I have created an interactive calendar, with links that take you to the events page. When I view that document in Chrome or Safari, the lines don't show up. They do show up in Firefox. Is there a work around to get the line to show up, so that our viewers know it is an interactive calendar?
Hi Communicationskcc,
As per the issue description mentioned above, PDF hyperlink line not showing in an interactive pdf, is that correct?
Web browsers uses their own mechanism to show pdf which we don't have any control over. You may try changing the appearance of the link and check if that helps. Refer to the steps given in the following help document for the same: Creating Hyperlinks in Adobe Acrobat
Let us know if you need any help.
Shivam
Changing the link (making the line thicker) in Acrobat Pro DC did not change anything in Chrome or Safari. The links are only showing in Firefox. Are you aware of a setting in Acrobat that will allow the links to be seen in all browsers?
Hi CommunicationsKCC,
Would it be possible if you can share the pdf file with us? To share the file here in the forums, refer to the steps given here: How to share a file using Adobe Document Cloud
Thank You,
Shivam
