2 Replies Latest reply on Sep 13, 2008 4:27 PM by hornstein
    How do you create a dynamic Slideshow?
    Level 7
      How do you create a dynamic slideshow using flash cs3? Let me explain: We
      have "Customer" definable html slideshows that a user can manually click
      through. The customer can go to a maintenance area and Add, remove or
      hcange any photo in any category and also change order in which it is
      viewed. Very simple code using ASP.NET. Now how do i get Flash to do the
      same. The above solution is completed by using a database list. Does Flash
      read Databases, if so problem solved, but where is the script for it. If
      not, what is another solution so my customer can edit the list of photos via
      the internet using one of our ASP.NET modules.
      Thank you in advnace for your help. If have looked everywhere for solutions
      on this and have only found during SWF creation solutions not post SWF
      creation.
        • 1. Re: How do you create a dynamic Slideshow?
          Level 7
          I would highly recommend slideshowpro.net using their Director and Slideshow
          program.
          "Name Withheld" <NoSpam@NoSpam.com> wrote in message
          news:frot1e$36$1@forums.macromedia.com...
          > We have "Customer" definable html slideshows that a user can manually
          > click through. The customer can go to a maintenance area and Add, remove
          > or hcange any photo in any category and also change order in which it is
          > Flash read Databases, if so problem solved, but where is the script for
          > it. If not, what is another solution so my customer can edit the list of
          > photos via the internet using one of our ASP.NET modules.
          > solutions on this and have only found during SWF creation solutions not
          > post SWF creation.
          • 2. Re: How do you create a dynamic Slideshow?
            hornstein
            Is there any other software out there that's a little easier to use than Slideshow Pro? Too much coding.
