I'm building an app in animate cc (10-frames long) and I have a movieclip at frame 3. When I navigate through frames 4-9 and return to frame 3, the object is still there, but when I go back from frame 10, my object turns null and my app crashes. I don't have a code that would remove it from the stage. I don't know what's happening, but that's the second time I've experienced something like this. It seems completely random and I can't seem to be able to fix it. This is really worrying.
Hmm, are you accessing an object within the movieclip ? or the movieclip directly ?
What code do you have in frame 10 ? how does it differ to 9 and the way is accesses the object ?
Example would be good !
Regards,
Is frame 10 a keyframe and does the movieclip still have an instance name assigned there if it is?
No, the app is a mobile app, so different views (frames) have different set of items. So in one frame I display game stas score, name, etc. while in another one I have a FAQ sections. The object in frame 3 doesn't exist in frame 10. This is undoubtedly a very annoying bug. I fixed it by placing the object on a separate layer and extending through the entire timeline, so that it's available in every view. I just added a new keyframe (instance name is preserved all the time), so that I could move the object out of users signt (it's an absolutely terrible workaround). I didn't want to play with the "visible" property or adding that object through code because I have several navigation buttons and I would have to add too many add/remove listeners and add/remove child, or the visible property.
Flash/animate cc can randomly lose instance names of random objects when navigating through frames.It's already happened to me 3 times on unique objects (used only once) or reused objects, e.g. same back button, but with different instance names. It's completely random.
