After the last update of Adobe XD I can't choose any time of transitions than 1s. When I try to choose any other time, such as 0.2, 0.4, 0.6, etc, it's unavailable.
This issue has been fixed in the update released today. Can you try installing the latest build and let us know if you are still facing this issue?
Preran
What do you mean by unavailable? Is the option grayed out, can you not choose it, do you not see the option? You should see something like this:
No, I see the options but when I try to select one of them, I can't.
I try to choose 0,6s, for exemple, but It can't remain selected.
Is it only on one file, or all files?
I tried in 2 differente files and in 2 different computers with the same issue.
From a team member's post on Twitter, it looks like this is a known issue and the team is working towards fixing it. Can you try entering the values manually? Does that work?
I tried to enter values manually but it doesn't work either. It remains on 1s only.
Thank you for your observations. This issue looks like it is restricted to specific locales. The team has logged a bug for it and is investigating the issue on priority. Stay tuned for updates. Apologize for the inconvenience meanwhile.
Preran
Hi skinimolsion ,
Are you using Mac OS? If yes, as a workaround, could you please try below steps:
1. Go to System Preferences > Language and region > Advanced > General
2. Check the value of Number separator for decimal
3. If it is set to comma ( , ) then please try changing it to dot ( . )
4. Try to change transition duration now in XD and see if it works.
Yes, I'm using a Mac.
I tried to change from comma to dot but I'm still having this issue with transitions on prototypes.
Preran
the issue still exists
Edit: duration is only 1s
Are you sure you are on the latest update? Can you verify if you have the version number 9.1 installed on your computer?
that's all I can download from CC,
Edit: Ok, now I downloaded the newest one. The latest version appeared a minute ago
It's working now! Thanx
Hi Peran! Yes, after the last update, it's working again.
Thank you!
