3 Replies Latest reply on Mar 18, 2008 12:33 PM by carburateur
    vector graphics
    carburateur
      I'm beginner in Flash 8 and really need help to achieve this job.... Hope I will get good news here
      THE GOAL
        • 1. Re: vector graphics
          Greg Dove Level 4
          I would be inclined to do this with an array of point objects:
          http://livedocs.adobe.com/flash/9.0/main/00002050.html#wp428765
          take a look at the Point object methods...e.g. offset
          And use the drawing API commands
          http://livedocs.adobe.com/flash/9.0/main/00001933.html#wp386253
          You can draw each segment with a lineTo for the next Points x and y properties.
          You also need to place movieclip dots (using attachMovie) for each visual representation of a point and to permit the mouse events and startDrag activity for moving them etc.
          That's a very quick idea of how I would do it, perhaps I would change things were I actually doing it.
          This is not a super complicated project, and you say you are new to flash 8, but you don't say if you are new to flash. If you are also new to flash there's a lot there to get familiar with in one go. If that is the case you probably want to run through some of the examples for each aspect of what you need to do. Start with the examples in the help files... look for online tutorials if you need more understanding.
          • 2. Re: vector graphics
            Greg Dove Level 4
            I just looked again and I see you have arrow shapes, so perhaps the lines would better suit use of a library movie clip symbol also... with the registration point at the base of the arrow. You could calculate the length and the angle of rotation based on the differences between the x and y coordinates between the points.
            Others may have other ideas for how to do this.
            • 3. Re: vector graphics
              carburateur Level 1
              I am beginner in "Flash".
              To prepare the programmation I identify the only 4 possibilities :
              IF
              I move B
              THEN
              --> V1 change of shape
              --> V2, V3, V4 translate without change of shape
              --> V5 change of shape
              IF
              I move C
              THEN
              --> V1 do not move, do not change of shape
              --> V2 change of shape
              --> V3, V4 translate without change of shape
              IF
              I move D
              THEN
              --> V1, V2 do not move, do not change of shape
              --> V3 change of shape
              --> V4 translate without change of shape
              IF
              I move E
              THEN
              --> V1, V2, V3 do not move, do not change of shape
              --> V4 change of shape
              Many thanks for your help.
