1 Reply Latest reply on Mar 20, 2008 9:02 AM by alejandro52
    HTTPS service
    ralph31
      I would like to use HTTPS service to load an external XML file, then make an AIR from the web file. Will the HTTPS service work? If not will
      <mx: xml id ="xml" source = ? /> work?
      Thanx
        • 1. Re: HTTPS service
          alejandro52
          Using httpService with air works fine. you can set the resultFormat as e4x, on the initialize function of the component you could send the data, and on the result event of the httpService you could get the data on a xml variable
