff5381894e] 1-10
                                10  semaphore_timedwait_trap + 10 (libsystem_kernel.dylib + 78430) [0x7fff5399125e] 1-10
                  Thread 0x675112           10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x1033af000 -        0x103416fff  crashpad_handler (0)               <89815085-974F-3592-A3D6-E3087F1A8542>  /Applications/Google Chrome.app/Contents/Versions/68.0.3440.106/Google Chrome Framework.framework/Versions/A/Helpers/crashpad_handler
                Process:         CrashReporterSupportHelper [355]
                Path:            /System/Library/CoreServices/CrashReporterSupportHelper
                Parent:          launchd [1]
                UID:             0
                Task size:       5540 KB
                  Thread 0xf50              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (CrashReporterSupportHelper + 8490) [0x10c5ae12a] 1-10
                  Binary Images:
                           0x10c5ac000 -        0x10c5aefff  CrashReporterSupportHelper (938.4.1)   <854C933E-AC36-3638-A76B-F9CA2004B9A4>  /System/Library/CoreServices/CrashReporterSupportHelper
                Process:         Creative Cloud [394]
                Path:            /Applications/Utilities/Adobe Creative Cloud/*/Creative Cloud.app/Contents/MacOS/Creative Cloud
                Parent:          launchd [1]
                UID:             502
                Task size:       169.04 MB
                CPU Time:        <0.001s (533.4K cycles, 189.0K instructions, 2.82c/i)
                Process:         ctkahp (Smartcard Agent) [261]
                Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
                Parent:          launchd [1]
                UID:             0
                Task size:       10176 KB
                  Thread 0x8ad              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 685 (ctkahp + 10627) [0x1048da983] 1-10
                  Binary Images:
                           0x1048d8000 -        0x1048edfff  com.apple.ctkahp 1.0 (1)               <E71E82FF-6955-3F74-A94C-062EBE5F4A5E>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
                Process:         ctkahp (Smartcard Agent) [326]
                Parent:          launchd [1]
                UID:             502
                Task size:       10.31 MB
                  Thread 0xe01              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 685 (ctkahp + 10627) [0x1019d6983] 1-10
                  Binary Images:
                           0x1019d4000 -        0x1019e9fff  com.apple.ctkahp 1.0 (1)               <E71E82FF-6955-3F74-A94C-062EBE5F4A5E>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
                Process:         ctkahp (Smartcard Agent) [7777]
                Parent:          launchd [1]
                UID:             0
                Task size:       10.22 MB
                  Thread 0x4a5b46           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  main + 685 (ctkahp + 10627) [0x10ea25983] 1-10
                  Binary Images:
                           0x10ea23000 -        0x10ea38fff  com.apple.ctkahp 1.0 (1)               <E71E82FF-6955-3F74-A94C-062EBE5F4A5E>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
                Process:         ctkd [172]
                Path:            /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
                Parent:          launchd [1]
                UID:             259
                Task size:       9888 KB
                  Thread 0x42f              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x1015c7000 -        0x1015d5fff  ctkd (281.50.22)                   <E10EFE63-B99D-3B51-8A27-75CBA24F0F82>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
                Process:         ctkd [330]
                Parent:          launchd [1]
                UID:             502
                Task size:       10.11 MB
                  Thread 0xe30              DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x103841000 -        0x10384ffff  ctkd (281.50.22)                   <E10EFE63-B99D-3B51-8A27-75CBA24F0F82>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
                Process:         ctkd [7778]
                Parent:          launchd [1]
                UID:             0
                Task size:       10.13 MB
                  Thread 0x4a5b55           DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x100b04000 -        0x100b12fff  ctkd (281.50.22)                   <E10EFE63-B99D-3B51-8A27-75CBA24F0F82>  /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
                Process:         cupsd [215]
                Path:            /usr/sbin/cupsd
                Parent:          launchd [1]
                UID:             0
                Task size:       14.64 MB
                CPU Time:        <0.001s (38.5K cycles, 14.6K instructions, 2.63c/i)
                  Thread 0x58e              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)       cpu time <0.001s (38.5K cycles, 14.6K instructions, 2.63c/i)
                    10  ??? (cupsd + 95390) [0x1008c949e] 1-10
                      10  kevent + 10 (libsystem_kernel.dylib + 121834) [0x7fff5399bbea] 1-10
                       *10  ??? (kernel + 5263408) [0xffffff8000705030] 1-10
                  Thread 0x9ef              10 samples (1-10)         priority 4 (base 4)
                        10  ??? (cupsd + 267948) [0x1008f36ac] 1-10
                  Binary Images:
                           0x1008b2000 -        0x100906fff  cupsd (462.2.4)                        <71AC0E67-CEEB-35ED-8E57-E2547A8957D9>  /usr/sbin/cupsd
                Process:         CVMServer [238]
                Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
                Parent:          launchd [1]
                UID:             0
                Task size:       2780 KB
                  Thread 0x7d6              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x10d3c2000 -        0x10d3cbfff  CVMServer (162.9)                  <C679EB4C-B2ED-361A-ACF8-701750092336>  /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
                Process:         dasd [105]
                Path:            /usr/libexec/dasd
                Parent:          launchd [1]
                UID:             0
                Task size:       12.53 MB
                  Thread 0x29f              DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (dasd + 5977) [0x10074f759] 1-10
                  Thread 0x6a5619           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background, process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                *10  wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f82a23b83] 1-10
                  Binary Images:
                           0x10074e000 -        0x10074ffff  dasd (626.60.2)                        <C9006AD5-7EB0-3BAD-92C5-2D1395F6E31E>  /usr/libexec/dasd
                Process:         DataDetectorsSourceAccess [10611]
                Path:            /usr/libexec/DataDetectorsSourceAccess
                Parent:          launchd [1]
                UID:             257
                Task size:       6680 KB
                  Thread 0x51e3b3           DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (DataDetectorsSourceAccess + 6003) [0x100253773] 1-10
                  Binary Images:
                           0x100252000 -        0x100253fff  DataDetectorsSourceAccess (590.3)      <AD510217-DEE0-3BF6-9605-9D522C0AEC13>  /usr/libexec/DataDetectorsSourceAccess
                Process:         dbfseventsd [500]
                Path:            /Library/DropboxHelperTools/*/dbfseventsd
                Parent:          Dropbox [334]
                Responsible:     Dropbox [334]
                UID:             0
                Task size:       844 KB
                CPU Time:        <0.001s (69.3K cycles, 22.2K instructions, 3.12c/i)
                  Thread 0x18b2             DispatchQueue 140735545517656                       10 samples (1-10)         priority 31 (base 31)     cpu time <0.001s (69.3K cycles, 22.2K instructions, 3.12c/i)
                  10  ??? (dbfseventsd + 4884) [0x100001314] 1-10
                    10  ??? (dbfseventsd + 5139) [0x100001413] 1-10
                  Binary Images:
                           0x100000000 -        0x10000afff  dbfseventsd                        <1F6C7C58-8553-3992-B509-6FB5841E0D40>  /Library/DropboxHelperTools/*/dbfseventsd
                Process:         dbfseventsd [501]
                Parent:          dbfseventsd [500]
                UID:             0
                Task size:       4596 KB
                CPU Time:        <0.001s (344.1K cycles, 111.5K instructions, 3.09c/i)
                  Thread 0x18b3             DispatchQueue 140735545517656                       10 samples (1-10)         priority 31 (base 31)     cpu time <0.001s (344.1K cycles, 111.5K instructions, 3.09c/i)
                  <IO tier 0>
                    10  ??? (dbfseventsd + 5753) [0x100001679] 1-10
                  Binary Images:
                Process:         dbfseventsd [508]
                Parent:          dbfseventsd [501]
                UID:             502
                Task size:       380 KB
                CPU Time:        <0.001s (281.6K cycles, 129.8K instructions, 2.17c/i)
                  Thread 0x18e6             DispatchQueue 140735545517656                       10 samples (1-10)         priority 31 (base 31)     cpu time <0.001s (281.6K cycles, 129.8K instructions, 2.17c/i)
                  <IO tier 0>
                      10  ??? (dbfseventsd + 12657) [0x100003171] 1-10
                                 *10  ??? (kernel + 5555689) [0xffffff800074c5e9] 1-10
                                   *10  ??? (kernel + 5437670) [0xffffff800072f8e6] 1-10
                                     *10  lck_mtx_sleep + 126 (kernel + 505086) [0xffffff800027b4fe] 1-10
                  Binary Images:
                Process:         deleted [445]
                Path:            /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
                Parent:          launchd [1]
                UID:             502
                Task size:       10.82 MB
                  Thread 0x1336             DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10dc1a000 -        0x10dc69fff  deleted (275.50.16)                <2C603149-CAD5-3BA8-B39F-D9232E821ACB>  /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
                Process:         diagnostics_agent [396]
                Path:            /System/Library/CoreServices/diagnostics_agent
                Parent:          launchd [1]
                UID:             502
                Task size:       16.70 MB
                  Thread 0x1352             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested background), thread darwinbg, process darwinbg, IO tier 3>
                    10  ??? (diagnostics_agent + 21724) [0x10172e4dc] 1-10
                  Binary Images:
                           0x101729000 -        0x101746fff  diagnostics_agent (938.4.1)            <D40D8F7D-D9D3-39EA-A535-E700EB826A0D>  /System/Library/CoreServices/diagnostics_agent
                Process:         diskarbitrationd [83]
                Path:            /usr/libexec/diskarbitrationd
                Parent:          launchd [1]
                UID:             0
                Task size:       7740 KB
                CPU Time:        <0.001s (533.1K cycles, 274.6K instructions, 1.94c/i)
                  Thread 0x280              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)     cpu time <0.001s (533.1K cycles, 274.6K instructions, 1.94c/i)
                    10  ??? (diskarbitrationd + 27830) [0x10b9accb6] 1-10
                  Binary Images:
                           0x10b9a6000 -        0x10b9bdfff  diskarbitrationd (297.70.1)            <190EF73F-C204-31BC-BD51-E1BE4DEAF90A>  /usr/libexec/diskarbitrationd
                Process:         diskmanagementd [229]
                Path:            /usr/libexec/diskmanagementd
                Parent:          launchd [1]
                UID:             0
                Task size:       18.99 MB
                  Thread 0x74c              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  <thread QoS default (requested default), IO tier 0>
                    10  ??? (diskmanagementd + 49804) [0x10b64328c] 1-10
                  Thread 0x13a4             10 samples (1-10)         priority 31 (base 31)
                          10  ??? (diskmanagementd + 76451) [0x10b649aa3] 1-10
                  Thread 0x750e             10 samples (1-10)         priority 31 (base 31)
                  Thread 0x7f80             10 samples (1-10)         priority 31 (base 31)
                  Thread 0x87a8             10 samples (1-10)         priority 31 (base 31)
                  Thread 0xbdb0             10 samples (1-10)         priority 31 (base 31)
                  Thread 0xf860             10 samples (1-10)         priority 31 (base 31)
                  Thread 0x13535            10 samples (1-10)         priority 31 (base 31)
                  Thread 0x5a044b           10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x10b637000 -        0x10b831fff  diskmanagementd (1429)                 <B1F49E51-9C20-3670-9D83-F2DAD960CD12>  /usr/libexec/diskmanagementd
                Process:         diskspaced [1788]
                Path:            /System/Library/PrivateFrameworks/StorageManagement.framework/Versions/A/Resources/disksp aced
                Parent:          launchd [1]
                UID:             502
                Task size:       10032 KB
                  Thread 0x2f936            DispatchQueue 11          10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), process sudden termination clean, timers tier 3 (coalesced), IO tier 1>
                  Binary Images:
                           0x10f39a000 -        0x10f39efff  diskspaced (60)                    <39D1E240-DAEF-3869-8778-18DC88CA7F38>  /System/Library/PrivateFrameworks/StorageManagement.framework/Versions/A/Resources/disksp aced
                Process:         DiskUnmountWatcher [707]
                Path:            /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
                Architecture:    x86_64
                Parent:          launchd [1]
                UID:             502
                Task size:       4364 KB
                  Thread 0x6f39             10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10b6ee000 -        0x10b6eefff  DiskUnmountWatcher (157)           <D55A63EB-FE63-3FA4-B217-E5DA1DA50B85>  /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
                Process:         displaypolicyd [104]
                Path:            /usr/libexec/displaypolicyd
                Parent:          launchd [1]
                UID:             244
                Task size:       9916 KB
                  Thread 0x28e              DispatchQueue 1           10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested utility), timers tier 3 (coalesced), IO tier 1>
                    10  ??? (displaypolicyd + 10537) [0x10ca60929] 1-10
                      10  ??? (displaypolicyd + 9717) [0x10ca605f5] 1-10
                  Thread 0x4f7              10 samples (1-10)         priority 20 (base 20)
                  <thread QoS utility (requested default), timers tier 3 (coalesced), IO tier 1>
                        10  ??? (displaypolicyd + 94635) [0x10ca751ab] 1-10
                          10  __accept + 10 (libsystem_kernel.dylib + 114382) [0x7fff53999ece] 1-10
                               *10  accept_nocancel + 417 (kernel + 5787665) [0xffffff8000785011] 1-10
                  Thread 0x880              10 samples (1-10)         priority 20 (base 20)
                        10  ??? (displaypolicyd + 119276) [0x10ca7b1ec] 1-10
                          10  ??? (displaypolicyd + 118820) [0x10ca7b024] 1-10
                  Thread 0x8ae              10 samples (1-10)         priority 20 (base 20)
                        10  ??? (displaypolicyd + 62677) [0x10ca6d4d5] 1-10
                          10  ??? (displaypolicyd + 51415) [0x10ca6a8d7] 1-10
                  Thread 0x8af              10 samples (1-10)         priority 20 (base 20)
                        10  ??? (displaypolicyd + 62690) [0x10ca6d4e2] 1-10
                          10  ??? (displaypolicyd + 53266) [0x10ca6b012] 1-10
                  Binary Images:
                           0x10ca5e000 -        0x10ca91fff  displaypolicyd (3.20.13)               <31BC90AD-12FD-3ABD-956F-15E192DD8541>  /usr/libexec/displaypolicyd
                Process:         distnoted [120]
                Path:            /usr/sbin/distnoted
                Parent:          launchd [1]
                UID:             241
                Task size:       5644 KB
                CPU Time:        0.007s (28.1M cycles, 9.9M instructions, 2.82c/i)
                Note:            9 idle work queue threads omitted
                  Thread 0x3b7              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (distnoted + 16199) [0x10e732f47] 1-10
                  Thread 0x6a5d71           DispatchQueue 29          1 sample (5)              priority 37 (base 37)     cpu time <0.001s (75.3K cycles, 28.4K instructions, 2.65c/i)
                  <DispatchQueue not seen for 4 samples, thread QoS user initiated (requested user initiated, ipc override user initiated), process sudden termination dirty, IO tier 0>
                  1  ??? [0x7000047dc8e0] 5
                    1  start_wqthread + 13 (libsystem_pthread.dylib + 11241) [0x7fff53b61be9] 5
                      1  _pthread_wqthread + 980 (libsystem_pthread.dylib + 12242) [0x7fff53b61fd2] 5
                        1  _dispatch_workloop_worker_thread + 880 (libdispatch.dylib + 109857) [0x7fff53829d21] 5
                          1  _dispatch_root_queue_drain_deferred_wlh + 332 (libdispatch.dylib + 93965) [0x7fff53825f0d] 5
                            1  _dispatch_queue_invoke + 373 (libdispatch.dylib + 37222) [0x7fff53818166] 5
                              1  _dispatch_queue_serial_drain + 222 (libdispatch.dylib + 90234) [0x7fff5382507a] 5
                                1  _dispatch_mach_invoke + 534 (libdispatch.dylib + 22898) [0x7fff53814972] 5
                                    1  _dispatch_mach_msg_invoke + 488 (libdispatch.dylib + 28770) [0x7fff53816062] 5
                                      1  _dispatch_client_callout4 + 9 (libdispatch.dylib + 28073) [0x7fff53815da9] 5
                                        1  _xpc_connection_mach_event + 1092 (libxpc.dylib + 40753) [0x7fff53b9df31] 5
                                          1  _xpc_connection_call_event_handler + 35 (libxpc.dylib + 46963) [0x7fff53b9f773] 5
                                            1  ??? (distnoted + 23509) [0x10e734bd5] 5
                                              1  xpc_dictionary_get_bool + 35 (libxpc.dylib + 21352) [0x7fff53b99368] 5
                                                1  _xpc_dictionary_look_up_fast + 68 (libxpc.dylib + 21483) [0x7fff53b993eb] 5
                                                  1  _xpc_dictionary_look_up + 668 (libxpc.dylib + 20411) [0x7fff53b98fbb] 5
                                                    1  _xpc_serializer_advance + 27 (libxpc.dylib + 30357) [0x7fff53b9b695] 5
                                                     *1  call_continuation + 23 (kernel + 120151) [0xffffff800021d557] 5
                                                       *1  thread_block_reason + 175 (kernel + 550463) [0xffffff800028663f] 5
                                                         *1  ??? (kernel + 554223) [0xffffff80002874ef] (running) 5
                  Thread 0x6a278c           DispatchQueue 35          1 sample (5)              priority 37 (base 37)     cpu time <0.001s
                  1  ??? [0x2e6d6f6300000018] 5
                                    1  _dispatch_mach_send_barrier_drain_invoke + 412 (libdispatch.dylib + 115086) [0x7fff5382b18e] 5
                                      1  _dispatch_mach_send_invoke + 674 (libdispatch.dylib + 115890) [0x7fff5382b4b2] 5
                                        1  _dispatch_mach_send_drain + 241 (libdispatch.dylib + 29259) [0x7fff5381624b] 5
                                          1  _dispatch_continuation_pop + 86 (libdispatch.dylib + 85247) [0x7fff53823cff] 5
                                            1  _dispatch_mach_barrier_invoke + 605 (libdispatch.dylib + 27981) [0x7fff53815d4d] 5
                                              1  _dispatch_set_priority_and_voucher_slow + 314 (libdispatch.dylib + 81547) [0x7fff53822e8b] 5
                                                1  _dispatch_set_priority_and_mach_voucher_slow + 160 (libdispatch.dylib + 81097) [0x7fff53822cc9] 5
                                                  1  __bsdthread_ctl + 10 (libsystem_kernel.dylib + 114526) [0x7fff53999f5e] 5
                                                   *1  hndl_unix_scall64 + 22 (kernel + 125382) [0xffffff800021e9c6] 5
                                                     *1  unix_syscall64 + 647 (kernel + 6306183) [0xffffff8000803987] (running) 5
                  Thread 0x6a5d6f           DispatchQueue 130         1 sample (5)              priority 37 (base 37)     cpu time <0.001s (56.4K cycles, 21.7K instructions, 2.60c/i)
                  <DispatchQueue not seen for 4 samples, thread QoS user initiated (requested user initiated), process sudden termination dirty, IO tier 0>
                  1  ??? [0x10f201880] 5
                              1  _dispatch_queue_serial_drain + 635 (libdispatch.dylib + 90647) [0x7fff53825217] 5
                                1  _dispatch_client_callout + 8 (libdispatch.dylib + 7608) [0x7fff53810db8] 5
                                  1  _dispatch_call_block_and_release + 12 (libdispatch.dylib + 38394) [0x7fff538185fa] 5
                                    1  ??? (distnoted + 24249) [0x10e734eb9] 5
                                      1  ??? (distnoted + 6463) [0x10e73093f] 5
                                        1  ??? (distnoted + 8379) [0x10e7310bb] 5
                                          1  ??? (distnoted + 22870) [0x10e734956] 5
                                            1  xpc_connection_send_message + 89 (libxpc.dylib + 43885) [0x7fff53b9eb6d] 5
                                              1  _xpc_connection_enqueue + 136 (libxpc.dylib + 39563) [0x7fff53b9da8b] 5
                                                1  dispatch_mach_send_with_result + 50 (libdispatch.dylib + 116564) [0x7fff5382b754] 5
                                                  1  _dispatch_mach_send_msg + 394 (libdispatch.dylib + 116330) [0x7fff5382b66a] 5
                                                    1  _dispatch_mach_send_drain + 325 (libdispatch.dylib + 29343) [0x7fff5381629f] 5
                                                      1  _dispatch_mach_msg_send + 799 (libdispatch.dylib + 25466) [0x7fff5381537a] 5
                                                        1  mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 5
                                                         *1  hndl_mach_scall64 + 22 (kernel + 125414) [0xffffff800021e9e6] 5
                                                           *1  mach_call_munger64 + 509 (kernel + 1513245) [0xffffff800037171d] 5
                                                             *1  mach_msg_overwrite_trap + 891 (kernel + 398667) [0xffffff800026154b] 5
                                                               *1  ipc_kmsg_send + 599 (kernel + 322519) [0xffffff800024ebd7] 5
        *1  ipc_mqueue_send + 95 (kernel + 337375) [0xffffff80002525df] 5
        *1  ipc_mqueue_post + 620 (kernel + 338284) [0xffffff800025296c] 5
        *1  knote + 175 (kernel + 5240911) [0xffffff80006ff84f] 5
        *1  ??? (kernel + 5237875) [0xffffff80006fec73] 5
        *1  ??? (kernel + 5240563) [0xffffff80006ff6f3] 5
        *1  workq_kern_threadreq + 507 (pthread + 24284) [0xffffff7f82a25edc] 5
        *1  workqueue_run_threadreq_and_unlock + 4687 (pthread + 13219) [0xffffff7f82a233a3] 5
        *1  thread_wakeup_thread + 61 (kernel + 559757) [0xffffff8000288a8d] 5
        *1  waitq_wakeup64_thread + 165 (kernel + 742165) [0xffffff80002b5315] (running) 5
                  Thread 0x6a71f6           1 sample (5)              priority 37 (base 37)
                  <Thread not seen for 4 samples, thread QoS user initiated (requested user initiated, ipc override user initiated), process sudden termination dirty, IO tier 0>
                  1  ??? [0x1800009000] 5
                      1  __workq_kernreturn + 10 (libsystem_kernel.dylib + 119434) [0x7fff5399b28a] 5
                       *1  wq_unpark_continue + 0 (pthread + 15235) [0xffffff7f82a23b83] (runnable) 5
                  Binary Images:
                           0x10e72f000 -        0x10e737fff  distnoted (1454.90)                    <3A0A8968-10C3-3D51-BAEE-6B3BA785B324>  /usr/sbin/distnoted
                        0x7fff53b94000 -     0x7fff53bc1fff  libxpc.dylib (1205.70.9)               <0BC7AD67-671D-31D4-8B88-C317B8379598>  /usr/lib/system/libxpc.dylib
                Process:         distnoted [287]
                Parent:          launchd [1]
                UID:             502
                Task size:       9840 KB
                CPU Time:        0.010s (41.8M cycles, 22.5M instructions, 1.85c/i)
                Note:            12 idle work queue threads omitted
                  Thread 0xc1d              DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                  10  start + 1 (libdyld.dylib + 4117) [0x7fff5384a015] 1-10
                    10  ??? (distnoted + 16199) [0x1045e7f47] 1-10
                  Thread 0x6a61f9           DispatchQueue 23          1 sample (5)              priority 37 (base 37)     cpu time <0.001s (73.0K cycles, 21.8K instructions, 3.34c/i)
                  1  ??? [0x7fe7e2d4a600] 5
                                        1  _xpc_connection_mach_event + 1068 (libxpc.dylib + 40729) [0x7fff53b9df19] 5
                                          1  _xpc_connection_unpack_message + 97 (libxpc.dylib + 41714) [0x7fff53b9e2f2] 5
                                            1  _xpc_serializer_unpack + 735 (libxpc.dylib + 29128) [0x7fff53b9b1c8] 5
                                              1  _xpc_dictionary_wire_length + 0 (libxpc.dylib + 30116) [0x7fff53b9b5a4] (running) 5
                  Binary Images:
                           0x1045e4000 -        0x1045ecfff  distnoted (1454.90)                    <3A0A8968-10C3-3D51-BAEE-6B3BA785B324>  /usr/sbin/distnoted
                Process:         distnoted [641]
                Parent:          launchd [1]
                UID:             89
                Task size:       3840 KB
                CPU Time:        0.001s (5.6M cycles, 849.6K instructions, 6.57c/i)
                  Thread 0x379c             DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (distnoted + 16199) [0x10c753f47] 1-10
                  Thread 0x6a5d74           1 sample (5)              priority 37 (base 37)     cpu time <0.001s
                  <Thread in another stack for 4 samples, thread QoS user initiated (requested user initiated, ipc override user initiated), process sudden termination dirty, IO tier 0>
                  1  ??? [0x70000bbcd8e0] 5
                        1  _dispatch_workloop_worker_thread + 518 (libdispatch.dylib + 109495) [0x7fff53829bb7] 5
                          1  _dispatch_event_loop_merge + 117 (libdispatch.dylib + 129100) [0x7fff5382e84c] 5
                            1  _dispatch_mach_merge_msg + 42 (libdispatch.dylib + 113259) [0x7fff5382aa6b] (running) 5
                  Binary Images:
                           0x10c750000 -        0x10c758fff  distnoted (1454.90)                    <3A0A8968-10C3-3D51-BAEE-6B3BA785B324>  /usr/sbin/distnoted
                Process:         distnoted [6561]
                Parent:          launchd [1]
                UID:             205
                Task size:       3120 KB
                CPU Time:        0.001s (5.3M cycles, 739.9K instructions, 7.19c/i)
                  Thread 0x4619e7           DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (distnoted + 16199) [0x10409cf47] 1-10
                  Thread 0x6a5e32           1 sample (5)              priority 37 (base 37)     cpu time <0.001s
                         *1  wq_unpark_continue + 644 (pthread + 15879) [0xffffff7f82a23e07] 5
                           *1  _setup_wqthread + 813 (pthread + 17598) [0xffffff7f82a244be] 5
                             *1  kevent_id_internal + 55 (kernel + 5264583) [0xffffff80007054c7] 5
                               *1  ??? (kernel + 5255434) [0xffffff800070310a] 5
                                 *1  kqueue_scan + 77 (kernel + 5260509) [0xffffff80007044dd] 5
                                   *1  ??? (kernel + 5263124) [0xffffff8000704f14] 5
                                     *1  ??? (kernel + 359179) [0xffffff8000257b0b] 5
                                       *1  mach_msg_receive_results + 545 (kernel + 396625) [0xffffff8000260d51] 5
                                         *1  ipc_kmsg_copyout + 31 (kernel + 334367) [0xffffff8000251a1f] 5
                                           *1  ipc_kmsg_copyout_header + 815 (kernel + 330831) [0xffffff8000250c4f] 5
                                             *1  ipc_right_copyout + 260 (kernel + 372916) [0xffffff800025b0b4] (running) 5
                  Binary Images:
                           0x104099000 -        0x1040a1fff  distnoted (1454.90)                    <3A0A8968-10C3-3D51-BAEE-6B3BA785B324>  /usr/sbin/distnoted
                Process:         distnoted [6575]
                Parent:          launchd [1]
                UID:             0
                Task size:       3132 KB
                CPU Time:        <0.001s (798.7K cycles, 290.1K instructions, 2.75c/i)
                  Thread 0x462f5d           DispatchQueue 1           10 samples (1-10)         priority 31 (base 31)
                    10  ??? (distnoted + 16199) [0x107118f47] 1-10
                  Thread 0x6a5dea           1 sample (5)              priority 37 (base 37)
                  Binary Images:
                           0x107115000 -        0x10711dfff  distnoted (1454.90)                    <3A0A8968-10C3-3D51-BAEE-6B3BA785B324>  /usr/sbin/distnoted
                Process:         dmd [382]
                Path:            /usr/libexec/dmd
                Parent:          launchd [1]
                UID:             502
                Task size:       12.31 MB
                  Thread 0x134f             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (dmd + 271704) [0x10f1cc558] 1-10
                      10  ??? (dmd + 232339) [0x10f1c2b93] 1-10
                  Binary Images:
                           0x10f18a000 -        0x10f1dcfff  dmd (10.48)                            <4BADAEBD-D0FA-39C2-A0F1-A85124F1B807>  /usr/libexec/dmd
                Process:         dmd [460]
                Parent:          launchd [1]
                UID:             0
                Task size:       11.46 MB
                  Thread 0x154b             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (dmd + 271704) [0x102969558] 1-10
                      10  ??? (dmd + 243607) [0x102962797] 1-10
                        10  ??? (dmd + 232339) [0x10295fb93] 1-10
                  Binary Images:
                           0x102927000 -        0x102979fff  dmd (10.48)                            <4BADAEBD-D0FA-39C2-A0F1-A85124F1B807>  /usr/libexec/dmd
                Process:         Dock [296]
                Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
                Parent:          launchd [1]
                UID:             502
                Task size:       152.89 MB
                  Thread 0xc91              DispatchQueue 1           10 samples (1-10)         priority 47 (base 47)
                  <process frontmost, thread QoS user interactive (requested user interactive), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
                    10  ??? (Dock + 24889) [0x1078fa139] 1-10
                      10  autoreleasepool<A>(invoking:) + 56 (libswiftObjectiveC.dylib + 15464) [0x7fff4ebf7c68] 1-10
                        10  ??? (Dock + 1722302) [0x107a987be] 1-10
                          10  ??? (Dock + 1722509) [0x107a9888d] 1-10
                              10  ??? (Dock + 1722382) [0x107a9880e] 1-10
                  Thread 0x1282             10 samples (1-10)         priority 31 (base 31)
                  <process frontmost, thread QoS default (requested default), process unclamped, process received importance donation from WindowServer [214], IO tier 0>
                  10  thread_start + 13 (libsystem_pthread.dylib + 11257) [0x7fff53b61bf9] 1-10
                    10  _pthread_start + 377 (libsystem_pthread.dylib + 13581) [0x7fff53b6250d] 1-10
                      10  _pthread_body + 340 (libsystem_pthread.dylib + 13921) [0x7fff53b62661] 1-10
                        10  ??? (Dock + 142843) [0x107916dfb] 1-10
                  Binary Images:
                           0x1078f4000 -        0x107e1cfff  com.apple.dock 1.8 (1849.16)           <2FA55534-87F6-3967-8AFF-589C0DA1467E>  /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
                        0x7fff4ebf4000 -     0x7fff4ebf9fff  libswiftObjectiveC.dylib (900.8.49.1)  <DCF880C2-D021-36E6-86A1-63845D04E99E>  /System/Library/PrivateFrameworks/Swift/libswiftObjectiveC.dylib
                Process:         DocumentPopoverViewService [14734]
                Path:            /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/DocumentPopoverViewSer vice.xpc/Contents/MacOS/DocumentPopoverViewService
                Parent:          launchd [1]
                Responsible:     Preview [14729]
                UID:             502
                Task size:       36.91 MB
                  Thread 0x692f76           DispatchQueue 1           10 samples (1-10)         priority 46 (base 46)
                  <thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, IO tier 0>
                    10  main + 37 (DocumentPopoverViewService + 4317) [0x10c8df0dd] 1-10
                      10  NSViewServiceApplicationMain + 2903 (ViewBridge + 10942) [0x7fff5048eabe] 1-10
                        10  -[NSXPCSharedListener resume] + 16 (ViewBridge + 19477) [0x7fff50490c15] 1-10
                          10  xpc_main + 433 (libxpc.dylib + 63946) [0x7fff53ba39ca] 1-10
                            10  _xpc_objc_main + 580 (libxpc.dylib + 68983) [0x7fff53ba4d77] 1-10
                                10  -[NSApplication run] + 764 (AppKit + 223365) [0x7fff28f9d885] 1-10
                                  10  -[NSViewServiceApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 92 (ViewBridge + 19952) [0x7fff50490df0] 1-10
                                    10  -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 3044 (AppKit + 8224308) [0x7fff2973ee34] 1-10
                  Thread 0x692fab           Thread name "com.apple.NSEventThread"               10 samples (1-10)         priority 46 (base 46)
                          10  CFRunLoopRunSpecific + 483 (CoreFoundation + 545107) [0x7fff2ba0d153] 1-10
                            10  __CFRunLoopRun + 1783 (CoreFoundation + 547543) [0x7fff2ba0dad7] 1-10
                              10  __CFRunLoopServiceMachPort + 341 (CoreFoundation + 550789) [0x7fff2ba0e785] 1-10
                                10  mach_msg_trap + 10 (libsystem_kernel.dylib + 78346) [0x7fff5399120a] 1-10
                                 *10  ipc_mqueue_receive_continue + 0 (kernel + 339136) [0xffffff8000252cc0] 1-10
                  Binary Images:
                           0x10c8de000 -        0x10c8e5fff  com.apple.appkit.xpc.documentPopoverViewService 6.9 (1) <C2FA80BC-5559-3B57-8E76-15405A4806CF>  /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/DocumentPopoverViewSer vice.xpc/Contents/MacOS/DocumentPopoverViewService
                        0x7fff5048c000 -     0x7fff5055bfff  com.apple.ViewBridge 343.2 (343.2)                      <5519FCED-1F88-3BE6-9BE1-69992086B01B>  /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
                Process:         dprivacyd [2134]
                Path:            /usr/libexec/dprivacyd
                Parent:          launchd [1]
                UID:             0
                Task size:       7772 KB
                  Thread 0x48f33            DispatchQueue 11          10 samples (1-10)         priority 4 (base 4)
                  Binary Images:
                           0x10bc40000 -        0x10bc40fff  dprivacyd (142.70.1)               <00206B9B-F631-3F17-B56D-181915533A65>  /usr/libexec/dprivacyd
                Process:         Dropbox [334]
                Path:            /Applications/Dropbox.app/Contents/MacOS/Dropbox
                Parent:          launchd [1]
                UID:             502
                Task size:       317.92 MB
                CPU Time:        <0.001s (1599.0K cycles, 1013.5K instructions, 1.58c/i)
                Process:         Dropbox [339]
                Parent:          launchd [1]
                UID:             502
                Task size:       9572 KB
                Process:         Dropbox [341]
                UID:             502
                Task size:       11.20 MB
                Process:         DropboxActivityProvider [471]
                Path:            /Applications/Dropbox.app/Contents/XPCServices/DropboxActivityProvider.xpc/Contents/MacOS /DropboxActivityProvider
                Parent:          launchd [1]
                UID:             502
                Task size:       59.96 MB
                CPU Time:        <0.001s (668.8K cycles, 181.9K instructions, 3.68c/i)
                Process:         DropboxFolderTagger [502]
                Path:            /Applications/Dropbox.app/Contents/XPCServices/DropboxFolderTagger.xpc/Contents/MacOS/Dro pboxFolderTagger
                Parent:          launchd [1]
                UID:             502
                Task size:       14.22 MB
                Process:         EscrowSecurityAlert [915]
                Path:            /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
                Parent:          launchd [1]
                UID:             502
                Task size:       22.21 MB
                  Thread 0x11eab            DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                  <thread QoS background (requested background), process sudden termination clean, thread darwinbg, process darwinbg, IO tier 2>
                    10  ??? (EscrowSecurityAlert + 18185) [0x10c48c709] 1-10
                  Binary Images:
                           0x10c488000 -        0x10c48dfff  com.apple.EscrowSecurityAlert 1.0 (1)  <9C289894-1B14-3C87-8A2E-87702CF0013B>  /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
                Process:         ethcheck [210]
                Path:            /usr/libexec/firmwarecheckers/ethcheck/ethcheck
                Parent:          launchd [1]
                UID:             0
                Task size:       3804 KB
                  Thread 0x593              10 samples (1-10)         priority 4 (base 4)
                     *10  ??? (kernel + 5438272) [0xffffff800072fb40] 1-10
                  Binary Images:
                           0x109c7e000 -        0x109c85fff  ethcheck (25.50.1)                 <FC4392A0-243E-3F2F-88F8-A49C43265ACD>  /usr/libexec/firmwarecheckers/ethcheck/ethcheck
                Process:         filecoordinationd [321]
                Path:            /usr/sbin/filecoordinationd
                Parent:          launchd [1]
                UID:             0
                Task size:       7448 KB
                  Thread 0xdcb              DispatchQueue 11          10 samples (1-10)         priority 31 (base 31)
                  Binary Images:
                           0x107745000 -        0x107745fff  filecoordinationd (1454.90)        <3C05FCCF-7704-3833-9292-C5D732E17C90>  /usr/sbin/filecoordinationd
                Process:         fileproviderd [371]
                Path:            /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
                Parent:          launchd [1]
                UID:             502
                Task size:       12.64 MB
                  Thread 0x127c             DispatchQueue 1           10 samples (1-10)         priority 4 (base 4)
                    10  ??? (fileproviderd + 10191) [0x104c727cf] 1-10
                  Binary Images:
                           0x104c70000 -        0x104ca9fff  fileproviderd (125.15)                 <E6C02333-F680-32D9-B352-B61D9CDAB1DB>  /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
                Process:         Finder [300]
                Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
                Parent:          launchd [1]
                UID:             502
                Task size:       202.27 MB (+1556 KB)
                CPU Time:        0.030s (129.4M cycles, 67.3M instructions, 1.92c/i)
                  Thread 0xc9c              DispatchQueue 1           10 samples (1-10)         priority 47 (base 47)     cpu time 0.025s (108.0M cycles, 58.4M instructions, 1.85c/i)
                  <process frontmost, thread QoS user interactive (requested user interactive), process sudden termination dirty, process unclamped, process received importance donation from WindowServer [214], IO tier 0>
                    10  ??? (Finder + 23182) [0x103b7fa8e] 1-10
                        1  -[NSApplication run] + 812 (AppKit + 223413) [0x7fff28f9d8b5] 1
                          1  ??? (Finder + 125336) [0x103b98998] 1
                            1  -[NSApplication(NSEvent) sendEvent:] + 2060 (AppKit + 8216740) [0x7fff2973d0a4] 1
                              1  -[NSApplication _handleKeyFocusNotification:withEvent:] + 83 (AppKit + 4576849) [0x7fff293c4651] 1
                                1  -[NSWindow becomeKeyWindow] + 1357 (AppKit + 1460464) [0x7fff290cb8f0] 1
                                  1  -[NSWindow(NSWindow_Theme) acquireKeyAppearance] + 170 (AppKit + 1463144) [0x7fff290cc368] 1
                                    1  -[NSWindow _setFrameNeedsDisplay:] + 178 (AppKit + 1468133) [0x7fff290cd6e5] 1
                                      1  -[NSThemeFrame _windowChangedKeyState] + 46 (AppKit + 1482617) [0x7fff290d0f79] 1
                                        1  -[NSView _windowChangedKeyState] + 253 (AppKit + 906394) [0x7fff2904449a] 1
